how to make a side-load system for Nacra 5.2 dagger? #249632
06/15/12 12:41 AM
06/15/12 12:41 AM
Canyon Lake, Texas
C
Canyon Doug Offline OP
C
Canyon Lake, Texas
Grew up on Hobie 16's and 18's on the beach... Now on a lake in Texas instead of Ft. Lauderdale... Resurrected a Nacra 5.2 and want the side-load system. Anyone have a good recommendation on making them? Looking forward to running this bad-boy... ALways heard they were wickedly fast. Many thanks!
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249633
06/15/12 02:15 AM
06/15/12 02:15 AM
Y
yurdle Offline
yurdle  Offline
Y
Took me a few tries before they were uniform. (the two on the right end were totally different and spent 3 years in the sun before getting the heat shrink)
PVC w/ caps drilled on center, wrap in 1/4" cork, then heat shrink over that. Not the same as the neoprene originals, but looks as good and just as functional.
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249635
06/15/12 05:19 AM
06/15/12 05:19 AM
pgp Offline
pgp  Offline
What does it do?
Pete Pollard
Blade 702
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249650
06/15/12 07:38 AM
06/15/12 07:38 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Assuming your intent is to hold the daggers in an intermediate position. Any reason the little squeegees like used on the Tiger wouldn't work?
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249651
06/15/12 08:42 AM
06/15/12 08:42 AM
japan
erice Offline
erice  Offline
japan
correctly sized bits of carpet at the top and bottom of the dagger well also important
just a side-loader bungee isn't usually enough
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: rehmbo] #249655
06/15/12 09:09 AM
06/15/12 09:09 AM
take some PVC pipe a little longer than the daggerboard is wide. Cover it with pipe insulation. Run a bunji through the PVC and tie each end of the bunji back to the trampoline / deck area (my 5.2 trampoline had grommets for the bunji - I think my 6.0 had eye straps on the inner edge of the deck (or maybe it was viceversa). You put the PVC on the outboard side of the board so it pulls the board inward toward the trampoline and keeps it at whatever position you put it. Most reliable system I've ever had!
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249693
06/16/12 07:29 AM
06/16/12 07:29 AM
Canyon Lake, Texas
C
C
Canyon Lake, Texas
Thanks very much for everyone's help! Will get busy! - Doug
Re: how to make a side-load system for Nacra 5.2 dagger? [Re: Canyon Doug] #249748
06/18/12 09:53 AM
06/18/12 09:53 AM
M
MN3
MN3
M
please post some pics and results smile
thanks
0 registered members (), 1,031 guests, and 41 spiders.
