| Re: A NEW Cat
[Re: Bille]
#258958 04/15/13 01:06 PM 04/15/13 01:06 PM |
Posts: 12,310 South Carolina | What's the "BEST" Sealant for use on the bolts & stay-mounts ?
The hulls are ready to go back on the X-beams & i need to seal the bolts ; what should i use that's better than silicone sealant ?
Bille 3M 5200 marine sealant is the best - but can be very difficult to remove if you need to remove things later. 4200 sealant is a little less permanent. Either can be cleaned up with mineral spirits while it's still wet to leave a nice smooth finish. I was onced involved with a Nacra that someone had seated it's beams to the hulls with 5200. When it finally came apart, the fiberglass hull was still stuck to the beam.
Jake Kohl | | | Re: A NEW Cat
#258959 04/15/13 03:43 PM 04/15/13 03:43 PM |
Posts: 5,590 Naples, FL | a leaky mast is a disaster waiting to happen.
El-cheapo method of finding out where it leaks is to toss it in the water (by itself) and see if you can find bubbles.
A pinhole drain near the base of the mast will help drain any water that may find its way into the mast during sailing later on.
| | | Re: A NEW Cat
[Re: Bille]
#258982 04/16/13 02:20 PM 04/16/13 02:20 PM |
Posts: 330 | what should i use that's better than silicone sealant ?
Bille What's wrong with using a standard marine silicone? This is what's used on most boats and works just fine. I would definitely not recommend using 3M 5200. If you ever need to take the boat apart in the future, you're going to really regret using that stuff - it is a permanent adhesive and you'll likely end up damaging/destroying the hulls, beams, or both trying to get them apart. Use marine silicone and if your hulls leak, then you probably have a crack somewhere or another leak source unrelated to the crossbar bolts. sm | | | Re: A NEW Cat
[Re: srm]
#258983 04/16/13 02:38 PM 04/16/13 02:38 PM |
Posts: 12,310 South Carolina | what should i use that's better than silicone sealant ?
Bille What's wrong with using a standard marine silicone? This is what's used on most boats and works just fine. I would definitely not recommend using 3M 5200. If you ever need to take the boat apart in the future, you're going to really regret using that stuff - it is a permanent adhesive and you'll likely end up damaging/destroying the hulls, beams, or both trying to get them apart. Use marine silicone and if your hulls leak, then you probably have a crack somewhere or another leak source unrelated to the crossbar bolts. sm I didn't read that far enough to realize he was talking about the beam bolts - yeah, don't use 5200 on the beams...it's great for sealing miscellaneous hardware and screw port bases (that will likely need to be removed later because it's falling apart).
#258984 04/16/13 03:38 PM 04/16/13 03:38 PM |
Posts: 5,590 Naples, FL | since he's talking about the beam bolts, does the Miracle 20 have stainless bolts going into aluminum so you have to consider corrosion?
| | | Re: A NEW Cat
[Re: Bille]
#258990 04/16/13 10:04 PM 04/16/13 10:04 PM |
Posts: 337 Arizona | Hey! Good to hear of another Catsailor in our neck of the woods! Throw the mast in the swimming pool to find the leaks. But if you do it on a hot day, cool it down by spraying it with the garden hose first. Otherwise when it hits that cool water it will suck a bunch of water in due to cooling contraction. Leave part of the mast sticking out of the water till the sun heats it up a bit and you should start to see bubbles where you have air leaks. Marine silicone, try not to make a mess, take your time, tape off around leaky areas if you are concerned about making a mess. For the hulls, an air compressor and hose, no more than a maybe 5 lbs of pressure in through the drain plug, do not over-pressurize!!!!!!!!! squirted bottle with soapy water, squirt every rivet, screw, crack, fitting, cover, till you find all the leaks, hit them with silicone. It's a 2 man job unless your pretty resourceful . Pressurize, squirt, mark holes, wash off soap, dry completely, silicone, sail the F out of it!
Have you looked up Gordo up there at Mohave? He could be a big help. Also, a friend sold his N5.8 NA to a guy that sails up at Mohave. Look us up at Fleet 42.org and come over to Phoenix for some sailing at Lake Pleasant and Lake Roosevelt.
We had a Miracle at Roosevelt this weekend, the guys driving it were pretty fast! We will be out at Roosevelt again third weekend of May at Horse Pasture. Also, there should be a pretty good size group of cats heading to Rocky Point in two weeks, lots of Hobies! This coming weekend, Sunday , regatta at lake Pleasant. Get that boat together an come sailing with us!
Auscat MKV 444 A class NACRA I-20- 440/CATHATKA | | | Re: A NEW Cat
[Re: Bille]
#258991 04/16/13 10:29 PM 04/16/13 10:29 PM |
Posts: 337 Arizona | For the hull bolts, I use a Teflon paste. Would need to go out to my shop and get the details.
[Re: Bille]
#258998 04/17/13 09:21 AM 04/17/13 09:21 AM |
Posts: 2,844 42.904444 N; 88.008586 W | Nice buy on the H20M,
An older boat now, but still a nice boat, very bouyant- could have put a bit more of that in the front end, but still a nice solid boat- in most cases.
F-18 Infusion #626- SOLD it!
| | | Re: A NEW Cat
[Re: bacho]
#259007 04/17/13 11:31 AM 04/17/13 11:31 AM |
Posts: 12,310 South Carolina | I would be tempted to give Rector Seal a try c'mon...now you're just making stuff up.
[Re: samc99us]
#259008 04/17/13 11:33 AM 04/17/13 11:33 AM |
Posts: 12,310 South Carolina | Damn that stuff is expensive. Welcome to "marine". The picture was misleading...that price was for a 16oz tub and not the little syringe shown.
#259009 04/17/13 11:47 AM 04/17/13 11:47 AM |
Posts: 932 Solomon's Island, MD | Damn that stuff is expensive. Welcome to "marine". The picture was misleading...that price was for a 16oz tub and not the little syringe shown. I realized that  Still pricey stuff.
Scorpion F18
| | | Re: A NEW Cat
[Re: samc99us]
#259016 04/17/13 05:47 PM 04/17/13 05:47 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Damn that stuff is expensive. Welcome to "marine". The picture was misleading...that price was for a 16oz tub and not the little syringe shown. I realized that  Still pricey stuff. A one ounce tube lasts a long time and compared to the cost of replacing or repairing stuff it's priceless. Jamestown isn't cheap either. Look at the Tefgel site and you may find a dealer near you to save shipping costs.
| | | Re: A NEW Cat
#259017 04/17/13 05:56 PM 04/17/13 05:56 PM |
Posts: 774 Greenville SC | I would be tempted to give Rector Seal a try c'mon...now you're just making stuff up. Fer seriously It works great for on all kinds of different metals and with all sorts of nasty chemicals. Its available just about anywhere.
1,268
guests, and 34
