Page 24 of 202 1 2 22 23 24 25 26 201 202
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259672
05/16/13 10:57 AM
05/16/13 10:57 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
That would make sense.
I think they need some bicycle mounted pumps!
Re: AC72 Oracle Team USA Spaceship has landed [Re: brucat] #259673
05/16/13 03:33 PM
05/16/13 03:33 PM
Originally Posted by brucat
I respectfully, wholeheartedly, disagree.
Here's a statement from the man in charge - The CEO of the event Stephen Barclay.
http://www.businessweek.com/article...clay-on-sailboat-design-and-death-at-sea
Re: AC72 Oracle Team USA Spaceship has landed [Re: bacho] #259674
05/16/13 03:49 PM
05/16/13 03:49 PM
yes, especially if those grinding stations don't have to reverse the direction of rotation to switch gears (I think the first few generations did switch direction to change gears like a standard winch) - which would make the bicycle style inefficient (I don't think I can pedal backwards nearly as effectively)
But if they're just using them to drive a hydraulic pump, use the legs man!
Of course, the drawback is that they might not have the strength to jump up and run across the trampoline quite as quickly as they do with the standing grinder stations...
Re: AC72 Oracle Team USA Spaceship has landed [Re: waterbug_wpb] #259676
05/16/13 04:37 PM
05/16/13 04:37 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I'm thinking the cycles need to be mounted on rails, just before each tack the grinders are released to slide down to the low side, pedaling all the way!
Re: AC72 Oracle Team USA Spaceship has landed [Re: bacho] #259679
05/16/13 05:29 PM
05/16/13 05:29 PM
Re: AC72 Oracle Team USA Spaceship has landed [Re: Tony_F18] #259682
05/16/13 06:23 PM
05/16/13 06:23 PM
Dunedin Causeway, FL
David Parker Offline
Pedal powered sailing tools are nothing new. Here's a photo of an on-deck blender.
The latest human powered airplanes (and blenders) are using a rowing machine style of human power, giving up on the bicycle style. Something about using only the big muscle groups.
If they got really strong at that technique a grinder/rower wouldn't ever run across the tramp, they'd simply take the whole width in single power jump, like a frog. Just don't overshoot.
I'll get my coat.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259687
05/17/13 07:26 AM
05/17/13 07:26 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259688
05/17/13 07:34 AM
05/17/13 07:34 AM
On the Water
P.M. Offline OP
P.M.  Offline OP
On the Water
Philip
USA #1006
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259689
05/17/13 07:58 AM
05/17/13 07:58 AM
pgp Offline
pgp  Offline
It sounds like a reasonable argument to me.
Pete Pollard
Blade 702
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259690
05/17/13 08:18 AM
05/17/13 08:18 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
One accident due to a boat insufficiently built makes it a slaughter?
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259691
05/17/13 09:43 AM
05/17/13 09:43 AM
pgp Offline
pgp  Offline
I'm guessing that's a translation problem. At any rate I got the impression he was referring to possible damage during qualifying, that wind on the bay would be quite high at that time and much reduced later in the year when the Cup is actually run. I was glad to read he was calling for divers, air bags and the like.
Pete Pollard
Blade 702
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259693
05/17/13 11:59 AM
05/17/13 11:59 AM
Recommends suspending sailing until the middle of the week! Ouch...that's not good for the event.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259694
05/17/13 12:03 PM
05/17/13 12:03 PM
I think the AC 45 was some of the best racing we will see. They could have just as easily used those boats for the Cup races and had a lot more teams participate.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Timbo] #259695
05/17/13 12:25 PM
05/17/13 12:25 PM
It would be hard for any of them to admit that now, but I'm with you. Open up the AC45 rule to allow some development in foils, etc and have a huge event.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259696
05/17/13 12:52 PM
05/17/13 12:52 PM
pgp Offline
pgp  Offline
I'll believe that when I see it. AC is all about elitism, imo.
Pete Pollard
Blade 702
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259697
05/17/13 02:16 PM
05/17/13 02:16 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
Good riddance.
Give me the keys to the boat on the way out, I'll take good care of her.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Timbo] #259698
05/17/13 02:17 PM
05/17/13 02:17 PM
Portland, Maine
Portland, Maine
Russell Coutts tried - and he was told to get stuffed.
Re: AC72 Oracle Team USA Spaceship has landed [Re: ThunderMuffin] #259699
05/17/13 03:02 PM
05/17/13 03:02 PM
Is it me, or has the AC always been a boat race between uber-wealthy narcissists? That's what makes it so entertaining
Would you rather watch "Lifestyles of the lower middle class & nominally known" on television? I think not.
Having Robin Leech ride in my half-destroyed car with his camera crew would be a little un-nerving, but he could help keep that window from leaking while he's there...
Suspending racing for a short while until people can determine if there is something inherently wrong with ALL the boats sounds reasonable. But if it turns out one team or boat was cutting the margin too thin, then the rest of the teams shouldn't be penalized
I've recovered a few bodies of offshore power boat racers in my earlier days (dive rescue), but I don't recall the industry cancelling the entire fleet/division/calendar because of one (or a few) accidents.
I'm sure that some of the accidents may have actually been the result of design deficiencies, too...
I recall diving on one boat (maybe a 60 foot tri) that stuffed hard in a wave while rounding a mark and killed the throttle hand (traumatic asphyxia from what we figured - our response was literally 30 seconds from when the boat crashed to our getting hands on him, but CPR attempts were unsuccessful). The boat literally disintegrated below us (our safety team was following in a small helicopter at about 100' asl). The driver denied being hurt, but we got him packaged (backboard/CS collar) on the rescue boat and later found out he had a C-6 fracture.
While tragic for all involved, the general racing community believed it was one of the inherent perils of the "game" and soldiered on. I would hope to see the same out of the AC
Even back in the early AC events, the danger of injury or worse was always present. A parted sheet or blown block could easily maime or kill a sailor. Collisions between boats have and will break bones or worse.
Booms swinging can knock sailors overboard unconscious, and until recently I don't recall any of them wearing PFDs while training or competing.
Learn all we can from this incident, apply those lessons to protect life and property, and let's develop the sport and its associated technologies in a safe and effective manner.
Re: AC72 Oracle Team USA Spaceship has landed [Re: Jake] #259700
05/17/13 03:16 PM
05/17/13 03:16 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I think that was tried but NZ killed the idea, I think it was proposed after the OR crash.
It might have made a much better event, I imagine it would have been much more affordable with more teams jumping in. Probably more teams doing the series as well.
On the other hand it would have have been quite the same as the big badass 72s either. It's not the AC without the wealthiest teams competing with the biggest and baddest boats.
Re: AC72 Oracle Team USA Spaceship has landed [Re: P.M.] #259701
05/17/13 03:33 PM
05/17/13 03:33 PM
pgp Offline
pgp  Offline
Then they can readily afford safety crews and equipment to safeguard the lives of the sailors. In hindsight I'd say safety standards were amateurish.
Pete Pollard
Blade 702
0 registered members (), 824 guests, and 44 spiders.
