Re: A NEW Cat [Re: bacho] #259018
04/17/13 06:54 PM
04/17/13 06:54 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
US Sail Level 2 Instructor
US Sail Level 3 Coach
Re: A NEW Cat [Re: hobie1616] #259024
04/18/13 07:34 AM
04/18/13 07:34 AM
Originally Posted by hobie1616
I'm not sure what you intended to link to - but good god...are people really "huffing" refrigerant to the point that you need to lock your charging ports?
Re: A NEW Cat [Re: Jake] #259027
04/18/13 08:28 AM
04/18/13 08:28 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Yep, Happens all the time. Nothing like a good dose of R-22 to get the party going.
Re: A NEW Cat [Re: Bille] #259028
04/18/13 08:30 AM
04/18/13 08:30 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
This is the product I had in mind, they have about 10 different flavor a though.
http://www.rectorseal.com/RectorSeal-No-5.php
Re: A NEW Cat [Re: Bille] #259029
04/18/13 09:03 AM
04/18/13 09:03 AM
M
MN3
MN3
M
from how much i have used when removing both beams, fabricating and attaching a new dolphin striker, my $12 tube will last the life of a boat (or 2)
After seeing the results after 300 salt water sails (2 years)... i couldn't be more impressed with this product
Re: A NEW Cat [Re: Jake] #259030
04/18/13 09:04 AM
04/18/13 09:04 AM
Unforutnately, that was pretty rampant up in Lehigh Acres during the housing debacle. Lots of abandoned houses and unattended HVAC units.
I can only presume that huffing the refrigerant produces a "high" because of the asphyxia? If that is the case, why don't they just put a plastic bag over their head? Or suck helium balloons?
I enjoy the thrill of driving home at night to find pre-teen (under 14) kids dressed in dark clothing sitting in circles texting each other IN THE MIDDLE OF THE ROAD.
At least cats and racoons try to get out of the way...
Maybe it's their activism campaign to ensure the residential speed limit of 25 mph?
One kid was recently smacked by a soccer mom late for her kid's game. Thankfully the kid in the street lived (broke leg), but the mom about flipped her land-yacht (I think it was an Armada or Excursion) swerving out of the way. Took out three water pipes/check valves too so no water for a day...
Re: A NEW Cat [Re: bacho] #259039
04/18/13 02:03 PM
04/18/13 02:03 PM
catman Offline
catman  Offline
I wouldn't use this stuff for the boat. The description mentions nothing about preventing corrosion caused by dissimilar metals.
Re: A NEW Cat [Re: Bille] #259133
04/23/13 03:02 PM
04/23/13 03:02 PM
Bille Offline OP
Bille  Offline OP
Today we packaged up the Main-sail and sent it off to
North Star kite & sail repair in San Diego, to get some
Reefing grommets & patches sewn into the third panel
from the bottom,(remaining aria about the size of a Hobie-16).
We Got a H-16 jib for when we reef the main ; we need to
practice the change-up , i think it's something that
can be done while under-way,
(i do that on a 45ft mono-hull); remember it blows 25+
at lake Mohave, and i'm kinda conservative. No way
would i bring that Rocket into that much wind with
Full sail aria (.)
The Cat is Near-Done except for sealing the Hull bolts, Fore-stay brackets,
& Mast, and the rudder mount bolts,
( i glassed both the hulls in the stern because of spiders
in the gel), and fixed some small de-lams on the daggers & rudders.
We decided Ageist using a Mast-float right off ; instead
we're gonna seal the Mast and practice righting it in
the bay at 6-mile Mohave in calm air. If there's a problem
then we get the ugly Mast-float LATER.
SO, i'll be researching all the sealants you guys suggested
and it should be in the water late next week !!
THANKS from : Bille and Tracy --co/owners
Ps :
Tracy's wife isn't nearly as Pissed now, at the
New purchase, cause
his --Nacra 5.2-- got sold last night . HA !!
Re: A NEW Cat [Re: Bille] #259134
04/23/13 03:27 PM
04/23/13 03:27 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Be sure to note that the boat will be A LOT harder to right from capsized in calm conditions. For practice, flip the boat in a moderate 10-12knt breeze to practice. The wind will actually help the righting of the boat....the more wind, the easier the boat rights.
Re: A NEW Cat [Re: ksurfer2] #259136
04/23/13 06:10 PM
04/23/13 06:10 PM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Uh, perhaps when the angle of the boat/sails are optimal for righting in the wind?
I mean, what if the wind is pushing on to the bottom of the tramp?
When it's pushing on the top of the tramp, better be hanging on the windward dolphin striker, eh?
Mast floats are the mark of a flunkie, if you want to sail and everyone stays away from you- put a mast float up there
Sounds like you're going about it well.
Never thought of reefing and smaller jibs like the monosluggers do- I just sheet/downhaul the SHEET oout of everything and feather up a bit.
Going with smaller sail area in the heavier stuff sounds like a good plan!
F-18 Infusion
#626- SOLD it!
Re: A NEW Cat [Re: hobie1616] #259137
04/23/13 06:11 PM
04/23/13 06:11 PM
Todd_Sails Offline
Todd_Sails  Offline
he, he, he said Rector! Rector? Nearly killed her!
F-18 Infusion
#626- SOLD it!
Re: A NEW Cat [Re: Todd_Sails] #259139
04/23/13 07:53 PM
04/23/13 07:53 PM
Bille Offline OP
Bille  Offline OP
... For practice, flip the boat in a moderate 10-12knt breeze to practice. The wind will actually help the righting of the boat....the more wind, the easier the boat rights.
WHAT IF :
if i made a Sea-anchor from 5ft diameter canvas & a cord
to center so retracting it is Easy ?
Place it where i can get at it to Reef the sails while in
irons with rudders up ; & toss it after flipping to
get that Optimum angle on the tramp . Maybe place it in a
bag on the base of the Mast ?
There's NO real current, (to speak of) on lake Mohave
Bille
Re: A NEW Cat [Re: Bille] #259145
04/24/13 08:49 AM
04/24/13 08:49 AM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
The sea anchor is a good idea for reefing, as well as keeping the bows into the wind when righting. I have a drift sock from Cabella's that works well. The line has a carabiner that clips to a jib bridle wire, and the line is tied off at the main beam. When the boat is ready, you can sail fwd over the anchor and pull it aboard, release the line from the beam, and it will run thru the 'biner as you retrieve it.
Dave
Re: A NEW Cat [Re: Bille] #259146
04/24/13 09:17 AM
04/24/13 09:17 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
You won't have much luck reefing that main. Because these mains hook at the top you can't really reef the main. The problem is the main will pull out of the comptip track when it's reefed. Only thing you could try would be to install a second hook but I doubt that will work.
If you just tie a line to the top of the main that will hook on the top of the mast, the main will pull right out of the mast track.
Also releasing a main and getting it to rehook in big seas and big wind is a recipe for problems. Only way I would do it is if I pulled up on land to make the change.
I owned an H20 for a number of years.
Mike Hill
N20 #1005
Re: A NEW Cat [Re: Bille] #259147
04/24/13 09:32 AM
04/24/13 09:32 AM
Arizona
AzCat Offline
AzCat  Offline
Arizona
As for righting, get Rick's book on cat sailing, the yellow one in his store on this site, has very good directions of exactly what to do to right your boat. You don't need a sea anchor, you have a mast and main to create drag and the tramp becomes your sail(pushes your hulls down wind). Biggest problem you will have is either an un sealed mast , or the wind pushing the hulls and tramp (your new sail) over the main and mast(your sea anchor). A good move is, upon capsize WITH THE MAST DIRECTLY DOWN WIND, to have your crew swim IMMEDIATELY to the tip o the mast and keep it from going down. The main and mast act like a scoop when directly down wind and the hulls can get blown over the top of them pretty quickly. You need to release the main sheet AND THE DOWNHAUL! FAST!! He swims the tip of the mast to the side. Which ever side it "wants" to go to. Which ever side he goes to, you are on the lower hull with the righting line in hand , and you move your weight to the opposite end of the boat to create drag to help the mast come around to downwind. Then right according to Ricks book. Get Ricks book!
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: A NEW Cat [Re: AzCat] #259149
04/24/13 09:42 AM
04/24/13 09:42 AM
Actually, a sea anchor is a great thing to have. The formula boats have a tendency to want to turn downwind after righting even if you have properly eased everything. At least hypothetically, the sea anchor will help park the boat so it doesn't take off while your crew (who fractured a rib in the capsize) drifts in the water while you use every drop of remaining energy to hang on to the rudder in Charleston Harbor while careening toward an anchored race committee boat, then an active dredge, and then a sea wall before it luckily comes upon a sand bar where you can dig in your heals and drag the boat into the wind and get it to stop while you catch your breath and sigh with relief. Not that that ever happened or anything.
Re: A NEW Cat [Re: Todd_Sails] #259153
04/24/13 10:16 AM
04/24/13 10:16 AM
my new starting strategy for a clean lane... put a mast float on the boat... smile
Re: A NEW Cat [Re: Mike Hill] #259163
04/24/13 03:07 PM
04/24/13 03:07 PM
Bille Offline OP
Bille  Offline OP
Originally Posted by Mike Hill
... Only thing you could try would be to install a second hook but I doubt that will work.
A second hook should work ; so should an Extension from
the existing hook to the top of the sail. I like the
second hook Better ! If the sail pulls out i will
make a carbon section on that track spot.
What diameter and weight cloth do they use on those Sea-Anchors ?
Bille
Re: A NEW Cat [Re: Bille] #259170
04/24/13 11:10 PM
04/24/13 11:10 PM
WA, ID, MT
davefarmer Offline
davefarmer  Offline
WA, ID, MT
http://www.cabelas.com/product/Bargain-Cave/Boating/Boat-Accessories%7C/pc/105591780/c/105767280/sc/105769980/Cabelas-Drift-Socks/738047.uts
I have the large, 38" dia, folds up very small, surprizingly lightweight rip stop nylon with 1" webbing. I have a pocket sewn to the underside of the tramp with a velcro closure facing aft.
Dave
0 registered members (), 1,088 guests, and 25 spiders.
