Gin-pole #248987
05/29/12 01:36 PM
05/29/12 01:36 PM
Bille Offline OP
Bille  Offline OP
Anyone know the length for a Gin-pole on a Hobie 21SE ?
Almost done building the molds for my center-board's, (mine were toast).
Had to take the best one and mod it so it would fit both hulls ;Both stuck
down about 1/4 to 3/8", even when pressed firmly up by the LE, so it wasn't just
a stretched retracting cord tuning needed.
When finished i'll be ready to check & see if anything needs repairing on the
stays, and try stepping the mast for the first time.
I didn't get a gin-pole with my cat, could someone tell me it's length ?
I'll need to build one of those also.
Bille
Re: Gin-pole [Re: Bille] #248995
05/29/12 07:00 PM
05/29/12 07:00 PM
South Florida & the Keys
arbo06 Offline
arbo06  Offline
I built a really nice one for my ARC 21. It is probably over built but it works like a charm. I'll get a few pics and measurementts fot you.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Gin-pole [Re: arbo06] #249020
05/30/12 11:39 AM
05/30/12 11:39 AM
Bille Offline OP
Bille  Offline OP
Originally Posted by arbo06
... It is probably over built ...
Over built is probably Better !!!
Thanks for your time : Bille
Now back to work on the Center-board mold.
Re: Gin-pole [Re: Bille] #249023
05/30/12 12:34 PM
05/30/12 12:34 PM
catman Offline
catman  Offline
Measure from the mast base to where the furler would be when the boat is rigged.
Re: Gin-pole [Re: Bille] #249032
05/30/12 03:27 PM
05/30/12 03:27 PM
uk
TEAMVMG Offline
TEAMVMG  Offline
uk
yes, the distance from mast base to forestay
Re: Gin-pole [Re: Bille] #249067
05/31/12 05:39 PM
05/31/12 05:39 PM
Bille Offline OP
Bille  Offline OP
And if i make it the distance Ya described, and as
strong as the boom on the SE ; will that be strong
enough ?
Bille
Re: Gin-pole [Re: Bille] #249068
05/31/12 06:46 PM
05/31/12 06:46 PM
arbo06 Offline
arbo06  Offline
give me yer email address and I'll send you the pics that I just took on my phone.
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Gin-pole [Re: arbo06] #249069
05/31/12 06:47 PM
05/31/12 06:47 PM
arbo06 Offline
arbo06  Offline
lenth of the pole is 90".
Eric Arbogast
ARC 2101
Miami Yacht Club
Re: Gin-pole [Re: Bille] #249071
05/31/12 10:34 PM
05/31/12 10:34 PM
Bille Offline OP
Bille  Offline OP
Thanks for taking the time to do that !!
Bille
Re: Gin-pole [Re: Bille] #249087
06/02/12 06:52 AM
06/02/12 06:52 AM
catman Offline
catman  Offline
You can use a 2 by 6 pt board to make it. Notch the one end so it fits the mast. Drill a couple holes so you can tie it to the mast. With a table saw you can taper the board slightly towards the tip to lighten it a bit. Cheap, simple and strong.
Re: Gin-pole [Re: arbo06] #249098
06/02/12 01:06 PM
06/02/12 01:06 PM
Bille Offline OP
Bille  Offline OP
Did you get my Pm : ?
Bille
0 registered members (), 380 guests, and 98 spiders.
