| Re: Simply awesome for sailors
[Re: ThunderMuffin]
#246449 03/29/12 10:07 AM 03/29/12 10:07 AM |
Posts: 12,310 South Carolina | that's f'in cool. I presume those are surface winds? (it appears to be).
Jake Kohl | | | Re: Simply awesome for sailors
[Re: ThunderMuffin]
#246452 03/29/12 10:32 AM 03/29/12 10:32 AM |
Posts: 2,490 On the Water | I'm diggin' it. This would make an excellent wallpaper or screen saver.
Philip USA #1006 | | | Re: Simply awesome for sailors
[Re: P.M.]
#246453 03/29/12 10:34 AM 03/29/12 10:34 AM |
Joined: Jan 2008 Posts: 3,655 Portland, Maine ThunderMuffin OP
Posts: 3,655 Portland, Maine | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. | | | Re: Simply awesome for sailors
[Re: ThunderMuffin]
#246457 03/29/12 10:50 AM 03/29/12 10:50 AM |
Posts: 2,490 On the Water | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. For those who have not yet discovered, the page has a zoom feature showing coordinates and location specific wind speed. Tad, how often does the page refresh (ever hour?)
[Re: ThunderMuffin]
#246458 03/29/12 10:53 AM 03/29/12 10:53 AM | MN3
| MN3
Unregistered | very cool find, thanks Tad | | | Re: Simply awesome for sailors
[Re: ThunderMuffin]
#246462 03/29/12 11:34 AM 03/29/12 11:34 AM |
Posts: 3,224 Roanoke Island ,N.C. | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. Your a droid man right? How do you do this?
[Re: Team_Cat_Fever]
#246464 03/29/12 11:48 AM 03/29/12 11:48 AM |
Posts: 3,655 Portland, Maine | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. Your a droid man right? How do you do this? Do you have a galaxy nexus or are you running a custom ICS rom? If not then you can't until your phone is updated to Android 4.0 I actually had to turn it off because it was sucking down juice and hindering performance unless I killed all the widgets on my homescreens.
[Re: ThunderMuffin]
#246465 03/29/12 12:00 PM 03/29/12 12:00 PM |
Posts: 2,584 +31NL | Not sure how often it refreshes.
"These are 1-hour forecasts, downloaded once per hour. So what you're seeing is close to live data." It loads painfully slow on my iPhone 4, would make great iPad app though. | | | Re: Simply awesome for sailors
[Re: ThunderMuffin]
#246466 03/29/12 12:14 PM 03/29/12 12:14 PM |
Posts: 3,224 Roanoke Island ,N.C. | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. Your a droid man right? How do you do this? Do you have a galaxy nexus or are you running a custom ICS rom? If not then you can't until your phone is updated to Android 4.0 I actually had to turn it off because it was sucking down juice and hindering performance unless I killed all the widgets on my homescreens. UUUHHHH...Yeah. None of that stuff. I just hit upgrade when my dROID x tells me to. I def. don't need anymore of a battery drain, but Thanks for 'splainin'.
[Re: ThunderMuffin]
#246570 03/30/12 11:40 PM 03/30/12 11:40 PM |
Joined: Aug 2010 Posts: 50 Bay Area, California, US Nacra5.8NA1386
Posts: 50 Bay Area, California, US | I'm diggin' it. This would make an excellent wallpaper or screen saver. I've already turned it into my live wall paper on my phone. Your a droid man right? How do you do this? Do you have a galaxy nexus or are you running a custom ICS rom? If not then you can't until your phone is updated to Android 4.0 I actually had to turn it off because it was sucking down juice and hindering performance unless I killed all the widgets on my homescreens. Actually, I just flashed a custom ICS rom last night... How did you do it? Thanks for the info, even if it doesn't work out it would be cool to try.
Nacra 5.8NA "Royal Flush" | | | Re: Simply awesome for sailors
#246583 03/31/12 11:41 AM 03/31/12 11:41 AM |
Posts: 4,119 Northfield Mn | UUUHHHH...Yeah. None of that stuff. I just hit upgrade when my dROID x tells me to. I def. don't need anymore of a battery drain, but Thanks for 'splainin'. +1 If my EVO doesn't have good service, the battery is gone in no time. Little pecker should have a built in generator and a crank to get power back into it.
1,088
guests, and 25
