| Loose beam bolt #269068 02/04/14 03:15 AM 02/04/14 03:15 AM |
Joined: Aug 2011 Posts: 182 Grafton, NSW Greg/Debra OP
Posts: 182 Grafton, NSW | I just tried to tighten my beam bolts and found that one of the rear beam bolts is loose, and can't be tightened - it just turns.
So how do I deal with this?
Thanks, Greg.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
| | | Re: Loose beam bolt
[Re: Greg/Debra]
#269070 02/04/14 04:49 AM 02/04/14 04:49 AM | thricebitten
| thricebitten
Unregistered | Hi Greg,
so is this on a timber boat?
Most timber boats have bolts with nuts under the beam pads. Usualy need a spanner to hold the nut underneath while you turn bolt above. But I guess its possible that they have threaded plates in place like glass boats, in which case you can buy next size bigger in diametre of bolt and tap out the plate to same size, or put a nut on the end of existing bolt if it's long enough (or buy a longer one). | | | Re: Loose beam bolt
[Re: Greg/Debra]
#269072 02/04/14 04:57 AM 02/04/14 04:57 AM |
Posts: 182 Grafton, NSW | Hi Gary,
The bolt in question is an inner one (plywood boat, 1434) so how on earth do you get a spanner inside the beam to get at the bolt (or nut)?
Thanks, Greg.
| | | Re: Loose beam bolt
[Re: Greg/Debra]
#269087 02/04/14 03:30 PM 02/04/14 03:30 PM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate
Posts: 858 Victoria Australia | I had the same probs on Jurassic Karp when I stripped it down. I chopped up an old 13mm ring/open ended spanner and welded in a nice bit of 3mm stainless flat to extend the daylights out of that spanner.... or you could make one from any bit of flat bar that will fit into the beam and by simply cutting a 'slot' in the bar that will fit the nut and your away..... Remember you'll have the re-install to do or future re-tightens to do so its worth making a half decent unit.  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: Loose beam bolt
[Re: Pirate]
#269107 02/05/14 11:25 PM 02/05/14 11:25 PM |
Posts: 182 Grafton, NSW | I chopped up an old 13mm ring/open ended spanner and welded in a nice bit of 3mm stainless flat to extend the daylights out of that spanner.... Hmm... 13mm spanner on a 12.7mm nut, goes on easier in a confined space. Good thinking Kingy! I made the tool as per instructions, except didn't have any stainless flat for the handle, so used tube instead. I will try it out on 1434 on Saturday. I just went to try it out on 1140, but it has the rear beam nuts welded to rectangular washers, so no spanner needed. Checked the main beam bolts on 1140; nuts were done up tight but bolts were loose as in the holes, as nuts had run out of thread. Will now cut a bit more thread on the bolts. Fortunately I don't have Popeye forearms, so didn't get stuck in the holes, but a bit of swearing nevertheless.
| | | Re: Loose beam bolt
[Re: Greg/Debra]
#269120 02/06/14 02:59 PM 02/06/14 02:59 PM |
Posts: 858 Victoria Australia | Here's one I prepared earlier ..... as you can see it reaches easily  ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/190_zps5de75577.jpg) the head of the spanner was just butt-welded directly onto the stainless scrap I had layin around.... ![[Linked Image]](http://i961.photobucket.com/albums/ae97/BADZX/191_zpsa755c8a1.jpg) the ring part was totally useless so it fell onto the grinder. Alternatively, you could always just cut a 13mm wide slot into a bit of high-tensile steel strap with a small grinder.....  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#269298 02/13/14 01:33 AM 02/13/14 01:33 AM |
Posts: 182 Grafton, NSW | The spanner I made worked a treat for holding the nut and getting the old bolt undone. However I could not for the life of me get the nut started on the new bolt, so was after much frustration and swearing ended up giving up and sailing one bolt shy. Grrr I am going to weld the nut onto a rectangular washer and grind a point on the new bolt to make it easier to locate the hole in the nut.
| | | Re: Loose beam bolt
[Re: Greg/Debra]
#269350 02/13/14 10:20 PM 02/13/14 10:20 PM |
Posts: 182 Grafton, NSW | Hi Phillip,
The bolts are 5/16" UNC, with 1/2"AF heads and nuts. And yes I will clean up the threads after grinding.
179
guests, and 32
