by soulsailor. 03/11/25 11:57 AM
Walk me through this #275142
09/02/14 10:56 AM
09/02/14 10:56 AM
waterbug_wpb Offline OP
Needing to pull the daggarboard out for gelcoat fairing.
Questions:
- Looks like some sort of adhesive between base plate and deck. Any thoughts on non-destructive removal?
- recommended sealant between plate and deck when I reinstall?
- when I replace the screws, should I consider bedding in thickened epoxy (assuming they're just screwed into the sandwich material)? If so, will I be able to remove them in the future? Should I wax the screws?
Re: Walk me through this [Re: waterbug_wpb] #275150
09/02/14 03:20 PM
09/02/14 03:20 PM
Pray to your favorite god that it isn't 3M 5200.
But it looks like regular polysulphide caulk (Boatlife).
Remove the screws and try levering it off. Maybe run a box cutter around the edge to help break the seal.
No way screws would be set in a sandwich material. See what they look like when they come out.
Re: Walk me through this [Re: mbounds] #275151
09/02/14 03:55 PM
09/02/14 03:55 PM
Quebec, Canada
A. Bourgault Offline
Quebec, Canada
I would remove the screw and heat the plate gently with a propane torch until it comes off.
Re: Walk me through this [Re: waterbug_wpb] #275152
09/02/14 05:17 PM
09/02/14 05:17 PM
well...first, remove the screws and see if you can gently pry it up. You might be surprised. If not, use a 5200 remover and soak the area (it will degrade any 5200 that it comes in contact with - so keep this in mind). Let that soak a while and remove the parts. The blade under the edge might give it some incentive and might help work the remover into the joint a little if it is problematic.
Reseal it with Sikaflex UV.
Re: Walk me through this [Re: Jake] #275153
09/03/14 08:52 AM
09/03/14 08:52 AM
Thanks!
Re: Walk me through this [Re: waterbug_wpb] #275180
09/05/14 09:54 AM
09/05/14 09:54 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
What is that a picture of?
F-18 Infusion
#626- SOLD it!
Re: Walk me through this [Re: Todd_Sails] #275181
09/05/14 10:14 AM
09/05/14 10:14 AM
that's the top of the daggarboard trunk. The mast base sits on that plate/ball
Re: Walk me through this [Re: waterbug_wpb] #275195
09/06/14 05:27 PM
09/06/14 05:27 PM
Todd_Sails Offline
Todd_Sails  Offline
OK, Daggerboard trunk, that a mast base sits on,
again, what are we looking at? I.E. What Boat is that?
F-18 Infusion
#626- SOLD it!
Re: Walk me through this [Re: Todd_Sails] #275211
09/08/14 08:35 AM
09/08/14 08:35 AM
apologies. Corsair F24-2
Yeah, it's not a cat, but you twerps have a pretty good experience base in composites, foils and lightweight multihulls...
0 registered members (), 901 guests, and 37 spiders.
Posts267,060
