| Mast stepping help #27298 12/28/03 11:29 PM 12/28/03 11:29 PM |
Posts: 324 South Florida | Hi there!!
Can anyone recommend a mast stepping device to raise the mast on my Hobie 18?? I find I am not going sailing as much as I would like because of the issue with raising the mast. I know there are three devices in the Hobie catalog but I would like to hear from someone who has used any of them to let me know what they think.
Thanks,
Fred F
(ex Hobie 18)
| | | Re: Mast stepping help
[Re: SOMA]
#27301 12/29/03 01:40 PM 12/29/03 01:40 PM |
Posts: 248 Colorado | I've used the EZ Stepper and find that I don't really need it. It works fine, but there's almost always someone around to help me lift the mast, which is the only step in the process that requires help.
The one scary part of raising the mast is keeping it from swaying side to side. The EZ Stepper comes with a couple of lines that you tie from the cross bar to the forward trapeze, but it's tough to get them just the right length so that they don't bind when the mast is going up. Now I use quickly adjustable tie-down straps, the kind with hooks on each end, so that I can easly pop them loose. Depending on he wind strength, I'll use them as a safety precaution even if I have lots of help. If it's calm I can toss my H-20 mast up quickly without the safety straps, but it can get out of hand in a hurry if it's windy and it only takes a moment to hank on the safety hooks.
H-20 #896
[Re: Brendan]
#27304 12/30/03 04:16 PM 12/30/03 04:16 PM |
Posts: 2,844 42.904444 N; 88.008586 W | Brenden,
If you're having difficulty with ONE person, on a h16 mast, I think you should be looking at technique, etc, not these mast rig devices.
ON the H16, when the mast is down before lifting, the traps with their bungees slide to the back of the tramp, then as you lift, you're working against a tight trap bungee. Have someone slide the bungess forward as you lift the mast.
Good luck
F-18 Infusion #626- SOLD it!
[Re: SOMA]
#27305 12/30/03 06:55 PM 12/30/03 06:55 PM |
Posts: 324 South Florida | Thanks guys, My trouble is with the raising part. The thing weighs a ton, plus I put a Hobie bob to the tip which makes it even heavier!! I think I'm going to try the EZ step. It didn't make my Christmas list but I'll make sure my wife knows it is at the top of my birthday list!  Good sailing!
Fred F
(ex Hobie 18)
[Re: DVL]
#27306 12/30/03 08:50 PM 12/30/03 08:50 PM |
Posts: 1,911 South Florida & the Keys | something is wrong. I used to step my H-21 SE mast solo with the EZ step. My crew was always late........
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Mast stepping help
[Re: Brendan]
#27308 01/01/04 02:14 PM 01/01/04 02:14 PM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | Back in the old days, I used to step the mast on my Hobie 16 by myself all the time. I would tie a line to the end of the forestay, run it through the shackle or around the bridle itself, and back to the front crossbeam. After I stepped the mast, I'd reach down and grab the line on the front crossbeam, pull out the slack, and tie it off there or cleat it off. Then, go foreward and pin the forestay to the bridle. Done. This was in the early 80's, but I don't think the set up has changed much over the years.
Good luck.
Don Cook
ARC22 #2226
ADRENALIN
305
guests, and 197
