Re: Nacra 5.8; adding a boom, losing a boomlet [Re: ileestma] #261471
07/17/13 07:03 PM
07/17/13 07:03 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Originally Posted by ileestma
Finally, since we're on the topic, and while i have your attention, what about adding a "blade" jib in the mix too. Namely, one that is self-tacking, and non overlapping. Will this cause "balance" problems? I've heard i can actually obtain roughly the same sq. ft. of area by extending the leech, which would be in keeping with the high-aspect theme of these potential rig changes. thoughts?
My thoughts on the jib are that all the bighead sails have a relatively small jib that just shapes the wind into the slot so you really just need to match your sail shape with your jib shape, the Taipan 5.7's went to self tackers by dropping the tack to the top of the spin pole using a stainless steel rod to give them a longer jib with roughly the same area, I'm not sure about lifting your hounds or putting your jib higher than the hounds. The F18 mast is only 20cm shorter than the 5.8 so you could try some F18 sails as a starting point and see how they feel and see if the mast holds the leach up.
Couple of other things to consider, the 5.8 mast is designed to loosten your diamonds as the wind gets higher allowing the mast to depower the rig by bending into the slot in gusts.
On a reach the 5.8 is the most fantastic boat I've been on, I've got video of me on a reach jumping over and through waves in over 20 knots on the 5.8 and it's totally controlled, I've never pitchpoled it on a reach but on downwind course's I've gone in big time. I run a F18 spin on my 5.8
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: yurdle] #261473
07/17/13 09:11 PM
07/17/13 09:11 PM
Arizona
AzCat Offline
AzCat  Offline
Arizona
Originally Posted by yurdle
Originally Posted by azcat
I would estimate that I had seen the 5.8 mast bend off +5-6 feet under kite and double trapped.
Holy..
-____
Yea, an abrupt turn above the hounds. Maybe pushing 30*.
Jeff, you have to see some stuff up there that looks pretty scary once in a while when you run spin, right?
I had a spin and sq top on a 5.7 also. I think it was a lighter mast section than the 5.8 & 6.0. Saw that thing bend off pretty bad also. Close to the 5.8, but I usually ran less weight on the trapeze and couldn't push as hard as Manny with his 5.8.
Auscat MKV 444 A class
NACRA I-20- 440/CATHATKA
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: ileestma] #261475
07/18/13 01:05 AM
07/18/13 01:05 AM
JeffS Offline
JeffS  Offline
I mainly saw the wild mast with my old style fat spin that fluffed around as soon as I got going properly. The F18 spin behaves nicely and doesn't do such dramatic pulling to the side. My Taipan 5.7 was set up beautifully when I got it and I just pulled the spin up and went double trapped at 185kg crew weight, I haven't got to that stage yet with the 5.8
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: JeffS] #261486
07/18/13 09:29 AM
07/18/13 09:29 AM
I
ileestma Offline OP
ileestma  Offline OP
I
Originally Posted by JeffS
[quote=ileestma]
The F18 mast is only 20cm shorter than the 5.8 so you could try some F18 sails as a starting point and see how they feel and see if the mast holds the leach up.......... I run a F18 spin on my 5.8
20 CM?!? Well, shoot. Sounds like my best route is buy a used F18 main and chute. That way i could save $$$$ by buying used as opposed to new/custom. the only question is will it look like hell, e.g. boom is way too high. I can't get the thing lengthened either because it's tri-radial construction right?
As for the chute, i have to add a pole and halyard anyways, i'll just place them wherever i have to in order to make the chute work.
bada bing bada boom!
The jib, i'm afraid WILL need to be custom however...
Am i on the right track here? this way i'm not spending the same money as a used F18, but still getting a major modernization of the rig..... or will this route yield a frankensteined POS?
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: ileestma] #261487
07/18/13 09:48 AM
07/18/13 09:48 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I wouldn't plan on keeping up with a real F18. I think your underestimating the difference the hull and foil shapes make.
I may have missed it, but are you planning to race or just tear up the water by yourself?
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: bacho] #261489
07/18/13 09:52 AM
07/18/13 09:52 AM
I
ileestma Offline OP
ileestma  Offline OP
I
no, i don't plan on keeping up with an f-18, i just want to get as close to them as possible, while spending as little as possible....
I am just going to be ripping it up by myself, with the occasional portsmouth event.
Re: Nacra 5.8; adding a boom, losing a boomlet [Re: ileestma] #261500
07/19/13 01:08 AM
07/19/13 01:08 AM
JeffS Offline
JeffS  Offline
It won't be a POS but will be a frankenboat, if you sail your boat as is around 20kts you will feel the controllable power in it, I don't know how the boat will react to having a third more drive up high with a square top but I can guess. A Tornado main is only slightly longer so perhaps have a go with the rig of one of those
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
1 registered members (nutsy), 297 guests, and 31 spiders.
