Soft Shackles. #244065
02/15/12 03:20 PM
02/15/12 03:20 PM
california
F-18 5150 Offline OP
california
Is there anywhere to buy soft shackles for the spin? I'm sick of tying knots to attach the spin. My splicing ability sucks. Where can I buy them.
Rich
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Soft Shackles. [Re: F-18 5150] #244068
02/15/12 04:04 PM
02/15/12 04:04 PM
Asuncion, Paraguay
Luiz Offline
Luiz  Offline
Asuncion, Paraguay
Colligo Marine. Talk to John Franta
Luiz
Re: Soft Shackles. [Re: F-18 5150] #244073
02/15/12 05:50 PM
02/15/12 05:50 PM
Made my first one this weekend - easy.
Re: Soft Shackles. [Re: F-18 5150] #244075
02/15/12 07:43 PM
02/15/12 07:43 PM
JW, that looks just about the right size...for the neck of that beer bottle! Is that whay you use to drag them over the side, to keep them cool?
Re: Soft Shackles. [Re: F-18 5150] #244079
02/15/12 10:23 PM
02/15/12 10:23 PM
Hillsborough, NC USA
I
Isotope235 Offline
Isotope235  Offline
I
Re: Soft Shackles. [Re: F-18 5150] #244089
02/16/12 12:42 AM
02/16/12 12:42 AM
california
california
Cool thanks those look perfect.
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Soft Shackles. [Re: F-18 5150] #244133
02/16/12 02:18 PM
02/16/12 02:18 PM
Israel, Sdot Yam
Opher Offline
Opher  Offline
Israel, Sdot Yam
Colligo have a great video on making soft shackles on their home page. 40 cm 3 mm dyneema, a small fid and a spare hour will make you an expert cool
Opher
Nacra F20C ISR1
F18 Cirrus ISR2
Sdot Yam, ISRAEL
Re: Soft Shackles. [Re: F-18 5150] #244163
02/16/12 05:31 PM
02/16/12 05:31 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
Easy shackles are better for halyards
Re: Soft Shackles. [Re: F-18 5150] #244177
02/16/12 07:52 PM
02/16/12 07:52 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
What do you mean by easy shackles? I too am looking for another solution over knots. My spin haylard gets so tight its a quite a feat to get the bowline apart.
Re: Soft Shackles. [Re: F-18 5150] #244231
02/17/12 11:23 AM
02/17/12 11:23 AM
BadLatitude1337 Offline
Open20NA 1337 FOR THE WIN!!!
Re: Soft Shackles. [Re: bacho] #244233
02/17/12 11:28 AM
02/17/12 11:28 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
Easy Shackles and spool shackles work the same way. They are metal barrels in which a loop of line goes through the middle and locks around them on each side.
Re: Soft Shackles. [Re: Dan_Delave] #244242
02/17/12 12:44 PM
02/17/12 12:44 PM
M
MN3
MN3
M
[Linked Image] Pretty cool - http://www.mauriprosailing.com/Tylaska/Tylaska-spool-shackle.htm
do you think even with the o-ring (second lock) this could come free on the spin clew?
Re: Soft Shackles. [Re: Luiz] #244248
02/17/12 01:07 PM
02/17/12 01:07 PM
Will_R Offline
Will_R  Offline
Won't spend another dime with them EVER again.....
Re: Soft Shackles. [Re: Will_R] #244264
02/17/12 03:18 PM
02/17/12 03:18 PM
Re: Soft Shackles. [Re: F-18 5150] #244285
02/17/12 11:30 PM
02/17/12 11:30 PM
california
california
I went with Vela. Ordered them just before Bad Lattitude posted.
Rod Favela
Vela Sailing Supply
Beyond a sailing store!
Toll free: 877-240-VELA (8352)
Int. calls: 001-214-960-4434
Skype: velasailingsupply
http://www.velasailingsupply.com/
Richard Vilvens
Brand Ambassador
PSA Capricorn USA
[email protected]
Fairfield, Ca
F-18 5150
Re: Soft Shackles. [Re: Opher] #244306
02/18/12 03:09 PM
02/18/12 03:09 PM
I
Isotope235 Offline
Isotope235  Offline
I
I make my soft shackles a little differently than Colligo. For one thing, I put a locking brummel in the sliding eye before tying the terminal knot. Colligo (at least in their instructional video) doesn't. Without the brummel, the knot will tend to pull out. That's why they have long leads between the knot and the exit (and why they suggest leaving the ends long when making the shackle yourself).
Secondly, Colligo (and most others) tie a knife lanyard knot (a.k.a. diamond knot) in the end. I prefer to make an 8-part button knot. Both are symmetric and appropriately sized, but I feel the button knot is prettier and more secure.
Colligo puts o-rings on the shackle to make it easier to milk closed. I don't. I looked into that, but customers told me that the o-rings tend to get pinched and break off anyway. So, I don't bother.
Both styles generally work and the differences are mostly cosmetic, but I think the locking brummel is a real advantage. Mine are less expensive too smile.
I hope that helps,
Eric
Re: Soft Shackles. [Re: Isotope235] #244307
02/18/12 03:47 PM
02/18/12 03:47 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
I hope that helps,
Eric
Can you post a close-up pic of one of yours?
Isak Dinesen
E. B. White
Re: Soft Shackles. [Re: Isotope235] #244312
02/18/12 07:18 PM
02/18/12 07:18 PM
JJ_ Offline
JJ_  Offline
Re: Soft Shackles. [Re: F-18 5150] #244313
02/18/12 08:57 PM
02/18/12 08:57 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
Nice JJ! Thanks for sharing that.
Re: Soft Shackles. [Re: Team_Cat_Fever] #244316
02/19/12 09:17 AM
02/19/12 09:17 AM
I
Isotope235 Offline
Isotope235  Offline
I
Here are a couple of pics. If you look at the photo of the open shackle, where the line exits the terminal knot, you can see part of the locking brummel. In the photo of the closed shackle, I've turned the knot up so you can see that it's a button knot -- not a lanyard knot.
Eric
0 registered members (), 1,496 guests, and 28 spiders.
