| Re: Mast transport on a motorhome
[Re: Qb2]
#280324 08/26/15 09:42 AM 08/26/15 09:42 AM |
Posts: 12,310 South Carolina | I've done all sorts of stuff there. Have you thought about a 2 or 3 foot hitch extension to move the trailer further back to allow room for the mast?
I've welded up and mounted steel mounts to the roof of my past RVs (wrapped the arms in rope to provide some padding). Cut small access holes in the ceiling skin to tighten the nuts and used milk jug caps to fill fill the ceiling holes lightly siliconed in place. Use plenty of 3M 5200 under the brackets outside if going this route. It's a bit of a pain heaving the mast up and down and also consider how the spreaders will stick out when considering other roof mounted objects and the outside perimeter of the RV (having the spreaders extend past the wall of the RV is probably not a great idea).
The best solution I came up with was to extend the tongue of my trailer. I added something like 6 or 8 feet and put in a new set of bracing on the sides of the main tongue member. It took a bit of work but it made everything super easy and avoided climbing up on the roof in the rain and so forth.
Jake Kohl | | | Re: Mast transport on a motorhome
[Re: srm]
#280361 08/30/15 09:51 AM 08/30/15 09:51 AM |
Posts: 12,310 South Carolina | How about hanging it from the side of the RV? Something similar to garage ladder racks. I would guess an A cat mast probably weighs about 20lbs, so not much weight.
sm Yeah, but the general life and abuse of an RV (getting stuck in tight places and so forth) will see it rub an occasional tree. The mast would be pretty exposed to potential damage hanging on the side.
[Re: Qb2]
#280463 09/08/15 01:38 PM 09/08/15 01:38 PM |
Joined: Apr 2005 Posts: 473 Panama City, Florida Redtwin
Posts: 473 Panama City, Florida | You have to also be careful not to raise it to the point that the other end gets too low to the road surface. Rob V.
Nacra 5.2
Panama City | | | Re: Mast transport on a motorhome
[Re: brucat]
#280464 09/08/15 04:16 PM 09/08/15 04:16 PM |
Posts: 12,310 South Carolina | I think Jake meant to make the tongue (not mast support) longer. Not sure how much length you'll save just by changing the angle?
One advantage of that approach, though, is to keep the mast away from the rear window. More than one cat sailor has poked a mast through the rear RV window...
Mike I did...the tongue extension - not raising the mast higher. You'll have a hard time getting it high enough to clear the back of an RV without putting the mast support at risk of a structural failure or putting the back of the mast so low that it hits the ground going up sudden inclines (like some gas station entrances).
Jake Kohl | | |
412
guests, and 144
