| Rules #258020 03/04/13 07:45 AM 03/04/13 07:45 AM |
Posts: 5,525 | Making the rounds of the innerwebs this morning, it looks like there are more and more foils and T-rudders. Maybe it's time...
Pete Pollard Blade 702
| | | Re: Rules
[Re: pgp]
#258024 03/04/13 09:52 AM 03/04/13 09:52 AM |
Posts: 4,451 West coast of Norway | T-foils are allowed as long as max width is not exceeded. Not much you can do in the main foils dept. though. I dont know what the growth in the class looks like? I would think we want to wait a bit longer before going that route. I agree that it looks like foils might be a viable options in a not to distant future. Still remains to be seen if they will be faster around the course Let the C-class guys go through a few more iterations on the topic.. | | | Re: Rules
[Re: pgp]
#258025 03/04/13 10:05 AM 03/04/13 10:05 AM |
Posts: 5,525 | Well, since dagger boards aren't required, why can't you use most any type of foil, as long as it doesn't have to fit through a dagger board trunk?
| | | Re: Rules
[Re: pgp]
#258030 03/04/13 11:18 AM 03/04/13 11:18 AM |
Posts: 4,451 West coast of Norway | I dont understand the question.. Are you thinking outside the rules or inside? Outside the rules anything goes. Inside the rules the "practical" aspect is quite important for most. Flipping the boat on the side to clean off weeds and plastic bags is quite slow I am leaning back and watching the developments. It is my opinion that it is currently to early for the F16 class to consider allowing foils. Let the pure development classes experiment a bit first. Or by all means, go off experimenting with an F16 platform and measure the performance up against a standard platform. I will totally support that! We should allow experimental platforms to race with the class but without scoring the experimentals. | | | Re: Rules
[Re: pgp]
#258033 03/04/13 12:11 PM 03/04/13 12:11 PM |
Posts: 5,525 | Inside the rules.
I like the idea of experitmental boats.
IIRC, the rules don't allow appendages but don't require dagger boards. So, can you attach some sort of foil to the cross bar, or add a structure to support gybing boards?
| | | Re: Rules
[Re: pgp]
#258050 03/04/13 03:46 PM 03/04/13 03:46 PM |
Posts: 5,525 | Foiling seems to be the cause du jour. We'll see how it plays out I guess. http://www.youtube.com/watch?v=taJYT4eAiWE&feature=youtu.be
| | | Re: Rules
[Re: pgp]
#258068 03/05/13 07:17 AM 03/05/13 07:17 AM |
Posts: 5,525 | I think foiling is clearly faster, consider Sailrocket, Hydropter. Control seems to be an issue.
I was talking to an A class builder and he maintains their boats are now going to weather with only about 1/3 of the lee hull in the water. Imo, that has to be both higher and faster.
Btw, I exchanged posts with Wayne Marlow yesterday and he has put an A class rig on his F16. Any idea how that might work?
| | | Re: Rules
[Re: pgp]
#258080 03/05/13 09:40 AM 03/05/13 09:40 AM |
Posts: 6,049 Sebring, Florida. | As I watched the last 30 seconds of that A cat video, it showed me exactly why I don't want to foil! Up down, Up down, you are basically riding a teeter-totter, and he was in flat, smooth water. Now, imagine trying to ride that hobby horse in some waves! The previous video, with the Phantom, also shot while sailing on flat water, but obviously it has some type of foil on the rudders that is helping both to lift and stabilize the boat. I think that is the biggest problem to overcome, trying to keep the boat stable, up on the foils, while also going up and down over waves. The C class Cats tried it a long time ago, and finally abandonded it, I thought because it was only faster when going downwind, not upwind? So, if we are going to go down the Foiling road, we may need to change our race course layout to more reaching/downwind.
Blade F16 #777
| | | Re: Rules
[Re: Rolf_Nilsen]
#258081 03/05/13 09:57 AM 03/05/13 09:57 AM |
Posts: 6,049 Sebring, Florida. | An A class rig on a uni F16 should be very nice. Two up would perhaps be more load than the mast was designed for. We discussed this some time ago on this forum I believe as part of the "uni vs two-up" performance thread. Consider "Rocker" C-class who was not faster than the other C-Class boats http://www.stevekilling.com/SteveKilling_CSYS2009.pdfIt still remains to be seen where development will go. Interesting time to watch and even perhaps play a bit. That's an excellent docutment Rolf, thanks for posting the link! Pete, skip on down and read all of page 15. Here's one small part I pulled from there: She proved very stable in both pitch and roll axes, leading her crews to have confidence in their ability to control her. In more breeze, at higher speeds, it proved important to prevent her from riding too high, as the rudder elevators, which were not as deep as the daggerboard wings, could surface and ventilate, whereupon they would lose lift and settle into the water. This pitched the bows up, and as the boat continued forward she would then fly the main foils out of the water, ventilate those, and crash (with some measure of grace) back to the water surface. It was at those times we were grateful to have used full-length hulls. Importantly, we never capsized or pitchpoled the boat. Figure 24
Blade F16 #777
| | | Re: Rules
[Re: pgp]
#258086 03/05/13 10:54 AM 03/05/13 10:54 AM |
Posts: 5,525 | So what's your take on canted boards?
| | | Re: Rules
[Re: pgp]
#258090 03/05/13 11:51 AM 03/05/13 11:51 AM |
Posts: 4,119 Northfield Mn | Foiling will kill every class, and everyone who's thought about it. Just look at the Moth.
| | | Re: Rules
[Re: pgp]
#258093 03/05/13 12:02 PM 03/05/13 12:02 PM |
Posts: 4,119 Northfield Mn | Yeah, lots of sarcasm. If a no limits board rule came up for vote in the F16 class, I'd vote yes.
| | | Re: Rules
[Re: Karl_Brogger]
#258095 03/05/13 12:04 PM 03/05/13 12:04 PM |
Posts: 3,906 Clermont, FL, USA | Dude, just quit fighting it and get an A-cat.
| | | Re: Rules
[Re: pgp]
#258096 03/05/13 12:05 PM 03/05/13 12:05 PM |
Posts: 6,049 Sebring, Florida. | Who, me?
I told you, I can't afford it, or I'd have one already!
Too damn many kids, and horses!
Blade F16 #777
| | | Re: Rules
[Re: Timbo]
#258100 03/05/13 12:23 PM 03/05/13 12:23 PM |
Posts: 5,590 Naples, FL | swap that F16 of yours for that yellow Marstrom Acat in GA ($9,000 +/-) It's made for old-dudes like us
356
guests, and 110
Mod | | Forums26 Topics22,405 Posts267,059 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
