Page 3 of 3 1 2 3
Re: Dagger Repair [Re: yurdle] #266273
10/15/13 08:39 AM
10/15/13 08:39 AM
pgp Offline
pgp  Offline
"Avoiding the bottom." There's an idea.
Pete Pollard
Blade 702
Re: Dagger Repair [Re: pgp] #266283
10/15/13 12:50 PM
10/15/13 12:50 PM
Didn't the Stiletto cats use Nomex cores?
I thought I saw a honeycomb core on one which had a porthole removed for replacement...
Re: Dagger Repair [Re: waterbug_wpb] #266315
10/15/13 06:29 PM
10/15/13 06:29 PM
Bille Offline
Bille  Offline
OUCH -- this will boarder-line on Mean :
http://stiletto.wildjibe.com/portfolio/Port_4/photo_15.jpg
And that is why northsea junkie said this :
Originally Posted by northsea junkie
I'm still very surprised that they use it in boatbuilding. If you have followed the last Volvo ocean races, you certainly have seen the complete delaminated panels on the Imoca boats (all with honeycomb sandwhich core).
Bille
Re: Dagger Repair [Re: yurdle] #266316
10/15/13 07:10 PM
10/15/13 07:10 PM
Marstrom boats use a nomex core. At least their Tornado did.
Re: Dagger Repair [Re: yurdle] #266342
10/17/13 05:27 PM
10/17/13 05:27 PM
maui
jollyrodgers Offline
maui
@bille Adding resin to your example is what i am describing.
A tshirt saturated with rein won't soak up water after curing, but if you were to sand the edge exposing the fibers, would the fibers be able to soak up water?
My contention is that after carbon or glass is saturated with resin, even if you sand the edge, exposing fibers, that the fibers won't soak up much water. You can dry it off, lightly skuff it and bond to it/paint it etc.
If you try that experiment with kevlar water will soak in and if it's salt water you will never get the salt out.
You will need to glass the salt in and the fuzz down; being careful not to sand back thru.
There is a whole big thread out there in cyberworld about honeycomb & Acats. Some of them use it.
Billl Higgins' Stilletos most definitely were made using aircraft honeycomb and prepreg.
Problems with honeycomb delam seem to be worked out. Once honey comb got to Tornados, they never looked back.
They still have wood rudders and maybe the boards too. I think he does prepreg over the wood.
Also there were honeycomb surf boards in the 60's that are still around today.
So all the cool kids have honeycomb/prepreg these days. i assume: the AC 45's and 72's, some Ccats, those big 60 and 70' tris, but that isn't my field so not 100 percent sure about some of those boats.
As for trailing edge thickness-it's personal taste. You want them as thick as possible without slowing you down too much.. I think if you leave it perfectly squared off. you will get humm. rounded corners-no humm, but is it slower?
for future readers: For this particular repair it sounds like; try a small fill job first, and if it keeps chipping off, make it into a bigger job. one way would be to grind both sides down enough- (roughly the thickness of 3 layers of material), say 2-3" in from the trailing edge, so that after you glass it, the result will fair down nicely. The stronger the materials that you use, the better the repair will last. And off course customize the the trunk so that it isn't as likely to damage your precious foil.
Re: Dagger Repair [Re: jollyrodgers] #266346
10/18/13 03:37 AM
10/18/13 03:37 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
For hum, sanding the trailing edge at an angle can get rid of it.
Re: Dagger Repair [Re: jollyrodgers] #266354
10/18/13 07:05 AM
10/18/13 07:05 AM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
@bille
What how??????????
Did you ever have a sheet of honeycomb in your hands and start wondering how in heavens name the exterieur laminate layers should bond to the extremely thin headsides of the honey comb. (without loosing too much weight in extra connections)
ronald
RAIDER-15 (homebuilt)
Re: Dagger Repair [Re: yurdle] #266358
10/18/13 10:31 AM
10/18/13 10:31 AM
Bille Offline
Bille  Offline
There's a test the Gov labs do to a honeycomb laminate
called the Peal-ply test ; they glue one side down, and
measure how much force it takes to remove the exposed side
from the honeycomb panel. Optimum skin weight for peal resistance
is 10oz skin or better. Adding more thickened epoxy
to disperse the energy to the cell walls, will add more weight.
I totally trust my Exxtacy to Not De-laminate while
i'm flying. But if it's Water i'm asking the honeycomb
to deal with than i'd keep the lamination width limited
to 1 inch strips to isolate the tears in a De-lam panel.
Remember they use honeycomb in the fins of Very high
speed rockets and also in some fighter-jet structures, and
it holds up Well ; i would Never trust my life to the stuff
on a boat , unless special precautions were utilized !!!
Bille
Re: Dagger Repair [Re: yurdle] #273284
06/19/14 05:19 AM
06/19/14 05:19 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Digging up an old thread -
Goodall Design just published a series of videos on proper dagger/rudder trailing edge repair. Link here
Looks like I have a fun little project before the next regatta. Anyone have a preferred source for carbon cloth?
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Dagger Repair [Re: rehmbo] #273291
06/19/14 09:55 AM
06/19/14 09:55 AM
uscomposites.com
Re: Dagger Repair [Re: rehmbo] #273295
06/19/14 02:28 PM
06/19/14 02:28 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
That was the best use of 7 minutes in quite some time.
F18 USA 242
http://www.solarwind.solar
Re: Dagger Repair [Re: rehmbo] #273422
06/24/14 05:37 AM
06/24/14 05:37 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Thanks for sharing those links. Certainly made it look easy!
Page 3 of 3 1 2 3
0 registered members (), 532 guests, and 111 spiders.
