by soulsailor. 03/11/25 11:57 AM
Kids trap harness #230667
04/01/11 08:26 PM
04/01/11 08:26 PM
Dunedin Causeway, FL
David Parker Offline OP
My 10 year old son needs a harness, probably not a full one. Any suggestions?
Re: Kids trap harness [Re: David Parker] #230670
04/01/11 08:34 PM
04/01/11 08:34 PM
Thorneside | QLD | AUS
furr_ball Offline
furr_ball  Offline
Hey,
My son who is 12 sails with me and he is small, was quite a challenge to sort a trap harness.
I made one from my old adjustable sailboard seat style harness with a webbing strap like a seatbelt strap to go up over shoulders. The harness has enough adjustemnt to downsize it to close to his size...only just though... he needs to grow some.
I sewed a loop at the back on the seat harness and run the strap through the loop up over his shoulders down to the hook / bar at the front - if that makes sense.
Have one of those plastic strap click together adjusters to make it tighten up.
The seat harness takes all his weight, the shoulder strap just stops it from falling down.
Maybe this helps and cost me nothing excpet some time.
Cheers, Drew
Drew........Furr_ball........Mosquito 1635
Re: Kids trap harness [Re: David Parker] #230681
04/02/11 09:48 AM
04/02/11 09:48 AM
There's been lots of talk about getting kids out of Optis and into cat sailing. My son hates being just crew/passenger who just sits on deck. Once he's out on the wire he'll sail all day. How can you get kids into cats if you can't find a trap harness and get them on a wire?
I'll try the Dakine windsurfing buckets, maybe an XS women's model. However, the XS requires a short 6" spreader bar that only comes with the weird kitesurfing hook. I could try the old fashioned square-plate hook.
Do any of you have kids that sail or did your old butt bucket ball-buster harness leave you sterile? grin
Worse yet, did you lose your kids to Facebook or the shopping mall? frown
Re: Kids trap harness [Re: David Parker] #230687
04/02/11 02:38 PM
04/02/11 02:38 PM
I bought a kids butt bucket type trap harness several years ago, from Murray's I think. It has the square hook plate in the front where all the straps come together for adjustment. It's small, simple and cheap but it does the trick.
It is a constant struggle to get my teenagers off Facebook and outside, even tougher to get them onto the boat but I'm going to take my 14yr. old daughter (and her boyfriend) out in a few minutes, we've been waiting all day for some wind, which is just now coming in.
Here's what I just found on Rick's online store:
http://store.catsailor.com/pc/viewPrd.asp?idproduct=8403&idcategory=273
Re: Kids trap harness [Re: Timbo] #230699
04/03/11 02:04 AM
04/03/11 02:04 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
I made a harness fit for my 8yo lad by getting a small nappy type harness then taking it to a saddlery shop where they folded up a section of the front and stitched it shorter. It worked perfect then you can unpick the harness if you want later when they grow. I sold that one recently to someone else taking their kids out.
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Kids trap harness [Re: JeffS] #230700
04/03/11 02:22 AM
04/03/11 02:22 AM
3 weeks Newman WA 1 week Robe ...
Brian P Offline
Brian P  Offline
i bought my 10 year old daughter the ronstan XS harness. crutchless with spreader bar. cost me $150. when i let all the straps right out it also fits a mate of mine who is 5'9" weighing 65kg. so they should get long enough out of it.
Brian Partridge
STINGRAY 580 "Fantasia"
A Class 585 "FHARKEN A"
YOU CAN'T POLISH A TURD
BUT YOU CAN ROLL IT IN GLITTER!!!!!
Re: Kids trap harness [Re: Brian P] #230701
04/03/11 03:01 AM
04/03/11 03:01 AM
Brian P Offline
Brian P  Offline
Brian Partridge
Re: Kids trap harness [Re: Brian P] #230774
04/05/11 01:43 PM
04/05/11 01:43 PM
Dunedin, FL
H
Headhunter Offline
Headhunter  Offline
H
Dunedin, FL
Re: Kids trap harness [Re: Headhunter] #230799
04/05/11 09:11 PM
04/05/11 09:11 PM
Thanks, Jon. I see that the Dakine harnesses in extra small require a 6" spreader bar. The only one that small is made by Dakine and has that weird hook the kite guys like. Will that hook work in the small dogbones used on cats? You have a Storm, did you use the Dakine or a Murray bar?
Dakine spreader.jpg (116 downloads)
Re: Kids trap harness [Re: David Parker] #230810
04/06/11 07:45 AM
04/06/11 07:45 AM
Northern Virginia
SoggyCheetoh Offline
Northern Virginia
I've used the Dakine spreader bars and like them. Plus you don't have to worry about the hook going into your hull when your pulling them back on board. (Not that kids ever fall off or anything.)
Alec D.
Pirates of the Chesapeake www.teampiratesofthechesapeake.com
Nacra20 1057 - Crew
F16 Viper 152 - Uni
Re: Kids trap harness [Re: David Parker] #230813
04/06/11 07:58 AM
04/06/11 07:58 AM
catman Offline
catman  Offline
You could have Brian F. make you a spreader bar. I can't see how it's easy to get back on the boat with a hook that sticks out 4-5"s (DAKINE). Julie has the same harness and likes it but with a regular bar.
Re: Kids trap harness [Re: catman] #230818
04/06/11 08:46 AM
04/06/11 08:46 AM
Thanks, everyone, for your comments. The problem with my son is that he has a 24 inch waist. The small men's Dakine is a 28-30 inch waist and the Murray runs big, only comes in medium or large, and costs $184 with bar. There is nothing designed or sized for kids, an admittedly small market segment.
Mike, thank Julie for showing me her Tempest harness. I bought a used Tempest in women's XS that includes the spreader bar and paid only $70. If the hook on the bar does not work on cats I will ask Brian to perform his welding magic to reshape it. Otherwise I will try an old square plate hook.
Cheap extra small used gear
Re: Kids trap harness [Re: David Parker] #230821
04/06/11 10:12 AM
04/06/11 10:12 AM
Dunedin, FL
H
Headhunter Offline
Headhunter  Offline
H
Dunedin, FL
Dave-
Sarah has the same bar pictured and it works great with our setup, but we don't use regular (stainless) dog-bones. I made some out of dyneema and plastic tubing and they work great. You can also nail someone in the noggin and they don't get as pissed. See pic.
[Linked Image] http://i7.photobucket.com/albums/y267/headhinter76/dogbonealt.jpg
Re: Kids trap harness [Re: Headhunter] #230823
04/06/11 10:15 AM
04/06/11 10:15 AM
Dunedin, FL
H
Headhunter Offline
Headhunter  Offline
H
Dunedin, FL
P.S. The Tempest seems to fit larger than the Storm. Julie and I examined both.
Re: Kids trap harness [Re: Headhunter] #230840
04/06/11 01:09 PM
04/06/11 01:09 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Now you know you shouldn't post a pic of your daughter on this forum... Thats just mean!
C
Re: Kids trap harness [Re: Clayton] #230860
04/06/11 06:04 PM
04/06/11 06:04 PM
catman Offline
catman  Offline
LOL, I believe that's his sister.
Jon, how many times has Sarah climbed back on the boat from the water with that harness. You haven't flipped.....yet. smile
Re: Kids trap harness [Re: catman] #230878
04/07/11 08:48 AM
04/07/11 08:48 AM
Dunedin, FL
H
Headhunter Offline
Headhunter  Offline
H
Dunedin, FL
Actually that's Sarah's friend Ashley from Ft. Meade.
And no, Sarah hasn't had the opportunity to attempt climbing back on without damaging the hulls with her massive kite bar. I find the boat sails much faster when not on it's side.
Re: Kids trap harness [Re: Headhunter] #230882
04/07/11 09:18 AM
04/07/11 09:18 AM
M
MN3
MN3
M
Come to think of it, i don't recall seeing Jon capsize his dart either. I guess he never pushes it smile
Man are you over-due
(This almost guarantees i am gonna capsize this weekend ...)
Re: Kids trap harness [Re: ] #230884
04/07/11 10:10 AM
04/07/11 10:10 AM
mikekrantz Offline
mikekrantz  Offline
The Zhik Trap-20 size 0 harness is probably the smallest harness on the market. It's pricey at $269, but will size down to a 20" waist (maybe smaller).
Available from the Catsailor Online store. They show the T-1, but if you order request the T-2.
Re: Kids trap harness [Re: mikekrantz] #230973
04/09/11 10:42 AM
04/09/11 10:42 AM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
I have a picture of my daughter last year when JC was at our Club with the Viper Club, picture is two big although I copied it from another posting here...
http://www.catsailor.com/forums/ubb...p;Words=bella&Search=true#Post215660
She is in my Adult Large Hobie Harness from 10 plus year ago. It is incredible adjustable, fits me from 200 - 220 #'s and her at 60#. It’s not perfect, but a kids desire to be on the wire is stronger than the maybe not perfect fit. I was in APS last fall and found in the discount bin a Magic Marine Adult Small that the kids fight over... it was $55. We can know triple trap…
Chris Allen
Nacra 20 Gertie
www.wrcra.org
0 registered members (), 369 guests, and 37 spiders.
Posts267,060
