| Re: One person enough to right the F16 in all conditions?
[Re: SIAM]
#228752 02/17/11 02:57 PM 02/17/11 02:57 PM |
Posts: 3,528 Looking for a Job, I got credi... | I had the main, traveller and downhaul all off (maybe not rotation) and was hanging right on the bow kicking with my legs to swing the bows into the wind but could still only get it to 45 degrees enough to get the wind under the sail but could not get it round further This may be the problem; you need to let the sterns drift down wind; not swim/kick the bows to the wind. If you are forward you are sinking the bows; trying to swim them round is going to be difficult/impossible; let the wind blow the higher-flowting sterns to drift away.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: One person enough to right the F16 in all conditions?
[Re: scooby_simon]
#228756 02/17/11 03:55 PM 02/17/11 03:55 PM |
Posts: 606 Maryland | This may be the problem; you need to let the sterns drift down wind; not swim/kick the bows to the wind.
If you are forward you are sinking the bows; trying to swim them round is going to be difficult/impossible; let the wind blow the higher-flowting sterns to drift away. Problem is if there is a strong current from the same direction. The bows being pushed down dig into the current. Usually, it results in a 45% angle to the wind.
Kris Hathaway | | | Re: One person enough to right the F16 in all conditions?
[Re: PTP]
#228853 02/19/11 06:12 PM 02/19/11 06:12 PM |
Posts: 4,119 Northfield Mn | in 15kt's you could damn near right the Titanic singlehanded.
(edit)- Its the days when you're screwing around on the low side in light air its tough to right a singlehanded F16. When its blowing its pretty easy. Add some waves its even easier.
394
guests, and 37
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
