| Re: ARC 17 Ultimate boardless beach cat...
[Re: Seeker]
#25755 11/05/03 02:47 PM 11/05/03 02:47 PM |
Posts: 12,310 South Carolina | WOW.  a 17' boat with 257 sq feet of sail? Upwind? My 6.0NA has a reputation for being seriously overpowered monster and it's 3 feet longer and has a measly 264 sqft of area (only 7 more!). the link to the website is here: http://www.aquarius-sail.com/
Jake Kohl | | | Did Bill Roberts invent...
#25756 11/05/03 02:55 PM 11/05/03 02:55 PM |
Posts: 1,253 Columbia South Carolina, USA | Did I dream this, or did someone tell me that Bill designed the first snuffer system?(sorry if thats a name brand product infringement thing) dave mosley www.seacats.orgbtw we are proposing to have a second annual supercat 20 Nationals, and would like to include the whole line of SC's and ARC's. I understand there was some talk of a national event to be held next year in Pensacola, is this right, and if so, would you consider letting the SEACATS run your event here in Columbia SC May 15-16th 2004?
| | | Re: and you can see Bill's patent online following...
[Re: Luiz]
#25760 11/05/03 09:33 PM 11/05/03 09:33 PM |
Posts: 1,253 Columbia South Carolina, USA | I find it incredible that this system was not widely used for all these years. I have seen versions of it for awhile, but not until the I20 did I really see it used on cats. Maybe others were using it, but that is the most prominant example that seemed to jumpstart it. I hope Bill's making a killing off of it, I know I sure love mine. I have sailed the Viper(20' monohull with open stern) and it has a molded in version, and I think the Laser 2 is doing something similar too. Thanks Bill, David Mosley
[Re: Seeker]
#25761 11/05/03 11:17 PM 11/05/03 11:17 PM |
Posts: 118 St. Louis, MO | Anybody have a clue what this boat has for a Portsmouth number?
JL
N20 # 1041 "Lucille"
A-cat USA 44
[Re: dave mosley]
#25762 11/06/03 08:20 AM 11/06/03 08:20 AM |
Posts: 1,307 Asuncion, Paraguay | I find it incredible that this system was not widely used for all these years This fact is a proof of how conservative the worldwide sailing comunity is - even the most competitive ones. Multihullers have a reputation of being more open minded. But I remember lots of IOR boats in the 70s using this system, with a big tube inside the cabin. After some time the system was abandoned. Maybe it is not so efficient for bigger spinakers, but the truth is I don't know the actual reason. I was too young...  Anyway, even the best engineering takes some time to replace traditional methods. When refrigerators were invented, it took a long time and extensive advertising for people to start buying. Sounds like a joke today, but it's true. One reason why sailing evolves so slowly, is the small size of sailing related industires. Big industries and corporations are faster then individuals with regards to (profitable) inovations. Mass production turns small unit profits into interesting results. Keeping with the refrigerators, Lokheed's representative in Brazil once told me the following story when he rented my apartment there: A company (there) started to mold the foam insulation instead of just jam pieces of foam between the internal and external walls of the refrigerators, as was customary at that time. The insulation of the molded foam is far better then that of pieces of foam, so the insulation could be thiner and still more efficient. Then, a smaller engine could be used (cheaper and less power consumption) and the internal volume grew (more groceries inside a refrigerator that looks the same in the outside). This inovation found its way into every industy in the world and also helped that Brazilian industry a lot - they owe some very popular international brands today. Comercial planes also copied the same idea (to keep the heat inside) and that explains why the guy from Lokheed knew the story. We need more people sailing and greater production volumes. Then, improvements will be introduced yearly, like in cars. Cheers,
Luiz
[Re: JoeLeonard]
#25763 11/06/03 09:52 AM 11/06/03 09:52 AM |
Posts: 9,582 North-West Europe | >>>Anybody have a clue what this boat has for a Portsmouth number?
It provisional Texel number = 100 with spi and 104 without (I have not taken into account the oversized spi as that will drop the handicap number but it remains to be seen wether the craft is really faster with such a large spi)
This leads to some "conservative DPN" to be expected at 65 (spi) and 67,5 ( no spi) under PN.
I used 8 kg's for the weight of the mainsail, battens and jib together and added that to the 136 to give 144 kg's overall no spi = 318 lbs. My smaller Pentex sails together are this weight and so this should be a good comparison. Weight of spi package has NOT been included in this. With it the ready to sail weight of the spi version will be 144 + 5 kg = 149 kg's = 329 lbs. Pretty standard for a 5.18 mtr. = 17 ft long 2,59 = 8'6" wide platform with an 8,76 mast. Fully fitted Hobie FX-one and Inter-17 are on either side of it within a few kg's (lbs).
Its jib is quite normal in size 4,74 sq. mtr. = 51 sq. ft. The remainder of those 257 sq. ft. = shy 24 sq. mtr. is all to be found in the mainsail and mast. WOW ! just 3 sq.ft less than the US I-20 main.
measure of aspect ratio of the mainsail = luff^2 / area = estimate 8.5^2/19,1 = 3.78 (other definitions are used as well but this is a good approximation)
Compare this to some other types :
A-cat = 8,8^2 / 13,95 = 5,55 US I-20 = 9^2 / 19,4 = 4,18 F18 = 8,5^2 / 17 = 4,25 F16 = 8^2 / 15 = 4,27 Prindle 16 = 7.37^ / 13,82 = 3,93 Hobie 16 = 7,33^2 / 15,21 = 3,53 Nacra 5.0 = 7,65 / 13.50 = 4,335
Bill, how does aspect ratio impact on being overpowered exactly ? You have me at a loss here.
Spinnaker area 27 sq. mtr. I-20's is 25 sq. mtr. Boats of comparable length and mastheight have typically 17-20 sq. mtr.
Aspect ratio spi :
ARC 17 = draw^2/area = 8^2(max !)/27 = 2,37 (probable 7,6^2/27 = 2.14) I-20 = 8,3^2 / 25 = 2.75 F18 = 8,25^2 / 21 = 3.24 F16 = 7,5^2 / 17,5 = 3.21 ISAF youth trail boats = about 7^2/ 15 : 7,2^2 / 17 = 3.26 - 3.05 NA NE Nacra 6.0 with 250 sq.ft. spi = 8,5^2/32.5 = 2.22 Mosquito 17 = 6,38^2/16,9 = 2,41 Mosquito 15 = 6,38^2/14.2 = 2,87
Mosquito 15 was found to be faster in most conditions than the Mosquito 17 both in Aus as in South Africa. We all know how the NA NE N6.0 spi performs with respect to that much smaller I-20 spi.
More than a few sailors have noticed that smaller spis of higher aspect ratio are quicker than larger spis with lower aspect rations; in most conditions except a small wind range between light and medium winds. When the winds are light than the large area spi limps before the smaller spi does so; therefor the smaller spi is more efficient again in light winds.
For this reason I did not hit the ARC 17 with the kind of several Texel penalty for oversized spis. Remember the Tybee 500 where the NA NE had to give the US I-20 time on Texel handicap but where they were found to be about of comparable speeds.
The jib is pretty normal is aspect ratio and comparable to those of the newer boats with spi kits.
With this I think the estimates of the PN given are dependable; the old sc17 was DPN = 73. Quite an improvement.
[Re: BRoberts]
#25769 11/07/03 10:27 AM 11/07/03 10:27 AM |
Posts: 552 | Bill, Wouter, Bob and All,
What a great time for innovation in singlehanded racing cats!
Reading this line of 'sailing minds' is very valuable,...especially the last post by Bill about the 'bow volume under spinnaker load' design.
...it was a good read!
..here is an idea,...make a 'Uni-rig open' portion of a large regatta,...allow the participants to sail other manufactures' design(, for example, Fx-1, T 4.9, N5.5, I-17, SC17, A-cat..etc)...kinda like a round robin, except on different boats,...the 'winner' would be a composite of 'all' types sailed.......since all these designs have their differences, sailpersonship would be the test..
....is that an idea,..or a dream...?
..congrats to your new 17 Bill,....where can we demo this???
regards,
Bruce St. Croix | | |
1 registered members (FredL),
505
guests, and 97
