Front Beam #263250
09/05/13 07:32 PM
09/05/13 07:32 PM
Karl_Brogger Offline OP
Do we need a dolphin striker?
Re: Front Beam [Re: Karl_Brogger] #263255
09/06/13 02:21 AM
09/06/13 02:21 AM
Scarecrow
Scarecrow
On a Viper with Ali beams? Yes
Alternately there is only one way to find out for sure....
Re: Front Beam [Re: Karl_Brogger] #263260
09/06/13 07:54 AM
09/06/13 07:54 AM
I mean rules wise. Is it required?
Re: Front Beam [Re: Karl_Brogger] #263262
09/06/13 08:10 AM
09/06/13 08:10 AM
From the top of my head: A dolphin striker is not required in the rules.
Materials in the beams are not restricted either.
Class rules are missing on the class website so it is impossible to check if there have been any changes on this over time.
Re: Front Beam [Re: Karl_Brogger] #263263
09/06/13 08:16 AM
09/06/13 08:16 AM
I didn't think so, or at least I didn't remember seeing anything about it. I knew materials weren't limited. A carbon front beam could be designed to not have a dolphin striker, whether or not there is a savings in weight I don't know. It could certainly be stiffer.
Re: Front Beam [Re: Karl_Brogger] #263265
09/06/13 08:23 AM
09/06/13 08:23 AM
No dolphin striker to hit waves is faster.
I dont know what happened to the rules in 2010 as the ISAFisation process was going on.. Look at this for the rudders in a PDF of the 2010 rules I found on the forum on the class website.
E.4.4 CONSTRUCTION
(a) The cross section of each rudder shall be symmetrical about its fore and
aft centre line .
Now what does this mean?? Rudder winglets certainly is allowed in multiplie configuration and is used in the class but this effectively does not allow L-shaped winglets. No discussion, no ballot and comments..
Re: Front Beam [Re: Rolf_Nilsen] #263274
09/06/13 10:00 AM
09/06/13 10:00 AM
M
mini Offline
mini  Offline
M
E.4.4 CONSTRUCTION
aft centre line .
T foil rudders are specifically mentioned as allowed. No varying shape is allowed on the dagger although they could be assym as long as they are straight and canted no more than 6 degrees. You could easily argue that a J or L foil on the rudder would be likewise allowed.
What is not mentioned is moving flaps or likewise appendages. By the rules you could add them on the rudders now and vertical flaps to the daggers too if you wanted to. - That ought to bring forth a big rules debate as soon as somebody shows up to a worlds sporting moveable flaps.
Re: Front Beam [Re: Karl_Brogger] #263276
09/06/13 10:52 AM
09/06/13 10:52 AM
pgp Offline
pgp  Offline
Does anyone have a link to the current rules set?
Was there a class meeting at Racine?
Pete Pollard
Blade 702
Re: Front Beam [Re: Karl_Brogger] #263277
09/06/13 10:52 AM
09/06/13 10:52 AM
Which after this AC and little AC cycle is a total reality smile
Re: Front Beam [Re: Karl_Brogger] #263278
09/06/13 10:56 AM
09/06/13 10:56 AM
pgp Offline
pgp  Offline
I think the hulls as we have known them are going away and the boat will become a ladder frame to attach sponsons and foils.
I was unwilling pay the collectors price for the Bernard Smith book, but iirc he talks about fat foils which lead to limitless design possibilites.
Pete Pollard
Blade 702
Re: Front Beam [Re: pgp] #263280
09/06/13 12:15 PM
09/06/13 12:15 PM
Mirabaud already went that route. It is not fast when not foiling wink
Re: Front Beam [Re: mini] #263282
09/06/13 12:21 PM
09/06/13 12:21 PM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
This might be a good thing for the class if it can be done well, and still be usable for single handing, and not add a lot of hassle to sailing off the beach. I for one would be pretty likely to switch to a full flying F16, as we're in the ball park weight range and have an existing local fleet. Trouble is the existing boats are not good in short chop on a distance course where waterline is king. Full flying changes all of that.
Scorpion F18
Re: Front Beam [Re: samc99us] #263284
09/06/13 12:44 PM
09/06/13 12:44 PM
No foiling in the F16 class as the daggerboards can not go more than 6deg off vertical. This makes it hard to get enough surface producing vertical lift in the water.
Sensible approach in my opinion. It is still early days for foiling. What would be cool was if somebody starter testing foiling under the platform outside class racing.
Re: Front Beam [Re: Karl_Brogger] #263289
09/06/13 03:19 PM
09/06/13 03:19 PM
waynemarlow Offline
waynemarlow  Offline
The early Stealths did not have a front Dolphin striker and had T Foils way back in 2001, very stiff boat reliant on an oversize extrusion designed for the Dart 18's. It was only when John couldn't source the beams any longer did he change to a conventional set up.
As to foiling, nah we are just too heavy, but a semi foiling mode maybe the answer. Interestingly the SCHRS handicap system will defeat most foiling boats ability to really shine. Type in your boats details and then try the same with the lifting boards tick box activated. Watch that handicap get real tough. It amounts to a penalty of about 20 kilos of ballast. Mmmm
Re: Front Beam [Re: Karl_Brogger] #263291
09/06/13 03:39 PM
09/06/13 03:39 PM
I would love to see some of the A Cat guys build an arched front beam with no dolphin striker. Are there any out there already?
It would have to be made of carbon of course, unless you're really good at custom bending alum. tubes.
I guess you could put on a huge oversized straight tube, either alum. or carbon, with a thick enough wall, it wouldn't need a striker for support, but it'd be heavier and more drag when you do hit the top of a wave with the beam.
Re: Front Beam [Re: Karl_Brogger] #263317
09/07/13 02:18 PM
09/07/13 02:18 PM
I have not seen arched front beams on A-cats. More surface area to contend with in the build.
The C-cats do have curved beams, but with dolphin strikers from what I remember.
Bending an alu tube of 80-100mm diam would not be possible I think without compromising the structural integrity.
Re: Front Beam [Re: Karl_Brogger] #263408
09/09/13 08:37 AM
09/09/13 08:37 AM
samc99us Offline
samc99us  Offline
Hydro's has a dolphin striker (here: http://4.bp.blogspot.com/-plJNEqIu7...k3vAWmg0/s1600/cclasshydrosADimages1.jpg)
That doesn't mean the other boats do. The DNA does not have a dolphin striker, meaning you can probably do the same on a F16. That is the kicker with the F16 rules as currently written, as has long been discussed elsewhere.
Phantom built a foiling F18, but in carbon of course. Reading between the lines the existing hull shapes are fine but longer and wider is much better, as is having a second pair of hands to work the dagger boards. Time will tell.
Scorpion F18
Re: Front Beam [Re: samc99us] #263418
09/09/13 12:33 PM
09/09/13 12:33 PM
M
mini Offline
mini  Offline
M
The early F18 used the beams from the 20 foot 10 foot wide Tornado because it was easy to source and that became the standard. Some of the builders are using this same oversized beam now on their F16. Both are overkill and it would be a simple calculation to see if they would be structurally capable of handling the loads without a striker.
If they could it would likely be a bit more flexy. I heard a rumor where Ashby installed a striker on his A class “stikerless beam” anyway because he thought the increased stiffness outweighed the added windage and weight.
The C class have a square truss system built into their designs. This requires the stiker post and its runners to each corner of the platform. They then can have a very light beam set as the truss system, which works off the striker and the standing rigg working together, provides all the structural stiffness at a significantly lower weight penalty than having big overbuilt beams. Looking at the AC45 and 72 they are doing the same thing it appears to me.
Re: Front Beam [Re: Karl_Brogger] #263453
09/10/13 06:12 AM
09/10/13 06:12 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I've been told a striker and beam on an A wieghs less than a striker less beam. A triangle is a fantastic way to add strength.
Re: Front Beam [Re: bacho] #263616
09/11/13 02:46 PM
09/11/13 02:46 PM
M
mini Offline
mini  Offline
M
Efficiently reaching your goal. You do not think the AC and C class guys would place those very complicated strut systems on their rides if is was not more efficent.(better)
0 registered members (), 1,284 guests, and 50 spiders.
