| Re: Seperation Irritation at Steeplechase
[Re: PeteCullum]
#241534 12/17/11 08:36 AM 12/17/11 08:36 AM |
Posts: 71 South Florida | You can by a safety sausage at any local dive shop, and I believe that some west marine locations carry them.
Joe
After all, its not easy, banging your head against some mad buggers wall.
[Re: PeteCullum]
#241584 12/19/11 12:21 AM 12/19/11 12:21 AM |
Posts: 805 Gainesville, FL 32607 USA | About 50 cats got turned over in the big Mt. Dora spring race back in the day. The start was scary downwind blowing over 25, then it got way heavier! My Hobie 18 didn't just capsize after the first mark while missing others, it got flung upside down, and the mast stuck in the mud. It took us 20 minutes on one hull then the other trying to get it loose. On the way back in, the same thing happened again, and it took a powerboat to get the mast out. Nobody got hurt AFAIK. Yup- cast iron.
[Re: dacarls]
#241714 12/20/11 10:32 AM 12/20/11 10:32 AM |
Posts: 5,590 Naples, FL | if it's blowing hard enough that you need a drogue to slow the boat down, it is likely you can right it singlehanded once it's pointed into the wind (by the drougue) and the main sheds some water.
Happened on my N20 in 18+ kts of breeze and medium chop (Florida Bay side). Didn't have drogue but I swam the bows enough to the wind that my crew (175#) could right the boat by himself. Once the wind got under the main and the water ran off, it was relatively straightforward to pull it upright. But it may have just been a good day, too...
[Re: PeteCullum]
#241716 12/20/11 10:48 AM 12/20/11 10:48 AM |
Posts: 297 | Pete,
Glad it worked out for the best...My worst case scenario is a squall, and I wanted to get a sea anchor before my last distance event. I was once sailing a N5.5 near home in a squall with 60 mph straight line wind , lightening, hail the works... solo. The ferocity of the wind and my point of sail left me no choice but to bear dead downwind to avoid the death zone and an assured capsize and whatever was to follow. While it was not to be the end of the world, it was pretty spooky, as riding it out was taking me onto a reef/island at extreme velocity, when, just as I was about to scuttle, as fast as it started, it was dead calm. (then it took me 2 h to sail about 1 mile). Where did you get your sea anchor, and what length line do you have attached to it?
One thought I would like to hear more about is helm. Most performance boats are pretty helm neutral and if they are righted, I figure they will pretty much sail away on their own. It has never happened to me. Any thoughts from the peanut gallery on this topic?
As for the diver marker...do those self-inflate?
+1 on the underneath grab line. A must have...
Nacra F18 #856
[Re: PeteCullum]
#241747 12/20/11 10:28 PM 12/20/11 10:28 PM |
Posts: 713 WA, ID, MT | Pete, Cabellla's has what they call drift socks, for fishermen, at reasonable prices.
Dave
[Re: Team_Cat_Fever]
#241826 12/23/11 06:24 PM 12/23/11 06:24 PM |
Joined: Jun 2001 Posts: 733 Home is where the harness is..... Will_R
Posts: 733 Home is where the harness is..... | None of you are considering tethering yourselves to the boat? All of this has been gone over dozens of times here. Boat flips, tether tangles, you drown. Not to mention the tether inhibits your mobility enough to increase the probablility of flipping . +1 on this. Also, ask Randy why he wears inflatable suspenders instead of a vest. I was NEARLY separated going around Hatteras b/c I was shoved under water by the skipper of the boat I was on. It was a typical slow round up and capsize spinnaker flip. I had my escape route and was executing it, but suddenly he jumped on my back as I was lowering to the water. His weight forced me deep enough that I ended up going under the hull. I popped up ~2-3' from the bottom of the boat and started swimming like crazy. You add VHF, EPIRB, camel back, GPSs and the rest of the typical distance racing gear we wear along with a dry suit, a danforth as nothing on us at that point.... (get it anchor?) With the sand bars at the Cape, I'd go from swimming to running back to swimming very quickly. The breeze and current were offshore and luckily I was able to grab the TOP batten on the main as the mast pivoted by. I vowed that the only way I was letting go was if that batten broke off in my hand. Had I not held on, I was head to England w/o my passport, lol. The point I wanted to make is that when sailing with skippers that I trust and especially the one I spend most of my on the water time with, we always have a plan/system. I'm usually the larger of the two and therefore am also the last person on the boat. As such, the skipper plans to roll himself up onto the boat as it rights while I always plan to have a solid hold somewhere and jump on as soon as he’s out of the way. This gives us a man on deck to steer if I can't hold on. Knock on wood, to date that has never happened and I've been upside down in some gnarly stuff on very light boats. Which brings me to my last point which we were discussing a couple of weeks ago. Trust your partner and make sure that they're competent. I learned my lesson with the Worrell and never would I sail with that particular person EVER again OR do a race like that w/o someone that I would trust with my life! I know that my skipper can get us out of almost any jam and he knows that I can do that same. Among other things, we can both run the boat single handed and are both big enough to pull the other on board. We planned to do the Cuba race and that level of trust is a HUGE comfort to me. In short, communication is key and IMO being prepared for all hell to break loose is part of that discussion. You can't prevent bad luck, but you can make good luck happen sometimes. I think the orange buoy and small drogue are both good ideas if they're small enough to not cause a problem on their own. Also, at one point Garmin Rhino’s were getting popular b/c they were radios with GPS that could send locations between the two, something else to consider. | | |
1 registered members (soulofasailor),
1,861
guests, and 23
