[Prindle 19] Holes in mast #269440
02/17/14 05:49 AM
02/17/14 05:49 AM
Ameland Offline OP
Ameland  Offline OP
Hi all,
After a few years of sailing with friends, I bought my own catamaran. This cat is not used in recent years, and needs some maintenance before the season starts.
There are two holes at the base of the mast (7 and 8 mm) that I thought where missing rivets however, I cannot find rivets in that size can someone tell me what belongs in this holes or how I can fix this?
Also, there are two bolts from the rear beam bent I've already looked at Murrays but I'm not sure which one i need. i need the countersunks bolts and the normal bolts are these deliverid complete? so including nylon spacer washer and nut?
thanks
Re: [Prindle 19] Holes in mast [Re: Ameland] #269442
02/17/14 06:09 AM
02/17/14 06:09 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Those holes sound like your mast rotation spanner, is it missing by any chance?
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: [Prindle 19] Holes in mast [Re: Ameland] #269443
02/17/14 06:20 AM
02/17/14 06:20 AM
Ameland Offline OP
Ameland  Offline OP
No i don't think so it is realy at the base below the gooseneck in the middle of the mast I'm not sure wich side.
Re: [Prindle 19] Holes in mast [Re: Ameland] #269450
02/17/14 09:45 AM
02/17/14 09:45 AM
some photos will really help us help.
Re: [Prindle 19] Holes in mast [Re: Jake] #269458
02/17/14 02:25 PM
02/17/14 02:25 PM
Ameland Offline OP
Ameland  Offline OP
I Will make some photos this weekend.
Re: [Prindle 19] Holes in mast [Re: Ameland] #269469
02/18/14 06:03 AM
02/18/14 06:03 AM
H
Hullflyer1 Offline
Hullflyer1  Offline
H
It sounds like the holes are located where the original small cheek blocks were for the down haul, which I believe was a 5 to 1. Most sailors upgraded this original system
Re: [Prindle 19] Holes in mast [Re: Ameland] #269507
02/18/14 03:13 PM
02/18/14 03:13 PM
Miami, FL
John McKnight Offline
Miami, FL
I used a product called JB Weld to patch some holes in my mast. The patches are holding up just fine. You should be able to find JB Weld at Home Depot in the glue section.
Re: [Prindle 19] Holes in mast [Re: Ameland] #269775
03/02/14 09:00 AM
03/02/14 09:00 AM
Ameland Offline OP
Ameland  Offline OP
Re: [Prindle 19] Holes in mast [Re: Ameland] #269776
03/02/14 09:00 AM
03/02/14 09:00 AM
Ameland Offline OP
Ameland  Offline OP
Re: [Prindle 19] Holes in mast [Re: Ameland] #269777
03/02/14 09:37 AM
03/02/14 09:37 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Aluminum rivet with 3m 5200 or sikaflex around it and over the hole in the center of the rivet should do fine.
Isak Dinesen
E. B. White
Re: [Prindle 19] Holes in mast [Re: Ameland] #269826
03/04/14 12:08 PM
03/04/14 12:08 PM
Ameland Offline OP
Ameland  Offline OP
I can ' t fint rivet in That size the hoes arena to big for 6 mm rivets ..
Re: [Prindle 19] Holes in mast [Re: Ameland] #269862
03/05/14 08:54 AM
03/05/14 08:54 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
It looks like a block, maybe a jib downhaul went there?
YOu could also just silicone a large threaded screw into the holes. Doesn't look to be a structural issue, from those pics anyways.
The P19 is a nice boat.
F-18 Infusion
#626- SOLD it!
Re: [Prindle 19] Holes in mast [Re: Ameland] #269893
03/05/14 07:32 PM
03/05/14 07:32 PM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
I don't think anything bad will happen if you live it like that, it's more an aesthetic repair to me. Maybe just use that duct tape on the picture.. The only way to fill the mast with water from that hole is if you turtle, but that is not supposed to happen. And if it happens most likely there will be water inside already.
Re: [Prindle 19] Holes in mast [Re: Ameland] #269895
03/05/14 08:13 PM
03/05/14 08:13 PM
Forego the rivet and just use 5200. All you really need to do is seal the mast.DO NOT put a stainless steel bolt or rivet in the hole just to fill it. Stainless will cause galvanic reaction and you don't need the strength of stainless for anything in that repair.
Isak Dinesen
E. B. White
0 registered members (), 306 guests, and 86 spiders.
Posts267,059
