| Re: Hanging a boat from the rafters
[Re: Beckit 1824]
#274767 08/15/14 09:26 PM 08/15/14 09:26 PM |
Posts: 416 | | | | Re: Hanging a boat from the rafters
[Re: Beckit 1824]
#274773 08/16/14 08:10 PM 08/16/14 08:10 PM |
Posts: 1,383 Kingston SE South Australia | I have two hanging in my shed, You don't need a winch, I use the main sheet blocks attached to the main beam if hoisting on my own and just a single rope at the rear. To get it right to the rafters it needs a rope on each bow and stern for the last bit and tie off with those
[Re: Beckit 1824]
#274775 08/17/14 03:31 AM 08/17/14 03:31 AM | thricebitten
| thricebitten
Unregistered | Hey Luke, Why not take the boat with you, the local YC even shows a Hobie on their website, must be some OTB sailing  . But if you have to hang it from the rafters, I recently hung mine with a couple of heavy tie down straps hooked in to the ends of the main beam which then went over the deck, under the main beam and hooked together with 6 to 1 tackle in the middle, then a light tackle hooked to the middle of the rear beam. | | | Re: Hanging a boat from the rafters
[Re: Beckit 1824]
#274779 08/17/14 04:47 AM 08/17/14 04:47 AM |
Posts: 1,383 Kingston SE South Australia | Definitely hatch covers on, It's amazing how much crap birds and mice can drag in, tried to buy a Stingray once and one hull would have weighed 200kg from the honeycomb. If your mates going to weld or grind, decks up, if birds are going to stand on top and repaint for you decks down. Take it as far as you can with the main sheet, then take it the last foot with the extra 4 ropes. When going up most of the weight is on the main beam the rear rope is just to take it up level, when near the top sway to one side tie of front and rear then do the other side, tie the mast next to it.
[Re: JeffS]
#274780 08/17/14 05:51 AM 08/17/14 05:51 AM |
Joined: Apr 2013 Posts: 858 Victoria Australia Pirate
Posts: 858 Victoria Australia | Put about a cup full of kitty-litter in an open plastic bag Make 4 bags like that and place one down each hatch hole (condensation catching done) Remove sponges or other bits you may normally 'store' in the hulls Hatch covers on but NOT tight ( bottom out the threads then back them off half a turn) St Vinnies.... Grab an old WOOLEN blanket or 3, lay one over the tramp area and cut the others to cover the fore & rear decks ...... use butchers twine to tie it in place if wind is a problem in the shed The wool will act as a heat insulate, absorb bird-poop etc and is more flame resistant than most other "cheap covers" like blue tarps, plastic drop sheets, cardboard etc Best NOT to lay items like boards, rudders, sailbags on the boat but to store them separately IE: hang them independent of the boat.... Place a few rodent baits on the woollen cover and a couple with any other stored gear Hoist up and tie in place from the Beams only....... remember mice etc love to chew so choose wisely as to what material you use to do the final 'tie' with  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
Kingy started with Impara Cadet #3 / Mosquito #245 & now Mosquitos #1182 & #1740 | | | Re: Hanging a boat from the rafters
[Re: Beckit 1824]
#274782 08/17/14 06:27 AM 08/17/14 06:27 AM |
Posts: 1,383 Kingston SE South Australia | Good point about the rat baits, in my loft I have icecream containers with holes cut in the side that I put rat blocks in. Don't need to worry about condensation, inside the top of a shed is pretty warm most days, I've got a boat that's been hanging for 3 years and it's perfectly dry
[Re: JeffS]
#274783 08/17/14 07:02 AM 08/17/14 07:02 AM |
Posts: 858 Victoria Australia | The kitty-litter isn't for the moisture in the hulls, it's for the condsation on the underside of the sheds roof ..... This drips down off of the purlins and the onto the boat ... Wrong drip in the right place could get past the hatch cover and over time cause issues ..... Cheap insurance in my book  That reminds me of one we've all forgotten ...... Contact your insurance company and give them the details of the storage time / location /etc  Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Beckit 1824]
#274786 08/17/14 05:50 PM 08/17/14 05:50 PM | Scarecrow
| Scarecrow
Unregistered | Maybe I will get a plastic cat for the birds.
Get a couple of rubber snakes. Given the roof is so high, is there any chance you could pull the trailer up with it?
[Re: Beckit 1824]
#274788 08/17/14 06:29 PM 08/17/14 06:29 PM |
Posts: 1,383 Kingston SE South Australia | If you have someone to help, back into place on trailer, get helper to lift the bows as far as possible then tie blocks to the main beam. Normal sheds wont take the load of a trailer and cat, I'm not sure I would try that but if you do, make sure you position a Go Pro before you start hoisting
[Re: ]
#274791 08/17/14 08:07 PM 08/17/14 08:07 PM |
Posts: 858 Victoria Australia | Get a couple of rubber snakes
Did that .... and five years later when I dragged it down I'd forgotten all about the snakes Needless to say when eye level was only inches from that snake, there was a moment where a little bit of poo may have escaped Yar, & this ere post be done without a sin'le drop o' rum passin' me lips
[Re: Pirate]
#274793 08/17/14 08:40 PM 08/17/14 08:40 PM | Scarecrow
| Scarecrow
Unregistered | Get a couple of rubber snakes
Did that .... and five years later when I dragged it down I'd forgotten all about the snakes Needless to say when eye level was only inches from that snake, there was a moment where a little bit of poo may have escaped also worth taping a sign on the bottom reminding you about the snakes. And take the tramp off. | | | Re: Hanging a boat from the rafters
[Re: Beckit 1824]
#274797 08/18/14 01:51 AM 08/18/14 01:51 AM |
Posts: 182 Grafton, NSW | Plastic cat? Rubber snakes?? There must be some dumb vermin around. The rats here are very smart, cunning and malevolent. Some times they eat things they don't even like just to be vindictive.
1140 Gadfly 1434 J.I.B.E. 1727 Atreus
[Re: Beckit 1824]
#274798 08/18/14 02:50 AM 08/18/14 02:50 AM |
Joined: Mar 2003 Posts: 943 East Gippsland, Australia Tim_Mozzie
Posts: 943 East Gippsland, Australia | I took delivery of Whiteside Express complete with a Possum carcas inside. It was a hell of a job to get out and bones and bits of fur kept appearing for years. The smell never went away!!
Hatches on (loosely) I think.
Tim Shepperd Mosquito 1775 Karma Cat
[Re: Beckit 1824]
#274854 08/19/14 06:45 PM 08/19/14 06:45 PM |
Posts: 1,383 Kingston SE South Australia | Boat safely in the rafters thanks gents. The only downside was one of the kitty litter containers going over whilst hoisting but that is going to have to wait. Luke Hopefully there won't be too many cats that make use of it while your gone
1 registered members (soulofasailor),
1,803
guests, and 18
