Re: heavy downhaul in light air [Re: rehmbo] #277589
02/13/15 02:00 PM
02/13/15 02:00 PM
Was it Bethwait who indicated the AWA in laminar flow (light) air is up to 10 - 20 degrees different at the top of the mast than at the water level?
But I see the greatest (personal) need for downhaul to keep the leech from hooking...
Re: heavy downhaul in light air [Re: ] #277590
02/13/15 05:30 PM
02/13/15 05:30 PM
That's my reason for pounding on the downhaul in light air, to keep the leech from hooking and keeping a continual shape. Softer battens would also help, but I'm not a huge fan of dropping a main on the water unless it is going to stay down. Singlehanded its a frickin' pain in the butt to pull it up, and keep the boat more or less in the wind.
Re: heavy downhaul in light air [Re: Karl_Brogger] #277591
02/13/15 05:50 PM
02/13/15 05:50 PM
You should try that with beach wheels still tied under the hulls.
Re: heavy downhaul in light air [Re: ] #277592
02/13/15 07:56 PM
02/13/15 07:56 PM
I've heard that works like a champ....
Re: heavy downhaul in light air [Re: Jake] #277594
02/14/15 09:14 AM
02/14/15 09:14 AM
man, that gets funnier every time you say it Jake smile especially since you're a good sailor!
Re: heavy downhaul in light air [Re: Karl_Brogger] #277596
02/14/15 11:23 PM
02/14/15 11:23 PM
brucat Offline
brucat  Offline
Should have stayed with the Hobie 16, and attended more NAs. In RI in 2006, before the first race (in heavy air and huge seas), one of the Mexican teams intentionally capsized the boat, so they could adjust battens.
Can't make that stuff up...
Re: heavy downhaul in light air [Re: brucat] #277599
02/15/15 09:09 AM
02/15/15 09:09 AM
when spreader rake was all the rage in the a-cats a few years ago, you would see them capsizing the boat all the time to make an adjustment to the spreaders.
Re: heavy downhaul in light air [Re: Jake] #277600
02/15/15 09:37 AM
02/15/15 09:37 AM
why isn't spreader rake "all the rage" now? Did something change with sail/mast design?
Re: heavy downhaul in light air [Re: ] #277601
02/15/15 10:16 AM
02/15/15 10:16 AM
I think they went back to adjusting tension.
Re: heavy downhaul in light air [Re: waterbug_wpb] #277603
02/15/15 10:59 AM
02/15/15 10:59 AM
I think that whole thing started because Ashby did it once.
Re: heavy downhaul in light air [Re: ] #277604
02/15/15 12:50 PM
02/15/15 12:50 PM
brucat Offline
brucat  Offline
That's usually all it takes!
Re: heavy downhaul in light air [Re: ] #277608
02/15/15 06:13 PM
02/15/15 06:13 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
We capsized the F18 to work on the spin halyard between races once, kinda sucked but it beat missing a race to return to the beach.
Re: heavy downhaul in light air [Re: bacho] #277609
02/15/15 09:01 PM
02/15/15 09:01 PM
dr5e14w Offline
dr5e14w  Offline
Changing the spreader rake was easier than trying to adjust indivual wires for port and starboard to get them to balance. I've watched mischa go up his mast between races to move his wires On the f18. There is definitely something to it but it all depends on what you're trying to accomplish.
Re: heavy downhaul in light air [Re: Jake] #277612
02/16/15 09:23 AM
02/16/15 09:23 AM
I'll bet he does stuff like that once in a while just to F with you guys....
"Look, he painted his daggarboards pink. It must be faster" and then there's a run on pink gelcoat the next week...
For someone who can make a 4x8 piece of plywood somehow sail fast, it must be fun to make the occasional poke at us luddites...
