Beaching or anchoring my inter 20 overnight #265536
10/01/13 03:35 PM
10/01/13 03:35 PM
Hawaii
timtower Offline OP
timtower  Offline OP
Hawaii
Hey guys, looking for some input.
Sailing over to a camping beach in a week or two and will be camping (most-likely on shore) overnight. Anchor the N20 overnight or drag it up on to the beach?
Sabotage
USA 302
Nacra Inter 20
https://TurnoverBnB.com
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265538
10/01/13 03:43 PM
10/01/13 03:43 PM
Beach it. Strap three 2" or larger PVC tubes under the trampoline (or across the hulls), use these to slide the boat up the beach.
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265542
10/01/13 05:03 PM
10/01/13 05:03 PM
Western New York
wyatt Offline
wyatt  Offline
Western New York
Beach it. Our Fleet on Lake Erie keeps them on anchors during the day when we come in for refreshments or sail to the next beach bar. If a strong wind comes up, your boat could take a beating in the surf.
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265546
10/01/13 05:21 PM
10/01/13 05:21 PM
catman Offline
catman  Offline
You'll sleep better if it's on the beach.
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265547
10/01/13 05:26 PM
10/01/13 05:26 PM
Hawaii
timtower Offline OP
timtower  Offline OP
Hawaii
I guess my question more is (and this may very well be a dumb question) if I left the boat in the water over night, is there a chance the boat will absorb water through the gel coat? I'm not overly worried about the anchorage, it's pretty protected.
Alternatively, if I dragged the boat up on to the beach, I could some how rig a tent on the boat instead of bringing a real tent. Although that might be more hassle than it's worth.
A Nacra 20 might not be the best camping platform, but whatever.
Sabotage
USA 302
Nacra Inter 20
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265548
10/01/13 05:40 PM
10/01/13 05:40 PM
catman Offline
catman  Offline
You won't have a problem with the gel coat.
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265561
10/02/13 08:06 AM
10/02/13 08:06 AM
Near SLC, Utah
tomthouse Offline
tomthouse  Offline
Near SLC, Utah
We have always used ABS pipoe to help slide the boat up onto the beach, when we use the boat for cruising and beach camping.
Sleeping on the tramp is comfy, protected from dew or rain with a simple blue tarp rigged as a boom tent. That also puts your sleeping and sitting area up off the dirt or sand.
The side of the boat's hull is also a handy place to sit.
Make sure your boom tent lets the blue tarp extend past the tramp and drape over the sides of the hulls and over the front and rear beams.
If you don't you may find that rain will hit the tramp and drip off the underside of the tramp and its lowest point which is right where you are sleeping.
That also allows the water to "wick" upwards and soak your sleeping bag and gear from underneath.
We tried sleeping on a second blue tarp, but that caught a bit of rain and directed some of the water, again to the lowest point created by our body wieght on the tramp.
Beach cats are great for crusing and beach camping, if you approach it as a minimalist, when deciding what to take and what to leave at home.
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265563
10/02/13 08:16 AM
10/02/13 08:16 AM
M
MN3
MN3
M
we camp often - some sail beach wheels out - some just leave it on anchor overnight (for days on end)
really not an problem - just drain it when on land
the issues is when a front comes through at 4am and other cats (on anchor) flip in shallows, dislodging your anchor. then when you wake up ... and you cat is gone ... that's when you really start to worry.
Re: Beaching or anchoring my inter 20 overnight [Re: ] #265566
10/02/13 09:52 AM
10/02/13 09:52 AM
pgp Offline
pgp  Offline
We have a serious problem with barnacles down here, just a few days and the hull is like shark skin.
Pete Pollard
Blade 702
Re: Beaching or anchoring my inter 20 overnight [Re: pgp] #265602
10/03/13 08:47 AM
10/03/13 08:47 AM
TeamChums Offline
TeamChums  Offline
I usually bring tow small boat fenders (rubber bumpers)to set either the bows or sterns on depending on which way the boat is facing to level it up. Hook your main halyard to your boom and raise it to where you want and snug it up a little with the main sheet then throw a blue tarp over it and bungie it down at all four corners to the cross beams. Makes a great tent. You may want a tarp under you as well since it gets a bit breezy under the trampoline.
Lee
Re: Beaching or anchoring my inter 20 overnight [Re: TeamChums] #265610
10/03/13 03:15 PM
10/03/13 03:15 PM
Hawaii
timtower Offline OP
timtower  Offline OP
Hawaii
That's a pretty good idea. If I beach it and rig a tarp to it, then I can leave the tent at home.
Sabotage
USA 302
Nacra Inter 20
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265611
10/03/13 06:33 PM
10/03/13 06:33 PM
M
MN3
MN3
M
works great in ideal conditions, not so great when it's raining, buggy or windy. I would bring a tent incase
Re: Beaching or anchoring my inter 20 overnight [Re: ] #265627
10/04/13 10:27 AM
10/04/13 10:27 AM
TeamChums Offline
TeamChums  Offline
Agreed. Wind can blow the rain in. I use an 8X10 tarp and hook put the 8' part, fore to aft and the 10' part side to side. You can set the boom height to take up most of the slack and bungee the corners to the cross beam ends. I did this ALOT on my H21SE and even camped on the boat with it on a mooring out at Catalina Island in Avalon Harbor. I did put a tarp under the sleeping bags since once in a while a wave would hit from underneath the tramp. I liked the Hollofill type synthetic filled sleeping bags since they still keep you warm if the bag gets a little wet from rain or splashes. If it's cool out, you will feel a breeze under the tramp if you don't use a tarp under you. I've used my spinnaker in a pinch under us to keep warm. Long story short, I had to beach my N20 in the middle of the night on an over night race and we used the mainsail over the boom and wrapped up in the spinnaker and our drysuits to keep warm. Thank God I had a cute female crew with me blush
It's a lot of fun to camp this way. Power bars and apples make great compact meals. Never pack bananas...unless you like baby food.
Lee
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265628
10/04/13 10:41 AM
10/04/13 10:41 AM
M
MN3
MN3
M
we camp with the entire spectrum of camper - guys on windriders rolled up in a small tarp like a burrito overnight, to 3 room 11 person tents, generators and of course ... satellite football
Re: Beaching or anchoring my inter 20 overnight [Re: timtower] #265629
10/04/13 11:56 AM
10/04/13 11:56 AM
Really, who would go camping with out DTV?
Re: Beaching or anchoring my inter 20 overnight [Re: Karl_Brogger] #265630
10/04/13 02:55 PM
10/04/13 02:55 PM
M
MN3
MN3
M
and gran turismo
Re: Beaching or anchoring my inter 20 overnight [Re: ] #265633
10/04/13 04:22 PM
10/04/13 04:22 PM
Originally Posted by MN3
and gran turismo
man, that reminds me of a certain oyster bar in Clermont, a squalled out regatta, Playstation and Grand Theft Auto. Good times watching JC's character try to car-jack an old lady only to get the beat-down put on him...
Re: Beaching or anchoring my inter 20 overnight [Re: ] #265636
10/04/13 05:35 PM
10/04/13 05:35 PM
catman Offline
catman  Offline
and gran turismo
Your lawn mower.
Re: Beaching or anchoring my inter 20 overnight [Re: catman] #265679
10/06/13 08:58 AM
10/06/13 08:58 AM
M
MN3
MN3
M
I would NEVER use my lawnmower to clear paths and tent sites on an island
but i bet my old landlord's could use a new blade
and gran turismo
Your lawn mower.
0 registered members (), 1,440 guests, and 14 spiders.
