Spreaders #278968
05/11/15 09:15 PM
05/11/15 09:15 PM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Would this be legal and worthwhile on a Mossie??......sorry in advance as I haven't checked the class rules.
http://www.a-cat.org/?q=node/551
Nic Maan
Sanity 1815
Re: Spreaders [Re: Nic M] #278989
05/12/15 10:30 PM
05/12/15 10:30 PM
Matt_Stone Offline
Matt_Stone  Offline
Just says one set of spreaders. But why would you. Keep it simple.
Look into it harder. If you fiddle with rake means that you will weed to tention the diamonds along with the spreaders.
Philip Pearce has ajustable diamonds on a leaver at the bottom of mast.
My opinion is that keep it simple. The rake and tension of the diamonds depends on your weight and how flexible is the mast and how much you want to de-power.
I set mine 10mm - 15mm foward of the mast track and set the diamonds to a rought tension of 25 on the loose gauge
Matt
Re: Spreaders [Re: Matt_Stone] #278994
05/13/15 04:13 AM
05/13/15 04:13 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by Matt_Stone
..... Philip Pearce has ajustable diamonds on a leaver at the bottom of mast.....
JurassicKarp has a similar setup smile
..... The rake and tension of the diamonds depends on your weight and how flexible is the mast and how much you want to de-power.
little more info please..... IE lightweight sailor with a new mast V's heavier sailor with an old mast ????
confused
Kingy
& now Mosquitos #1182 & #1740
0 registered members (), 1,466 guests, and 43 spiders.
