| Retrieving spinnaker into snuffer - where's 2d kno #24476 09/22/03 08:16 PM 09/22/03 08:16 PM |
Posts: 28 Florida | Spent this past weekend sailing in pretty good winds, but discovered a new problem that I never had before. I have completely redone the Taipan's front rigging, and the snuffer lines. Before, I never seemed to have any problem "snuffing" the spinnaker, even in good winds (15-20), except for occasionaly "running" over the sheets in big swells. This weekend I had trouble putting it away every time in fairly flat seas. I put the second knot about 20" down from the primary tie point in the spinnaker. I always did this to avoid the spinnaker becoming bunched as it approached the snuffer mouth. This weekend, the bottom seemed to blow out each time and I was left with spinnaker half in and half out of the chute bag. I tried moving the knot up to about 12" and back to about 36", but the 18-20" range seemed about right. I turned dead downwind as I retrieved, but struggled every time.
I can see how the mid mount snuffer (skunk) could alleviate this problem, but I'm trying to stay with the original one I put together.
Any suggestions? Anyone else have this problem? Maybe I was flying it in too much wind? It was gusty, but the seas were only 2-3 feet.
But, hey! What a ride!
Jon Hamlet Taipan #217 casey Key Island, Florida | | | Re: Retrieving spinnaker into snuffer - where's 2d kno
[Re: Jon Hamlet]
#24477 09/22/03 09:36 PM 09/22/03 09:36 PM |
Joined: May 2002 Posts: 1,037 Central California ejpoulsen
Posts: 1,037 Central California | If I understood Goodall correctly, he told me that they encountered snuffer problems similar to what you're describing until they added a third hole/patch right at the bottom (centered) of the spinnaker. This guides the initial "wad" in. I don't know if this would be relevant with your system, though, since it is an end-pole snuffer. A photo can be seen at this web site: http://www.taipan.asn.au/Look under Photos at the Kurnell F16 section--the photo with two blue spinnakers clearly shows the 3 patches. I'm curious to hear from others about knotting the retrieval line--do most people do this, and if so, at what point above the hole/patches?
436
guests, and 37
