| Tuning specs for Hobie 18? #243334 02/01/12 02:19 AM 02/01/12 02:19 AM |
Joined: May 2006 Posts: 1,383 Kingston SE South Australia JeffS OP
Posts: 1,383 Kingston SE South Australia | G'day we've got a couple of Hobie 18's on our coast at another club the sailors have never known how to set the boat's up. When I visited last week one had soft and one had hard diamond wires could someone give me simple specs on mast rake, rig tightness etc. I'd like to get them more competative and perhaps get them sailing more
| | | Re: Tuning specs for Hobie 18?
[Re: rehmbo]
#243345 02/01/12 07:49 AM 02/01/12 07:49 AM |
Posts: 12,310 South Carolina | Check here: http://www.hobieclass.com/site/hobie/ihca/downloads/hobieu/HobieU.pdfThis should get you in the ballpark. There is also a section for the TheMightyHobie18 in the back of Rick White's book "Catamaran Sailing for the 90's" Soft diamonds allow the mast to bend, depowering the main - good for high wind. Hard diamonds do just the opposite - good for light air. That depends on whether or not you have raked spreaders or the straight spreaders. Hobie had both varieties depending on the age of the boat.
Jake Kohl | | | Re: Tuning specs for Hobie 18?
[Re: JeffS]
#243362 02/01/12 12:22 PM 02/01/12 12:22 PM |
Posts: 330 | There is only one style of spreaders for a Hobie 18 - they have minimal rake adjustment determined by positioning a pin in one of the spreader arms. Virtually all racers run with the spreaders raked as far back as possible (there are only like two or three possible settings).
As far as diamond wire tension, if you have a comptip, you want to run the diamond wires snug to tight (sorry, don't have a quantative number). 18's are pretty underpowerd boats by today's standards and the comptip is quite flexible, so you want to stiffen the lower part of the mast as much as possible to keep some power down low.
Shrouds should be snug enough that the mast doesn't flop around, but loose enough that you can rotate the mast to 90 degrees easily.
I've been racing these boats for about 20 years and I don't find them to be overly sensitive to tuning. I rig mine the same way every time regardless of wind conditions. Your main tools are mainsheet, traveller, and downhaul. Make sure they work efficiently and you're in good shape. Having a good set of rudders and a balanced helm is also critical.
sm
[Re: JeffS]
#243382 02/01/12 06:03 PM 02/01/12 06:03 PM |
Posts: 1,383 Kingston SE South Australia | Thanks for the info, both are old boats, I can lend them Ricks book for a while not sure if they are keen enough to read it though. The mast section looks like my Nacra 5.8 mast without a comp tip, at least now I can take this info and tune the boats a bit for them. Would you know how soft is soft on the diamond wires for instance on the Nacra if you push on the diamond wires you can nearly touch the mast 18 inches from the base in heavy weather? If I tied a rope to the end of the trap and measured to the bridal tang where would the rope be at the rear hatch for proper rake?
[Re: JeffS]
#243399 02/02/12 07:58 AM 02/02/12 07:58 AM |
Posts: 330 | As I said, I've found the 18 to work with a pretty wide range of tuning. There really aren't any hard and fast numbers. For diamond wire tension, the traditional method for measuring tension was to place marks at 12, 24, & 36 inches up from the diamond wire bolt. The tension is determined by where the wires touch the mast with moderate inward pressure. So between the 12 to 24 inch marks would be tight to moderate tension. I don't recall seeing anyone with loose/floppy diamond wires in recent years. Everyone has them at least snug, even the ligt guys.
For mast rake, again I don't know numbers as I haven't measured a boat in many years. I have non-low profile mainsheet blocks (i.e. the bottom block is a triple on top of the ratchet) and in a strong breeze there is about 2 to 3 inches between the lower mainsheet block and the block on the boom. That's more or less how I measure my rake. It's about as far back as possible without the possibility of going two-blocked. After that, its a matter of having the helm dialed in to a slight weather helm and once I achieve that, I don't want to screw with any adjustments.
sm
[Re: JeffS]
#243421 02/02/12 02:31 PM 02/02/12 02:31 PM |
Posts: 1,383 Kingston SE South Australia | Thats the info I'm after guys, I'm race officer at our regatta for the next 2 days and I wont have much time to set these boats up so now I can use these quick measurements to get them started
376
guests, and 148
