Sails on Carbon vs Aluminum Mast #237275
09/07/11 09:21 PM
09/07/11 09:21 PM
PTP Offline OP
PTP  Offline OP
Say the same boat has the same height of mast but one is carbon and the other aluminum. If the sailmaker truly designs one sail to match each mast, how much of a problem would it be to switch the sails?
Guess the question revolves around the extent of the difference of bending characteristics between the two materials and whether the sailmaker actually designs a different sail based on the material of the mast (I actually doubt that this is the case).
Re: Sails on Carbon vs Aluminum Mast [Re: PTP] #237276
09/07/11 09:47 PM
09/07/11 09:47 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
shouldn't you be inroute to MD?
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Sails on Carbon vs Aluminum Mast [Re: Chris9] #237295
09/08/11 10:45 AM
09/08/11 10:45 AM
PTP Offline OP
PTP  Offline OP
Are you confusing me with pgp?
Re: Sails on Carbon vs Aluminum Mast [Re: PTP] #237311
09/08/11 01:57 PM
09/08/11 01:57 PM
or PCP?
Re: Sails on Carbon vs Aluminum Mast [Re: PTP] #237312
09/08/11 02:10 PM
09/08/11 02:10 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
apparently. sorry.
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: Sails on Carbon vs Aluminum Mast [Re: PTP] #237318
09/08/11 02:40 PM
09/08/11 02:40 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Good sailmaker will ask you for pre/bend and bending characteristics, not material. Other point to check is track width, some A-Cat carbon mast have a wide track for plastic tube with increased diameter instead of a rope.
Cheers,
Klaus
Re: Sails on Carbon vs Aluminum Mast [Re: Smiths_Cat] #237327
09/08/11 05:46 PM
09/08/11 05:46 PM
BadLatitude1337 Offline
If you’re talking about the nacra 20 masts. I sail the alum wing we just did sum sail measurements including the mast and the total was just over 48Sq meters this is using the ISAF F16 Rule for sail measurements. The carbon rig and sails were just over 49sq meters.
Open20NA 1337 FOR THE WIN!!!
1 registered members (FredL), 505 guests, and 97 spiders.
