| Re: Newbie cat type info
[Re: Bas]
#23979 09/09/03 05:08 AM 09/09/03 05:08 AM |
Joined: Aug 2002 Posts: 164 The Netherlands (North West Eu... RobLammerts
Posts: 164 The Netherlands (North West Eu... | Hi Bas, You could also take a look at the Nacra 5.7 or 570. This is a good ship without swords which makes landing on the beach more easy. You can sail it alone and wit a crew, and has more distance between the water and the trampoline than the Dart 18. You can also vist Jan de Boer Catamarans for a honest advise, ask for Bas. you can find them @ www.jandeboer.comOr vistit the next big cat event at Hellecat (hellevoetsluis) www.hellecat.nlI am sure people there will give you all the advise you need. Good luck
Rob
Nacra 6.0 European version
Nr 090 + Spi
[Re: Bas]
#23980 09/24/03 10:04 PM 09/24/03 10:04 PM |
Joined: Apr 2003 Posts: 12 SW Florida, USA Andrew2003
Posts: 12 SW Florida, USA | [color:"blue"] [/color] Though I have not experienced it, I have heard much about the tendency of a Hobie 16 to pitchpole. Based on firsthand knowledge, the Prindle 16 sails like a dream, practically steers itself, hugs the water and is very stable, though it's not the easiest cat to tack, nor is it very easy to sail alone, because each rudder has to be lowered individually. Used models are inexpensive in the US. A Hobie Wave is an even better starter cat, though not as fast as a Prindle 16, but is very stable, and easy to handle, the crossbar will lower both rudders, and there is no boom to duck. It seems to plow through the water a little instead of squatting into it and slicing through it like the Prinde does, but one person can operate it easily. Used models would be more expensive than the Prindle. Good luck with your search. | | |
824
guests, and 44
