| Re: AC72 Oracle Team USA Spaceship has landed
[Re: catman]
#264363 09/20/13 09:32 AM 09/20/13 09:32 AM |
Posts: 2,490 On the Water | Has anyone checked their TV schedule to see if it's on NBCS today? I checked right before I left the house this morn and it didn't show up. Yes
Philip USA #1006 | | | Re: AC72 Oracle Team USA Spaceship has landed
#264369 09/20/13 09:54 AM 09/20/13 09:54 AM |
Posts: 96 | Hey Jake --you were the one with GPS on his wrist checking VMG S and very good at Navagation etc --I think that is what team O achieved by doing "something weird "upwind--A BETTER VMG upwind angle. The TV stats indicated a lower faster course sailed with better VMG . Jobson also mentioned he saw team O slide sideways a couple times upwind. This must be from attaining higher speeds by sailing a slightly lower -close reaching type angle then inadvertantly sometimes lifting on the foils as higher speed is reached . Going upwind surface foiling must be a delicate balance of angle vs speed keeping the radius board in the water for lateral resistance { from slipping sideways} . As a gust hits it must temporarily jump them up .
The designer in me can't help wonder if the foils were reversed --angled outward rather than tucked in towards the other windward hull, --that they would not provide much more lateral resistance upwind and the posibilty of foiling upwind most likely at close reach angles.
Seems team O has found a better upwind angle VMG than team N .
DISCLAIMER --i intend no disrespect to any person or team in observations -comments and constructive criticsms made --{joking a little here }
Carl
[Re: Carl]
#264372 09/20/13 10:18 AM 09/20/13 10:18 AM |
Posts: 12,310 South Carolina | Excellent race by team O yesterday --one small constructive criticsm. {see disclaimer} --When team O is ahead and has better speed why are they splitting so far to opposite sides of the course. Classic tactics while ahead after rounding the leeward mark is to sail upwind until your opponant is rounding then tack . This places your boat directly upwind from your opponant able to loosely cover in either direction .
The choise is made by the belief that while ahead you are in better wind pressure and towards the favored lift --BUT --gains made in match racing are all relative to the other boat --they need to settle for smaller potential gains and at least a loose cover on tean N . Instead we saw them split upwind yesterday --a potential mistake when they can not afford any . Lets hope they keep at least a loose cover when ahead .They are faster now --no reason not to.
{double check previous disclaimer ;] } While in the lead, Oracle is getting to the preferred side of the course. The guy behind seems to just split for the sake of splitting even if it puts them in a statistically less favorable position. -Ding, divert your eyes...I'm going to speculate and imagine I know what I know something for the sake of discussionI am also surprised that the boat behind is so quick to split and gamble on the opposite side of the course when it's proven to be less of an advantage in either current and/or pressure. I guess if you have committed yourself to the belief that you can't sail faster/higher than your competitor it makes sense to split and roll the dice...but I'm not sure either team has a clear advantages even in the normal wind speed differences across the course on a single upwind leg. Maybe it's a throw back to the larger wind disturbances mono-hulls create. A cat (particularly an uber-efficiently winged one) isn't going to disturb as much air and slow you down unless you are right on top of each other. As far as devices go, these guys have flip down tablets bunjied to their chests...I would love to see what they are seeing on those displays! I'm also in the process of making a spandex device sleeve like they have so I can quit losing GPS units.
Jake Kohl | | | Re: AC72 Oracle Team USA Spaceship has landed
[Re: Carl]
#264373 09/20/13 10:57 AM 09/20/13 10:57 AM |
Posts: 3,224 Roanoke Island ,N.C. | Excellent race by team O yesterday --one small constructive criticsm. {see disclaimer} --When team O is ahead and has better speed why are they splitting so far to opposite sides of the course. } Tidal Current.
[Re: Team_Cat_Fever]
#264376 09/20/13 11:38 AM 09/20/13 11:38 AM |
Posts: 96 | Hey Todd
Wow -I,ll never forget the stay snapping and mast falling over while we were on the Cape Hatterous leg of the W -1000--MILE RACE --talk about tidal currents WHEWW ! The Gulf Stream and Labadore currents colliding at the Cape.
Racing in Charleston harbor -Long Island Sound --Newport harbor -Corpus Cristi TX -the huge tidal currents along the N Carolina Virginia coast --or Tybee Island -etc --just like San Fran all have similar tidal currents. Most of us have sailed in something similar and can relate to it--Sarnia -Port Huron MI --Great Lakes where Lk Huron flows into the St Clair River at the Blue Water bridge --lots of frieghter traffic too--has a 5 mph current --it is brutal--you have to hug the shore.
Let me put the importance of a loose cover another way ---If you were on the last race of a major regatta and had to beat one boat to win the regatta --would you split tacks and sides of the course on the last upwind beat providing the only possible means of that one boat passing you --a fluke windshift ie , --or would you loosely cover the one boat staying between him and the finish ?
The only gain made by team N during the entire race yesterday -race 12 --was when they split tacks and sides of the course --lETS HOPE THEY DON'T OPEN THE DOOR WHEN AHEAD AGAIN .
Jake made a good point of how readily the boat behind splits and often goes to the less favored side instead of trying to mix it up and grind the other boat down to close the gap.
good observation and spot on .
[Re: P.M.]
#264380 09/20/13 12:08 PM 09/20/13 12:08 PM |
Posts: 1,658 Florida Suncoast, Dunedin Caus... | Has anyone checked their TV schedule to see if it's on NBCS today? I checked right before I left the house this morn and it didn't show up. Yes Hmmm. I have Direct tv and at 1pm it still does not show up.
[Re: catman]
#264386 09/20/13 12:57 PM 09/20/13 12:57 PM |
Posts: 12,310 South Carolina | Has anyone checked their TV schedule to see if it's on NBCS today? I checked right before I left the house this morn and it didn't show up. Yes Hmmm. I have Direct tv and at 1pm it still does not show up. DirectTV has NBCSN (channel 220 on my system)...but it's not showing up in my guide either.
[Re: Carl]
#264389 09/20/13 01:05 PM 09/20/13 01:05 PM |
Posts: 3,224 Roanoke Island ,N.C. | Hey Todd
I completely understand the validity of a cover in match racing, but the gains are relative to the losses and if you are skipping a 3 knot current in a boat doing 30 knots just to cover, then you are not taking advantage of the gains you earned as a lead boat. Alot of folks criticizing these tactics forget that the exceptional boatspeed moves this into a new realm. Your thought process works great at 1/3 the speed, but if you use it at this speed ,you better sail flawlessly i.e. never come off the foils because that alone will cost you 3 to 4 boat lengths. If you do cover and make a small mistake you just lost your lead, and will most definitely have the peanut gallery as well as your boss questioning why you didn't split and take advantage of the 3 knot current boost. If you use the "triple the wind speed" formula for the current, that's a 9 knot speed advantage over the boat on the other side of the course. That's huge. They've got the patterns there covered and have weighed the loss vs. gain scenarios. Not to say they can't be caught out, but this isn't club racing. In the same vein, you better get your current call right and get the advantage or the cover is the safe bet. TNZ should be playing it safe and Oracle should be all in, "safe" hasn't seemed to work so well for them.
#264390 09/20/13 01:06 PM 09/20/13 01:06 PM |
Posts: 3,224 Roanoke Island ,N.C. | Has anyone checked their TV schedule to see if it's on NBCS today? I checked right before I left the house this morn and it didn't show up. Yes Hmmm. I have Direct tv and at 1pm it still does not show up. DirectTV has NBCSN (channel 220 on my system)...but it's not showing up in my guide either. Mine hasn't showed up for awhile. When they did the guides, I guess they thought this would be wrapped up.
[Re: P.M.]
#264394 09/20/13 01:29 PM 09/20/13 01:29 PM |
Posts: 2,490 On the Water | I checked my schedule using a web browser and a phone app and it's there, might want to check that. You can power cycle (unplug) your DVR, let it reboot and that should force a schedule update.
Race 13 starts today at 13:15 PDT (8:15 NZST, 22:15 CEST) Race 14 at 14:15 if needed.
[Re: P.M.]
#264396 09/20/13 01:30 PM 09/20/13 01:30 PM |
Posts: 2,490 On the Water | Race 13 - 1:15pm (+0.3 ebb - 23.3 knot wind limit) Race 14 - 2:15pm (-1.7 ebb - 21.3 knot wind limit)
[Re: P.M.]
#264398 09/20/13 02:04 PM 09/20/13 02:04 PM |
Posts: 2,490 On the Water | Hard to tell from this picture but looks like Oracle has installed their sprit pole There was light winds forecast last night for today but wind has been building. Interesting.
[Re: P.M.]
#264399 09/20/13 02:17 PM 09/20/13 02:17 PM |
Posts: 2,490 On the Water | Dalton watching this one on the sidelines.
Wind 270 at 8.4 kts, 11.0 kts peak
1 registered members (FredL),
505
guests, and 97
