by soulsailor. 03/11/25 11:57 AM
Page 1 of 5 1 2 3 4 5
The Everglades Challenge #269690
02/25/14 07:52 AM
02/25/14 07:52 AM
Jake Offline OP
Jake  Offline OP
I depart tomorrow afternoon for an adventure with Alan Stewart aboard his custom built 22' trimaran "Mosquito". We're taking part in the Everglades Challenge which is part of several challenge events run by the Watertribe (watertribe.com). The race starts just north of Tampa Bay in Fort Desoto Park and finishes in Key Largo. Other than requirements for safety and survival gear, the only real restrictions are that you must launch your boat from the high tide mark (restricts boat design somewhat) and there are three checkpoints we have to visit along the way. In years past, some of these checkpoints were behind bridges that restricted the boat designs (dropping masts, maximum beam, etc.) but this year there are no more bridges or other obstructions along the way. You don't have to do anything other than sign a log book and ping your Spot tracker while "presenting your boat" at the checkpoints. You can stay a while and reprovision if you wish...or just turn around and keep on trucking. Two of the three checkpoints are relatively easy to access but the middle one, Chokoloskee, requires navigating several creeks and over extended distances of shallow mucky water. The backside of the keys in Florida Bay can also be a real challenge and we will have a choice to either pick our way through the shallow Florida Bay or sailing around it and essentially take the Key Largo Steeplechase route back to Key Largo. This race has 144 entries (last I checked) that range everywhere from stand up paddle boards, kayaks, kayaks with sails, to our 24' trimaran and everything anyone can come up with in between. Boats are divided up into 6 different classifications for the race. We're in class 5 "small sailing multihulls" and we're hoping to present a threat to be near the front in Class 5. With regards to our sleep and rest plans...that all depends on how close to the front we are or how closely we're being chased smile . Every competitor has a Spot tracker and you will be able to follow the race here:
http://www.watertribe.com/Events/ChallengeGMapper.aspx?RaceID=EC2014
Here's a video from last weekend and a couple of pictures of Alan's trimaran we're sailing. We haven't had much time to test and tune since we made several changes to the boat. My early impressions are that we may struggle a little going hard to weather until we get a chance to work on some trimming techniques but the boat is proving to be a real monster on reaching angles (especially with the giant code 0 Alan has equipped it with). We're carrying sails on a recycled F18HT mast with a square top main, roller furling jib, roller furling code 0, and an F18 spinnaker. We were able to do better than double wind speed on Lake Keowee last weekend and we'll be able to figure some new things along the way.
Alan's blog will also have some information here and I'll probably be posting some stuff to my facebook wall (Jake Kohl).
http://www.sailnaway.blogspot.com/
Re: The Everglades Challenge [Re: Jake] #269691
02/25/14 08:11 AM
02/25/14 08:11 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Good luck!
Re: The Everglades Challenge [Re: Jake] #269692
02/25/14 08:20 AM
02/25/14 08:20 AM
pgp Offline
pgp  Offline
Very cool looking boat, all the best!
Pete Pollard
Blade 702
Re: The Everglades Challenge [Re: Jake] #269694
02/25/14 08:50 AM
02/25/14 08:50 AM
Good luck, looks like a great adventure!
Is there a mandatory amount of sleep or can you sail 24/7?
Re: The Everglades Challenge [Re: Tony_F18] #269695
02/25/14 09:16 AM
02/25/14 09:16 AM
Jake Offline OP
Jake  Offline OP
No sleep requirements whatsoever. The race record is just over 28 hours on an Olympic Tornado (Jamie Livingston / Kenny Pierce). The center hatch on Alan's tri has a subdeck under it and it's sized to be able to crawl into and lay prone to do something resembling sleep.
Alan and his dad currently own the monohull record of just over two days and he and his mom own the current 1,200 mile Ultimate Florida event record as well.
Re: The Everglades Challenge [Re: Jake] #269696
02/25/14 09:47 AM
02/25/14 09:47 AM
brucat Offline
brucat  Offline
St Pete to Key Largo on a SUP?????
Re: The Everglades Challenge [Re: Jake] #269697
02/25/14 09:53 AM
02/25/14 09:53 AM
M
MN3
MN3
M
good luck, I hope to be out there fri afternoon for a walk around to look at all the cool designs.
Re: The Everglades Challenge [Re: Jake] #269698
02/25/14 10:46 AM
02/25/14 10:46 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
Good luck you guys!
F18 USA 242
http://www.solarwind.solar
Re: The Everglades Challenge [Re: David Ingram] #269717
02/26/14 10:20 AM
02/26/14 10:20 AM
Jake, if you're going to attempt a "modicum of sleep like behavior" in that tunnel berth I'd suggest those little foam earplugs. They'll deaden a lot (but not all) of the noise.
I suspect that inside that berth will sound like a wooden barrel rolling down a rocky slope.
Re: The Everglades Challenge [Re: waterbug_wpb] #269718
02/26/14 10:24 AM
02/26/14 10:24 AM
and what's your team name? I think I see SOS, which I think is Alan, right?
Uh, hello?.... It shows you still in Wilmington. Isn't that a bit far from the start? Or did you not turn on your spot?
Re: The Everglades Challenge [Re: waterbug_wpb] #269725
02/26/14 04:12 PM
02/26/14 04:12 PM
also, remember. You don't play "Hide and Seek" with Kenny (MachoMan), you play "Hide and pray he doesn't find you"
Re: The Everglades Challenge [Re: Jake] #269726
02/26/14 06:12 PM
02/26/14 06:12 PM
catandahalf Offline
catandahalf  Offline
Jake,
I wish you and your skipper the best. Ron White and Mike Fahle on the former 1992 Olympic sailed Tornado, Jamie and Kenny aboard their Tornado, Randy on his homebuilt tri, and Meade Gougeon are names worth mentioning. The talent in the tribe, and the spirit of the Challenge will last a lifetime.
Enjoy the journey,
Bert
Re: The Everglades Challenge [Re: Jake] #269738
02/27/14 07:57 AM
02/27/14 07:57 AM
Syracuse, NY Hobie Fleet 204
Tom Korz Offline
Tom Korz  Offline
Good Luck Jake and Alan!!!
Have heard nothing but great things about the Watertribe events.
Re: The Everglades Challenge [Re: Jake] #269758
03/01/14 08:39 AM
03/01/14 08:39 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Looks like there off to a good start. Appears to be a moderate beam reach conditions off Bradenton beach.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: The Everglades Challenge [Re: rehmbo] #269759
03/01/14 09:50 AM
03/01/14 09:50 AM
Jake Offline OP
Jake  Offline OP
I'm on a boat. I'm not going to tell you how, but we have technology baby! We are making good time on a straight line down the coast. Smyth is slowly getting out of site. Alan and I are leaving the tornados behind and have about lost sight of them. Jamie and Kenny had some sort of problem and headed back. I can't get to the tracking site to see if they're back out or not...hope so.
Re: The Everglades Challenge [Re: catandahalf] #269760
03/01/14 09:51 AM
03/01/14 09:51 AM
Jake Offline OP
Jake  Offline OP
Originally Posted by catandahalf
Jake,
Enjoy the journey,
Bert
Mike fahle didn't make it for some reason. I gotta get back to sailing before Alan yells at me.
Re: The Everglades Challenge [Re: waterbug_wpb] #269761
03/01/14 09:54 AM
03/01/14 09:54 AM
Jake Offline OP
Jake  Offline OP
Yes...SOS
Re: The Everglades Challenge [Re: Jake] #269762
03/01/14 10:13 AM
03/01/14 10:13 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Keep it coming. Seems like the tracking site is overloaded at the moment.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: The Everglades Challenge [Re: Jake] #269763
03/01/14 10:24 AM
03/01/14 10:24 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
The tracker worked for me for about 2 hours, Looked like Jake and Alan had a early lead. Couldn't see Smyth on there, is he not in class 5?
Re: The Everglades Challenge [Re: Jake] #269764
03/01/14 10:41 AM
03/01/14 10:41 AM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Good luck Jake and Alan. I'm jealous, as every year.
The tracker is overloaded. Discussion and FB said Jamie and Kenny are "out with a busted rudder." I hope they have a spare at the beach if nothing else. Randy is notorious for "forgetting" to turn on his tracker.
Isak Dinesen
E. B. White
0 registered members (), 901 guests, and 37 spiders.
Posts267,060
