| Re: Dagger Repair
[Re: yurdle]
#266273 10/15/13 08:39 AM 10/15/13 08:39 AM |
Posts: 5,525 | "Avoiding the bottom." There's an idea.
Pete Pollard Blade 702
| | | Re: Dagger Repair
[Re: pgp]
#266283 10/15/13 12:50 PM 10/15/13 12:50 PM |
Posts: 5,590 Naples, FL | Didn't the Stiletto cats use Nomex cores?
I thought I saw a honeycomb core on one which had a porthole removed for replacement...
| | | Re: Dagger Repair
[Re: waterbug_wpb]
#266315 10/15/13 06:29 PM 10/15/13 06:29 PM |
Posts: 190 | Didn't the Stiletto cats use Nomex cores?
... OUCH -- this will boarder-line on Mean : http://stiletto.wildjibe.com/portfolio/Port_4/photo_15.jpgAnd that is why northsea junkie said this : ...
I'm still very surprised that they use it in boatbuilding. If you have followed the last Volvo ocean races, you certainly have seen the complete delaminated panels on the Imoca boats (all with honeycomb sandwhich core). ...
Bille | | | Re: Dagger Repair
[Re: yurdle]
#266316 10/15/13 07:10 PM 10/15/13 07:10 PM |
Posts: 4,119 Northfield Mn | Marstrom boats use a nomex core. At least their Tornado did.
| | | Re: Dagger Repair
[Re: yurdle]
#266342 10/17/13 05:27 PM 10/17/13 05:27 PM |
Posts: 307 maui | @bille Adding resin to your example is what i am describing. A tshirt saturated with rein won't soak up water after curing, but if you were to sand the edge exposing the fibers, would the fibers be able to soak up water? My contention is that after carbon or glass is saturated with resin, even if you sand the edge, exposing fibers, that the fibers won't soak up much water. You can dry it off, lightly skuff it and bond to it/paint it etc. If you try that experiment with kevlar water will soak in and if it's salt water you will never get the salt out. You will need to glass the salt in and the fuzz down; being careful not to sand back thru.
There is a whole big thread out there in cyberworld about honeycomb & Acats. Some of them use it. Billl Higgins' Stilletos most definitely were made using aircraft honeycomb and prepreg. Problems with honeycomb delam seem to be worked out. Once honey comb got to Tornados, they never looked back. They still have wood rudders and maybe the boards too. I think he does prepreg over the wood. Also there were honeycomb surf boards in the 60's that are still around today. So all the cool kids have honeycomb/prepreg these days. i assume: the AC 45's and 72's, some Ccats, those big 60 and 70' tris, but that isn't my field so not 100 percent sure about some of those boats.
As for trailing edge thickness-it's personal taste. You want them as thick as possible without slowing you down too much.. I think if you leave it perfectly squared off. you will get humm. rounded corners-no humm, but is it slower?
for future readers: For this particular repair it sounds like; try a small fill job first, and if it keeps chipping off, make it into a bigger job. one way would be to grind both sides down enough- (roughly the thickness of 3 layers of material), say 2-3" in from the trailing edge, so that after you glass it, the result will fair down nicely. The stronger the materials that you use, the better the repair will last. And off course customize the the trunk so that it isn't as likely to damage your precious foil. | | | Re: Dagger Repair
[Re: jollyrodgers]
#266346 10/18/13 03:37 AM 10/18/13 03:37 AM |
Posts: 774 Greenville SC | @bille Adding resin to your example is what i am describing. A tshirt saturated with rein won't soak up water after curing, but if you were to sand the edge exposing the fibers, would the fibers be able to soak up water? My contention is that after carbon or glass is saturated with resin, even if you sand the edge, exposing fibers, that the fibers won't soak up much water. You can dry it off, lightly skuff it and bond to it/paint it etc. If you try that experiment with kevlar water will soak in and if it's salt water you will never get the salt out. You will need to glass the salt in and the fuzz down; being careful not to sand back thru.
for future readers: For this particular repair it sounds like; try a small fill job first, and if it keeps chipping off, make it into a bigger job. one way would be to grind both sides down enough- (roughly the thickness of 3 layers of material), say 2-3" in from the trailing edge, so that after you glass it, the result will fair down nicely. The stronger the materials that you use, the better the repair will last. And off course customize the the trunk so that it isn't as likely to damage your precious foil. For hum, sanding the trailing edge at an angle can get rid of it. | | | Re: Dagger Repair
[Re: jollyrodgers]
#266354 10/18/13 07:05 AM 10/18/13 07:05 AM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | @bille Problems with honeycomb delam seem to be worked out. What how?????????? Did you ever have a sheet of honeycomb in your hands and start wondering how in heavens name the exterieur laminate layers should bond to the extremely thin headsides of the honey comb. (without loosing too much weight in extra connections)
ronald RAIDER-15 (homebuilt)
| | | Re: Dagger Repair
[Re: yurdle]
#266358 10/18/13 10:31 AM 10/18/13 10:31 AM |
Posts: 190 | There's a test the Gov labs do to a honeycomb laminate called the Peal-ply test ; they glue one side down, and measure how much force it takes to remove the exposed side from the honeycomb panel. Optimum skin weight for peal resistance is 10oz skin or better. Adding more thickened epoxy to disperse the energy to the cell walls, will add more weight.
I totally trust my Exxtacy to Not De-laminate while i'm flying. But if it's Water i'm asking the honeycomb to deal with than i'd keep the lamination width limited to 1 inch strips to isolate the tears in a De-lam panel.
Remember they use honeycomb in the fins of Very high speed rockets and also in some fighter-jet structures, and it holds up Well ; i would Never trust my life to the stuff on a boat , unless special precautions were utilized !!!
Bille
| | | Re: Dagger Repair
[Re: yurdle]
#273284 06/19/14 05:19 AM 06/19/14 05:19 AM |
Posts: 382 SE MI / NE IN | Digging up an old thread - Goodall Design just published a series of videos on proper dagger/rudder trailing edge repair. Link hereLooks like I have a fun little project before the next regatta. Anyone have a preferred source for carbon cloth? | | | Re: Dagger Repair
[Re: rehmbo]
#273295 06/19/14 02:28 PM 06/19/14 02:28 PM |
Posts: 3,906 Clermont, FL, USA | Digging up an old thread - Goodall Design just published a series of videos on proper dagger/rudder trailing edge repair. Link hereLooks like I have a fun little project before the next regatta. Anyone have a preferred source for carbon cloth? That was the best use of 7 minutes in quite some time.
| | | Re: Dagger Repair
[Re: rehmbo]
#273422 06/24/14 05:37 AM 06/24/14 05:37 AM |
Posts: 774 Greenville SC | Digging up an old thread - Goodall Design just published a series of videos on proper dagger/rudder trailing edge repair. Link hereLooks like I have a fun little project before the next regatta. Anyone have a preferred source for carbon cloth? Thanks for sharing those links. Certainly made it look easy! | | |
649
guests, and 178
