Weather App #282301
03/29/16 05:55 AM
03/29/16 05:55 AM
Hernando, Florida
M
Mlcreek Offline OP
Mlcreek  Offline OP
M
Hernando, Florida
I've been using weather underground for weather reports. Unfortunately they can't predict it if they were standing in it.
Anyone out there have better suggestions?
Thanks
Forrest
I-20
USA 645
" There ain't enough rum in the drum!"
Re: Weather App [Re: Mlcreek] #282302
03/29/16 07:41 AM
03/29/16 07:41 AM
brucat Offline
brucat  Offline
Here's my rule of thumb:
TV weather: Should I wear more layers?
Wunderground, The Weather Channel sites/apps: What's on the RADAR?
For wind predictions, start with an app such as WindAlert (they've acquired a bunch of others). The quality of the forecasts from these apps varies by location, however, so check around with locals or just monitor a few for a while.
For the best forecasts, there are subscription services. These are definitely location sensitive, especially for a place with complex features (land/water/prevailing flows).
Most times, a combination of the first three is sufficient. When running important regattas in Newport, decisions on where to race (ocean vs bay) or whether (and how long) to postpone ashore can make the paid services invaluable.
Hope this helps.
Re: Weather App [Re: Mlcreek] #282303
03/29/16 07:46 AM
03/29/16 07:46 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
SailFlow, there is a free smart phone app.
F18 USA 242
http://www.solarwind.solar
Re: Weather App [Re: Mlcreek] #282304
03/29/16 07:48 AM
03/29/16 07:48 AM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
Not apps, but two of my favs:
https://www.windyty.com/
https://weatherspark.com/
Accuracy depends on the models they use as reference (and a lot of luck). Supposedly Windyt uses some kind of algorithm to create a mash-up of forecast models that increases accuracy.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Weather App [Re: David Ingram] #282307
03/29/16 08:33 AM
03/29/16 08:33 AM
Hernando, Florida
M
Mlcreek Offline OP
Mlcreek  Offline OP
M
Hernando, Florida
Thanks Ding, I like that one. Thanks to everyone.
Forrest
I-20
USA 645
Re: Weather App [Re: Mlcreek] #282312
03/29/16 02:06 PM
03/29/16 02:06 PM
I have windfinder on my phone which is reasonably accurate (although they are generous on the windspeed forecast... usually about 5 mph faster than actual). They're based on local airport WX stations so they can give you an idea of what you'll see around that area.
Re: Weather App [Re: Mlcreek] #282319
03/30/16 12:53 AM
03/30/16 12:53 AM
cyberspeed Offline
cyberspeed  Offline
I started using PredictWind but everyone got it wrong last weekend. They have free or pro version.
craig van eaton
Supercat 20
TEAM CYBERSPEED
www.TeamCyberspeed.com
Endurance Series
www.SailSeries.com
Re: Weather App [Re: cyberspeed] #282320
03/30/16 05:31 AM
03/30/16 05:31 AM
RickWhite Offline
RickWhite  Offline
I used Sailflow a couple of years ago, until they improved it. Then it was worthless.
So, did they improve it.., really, or did they unimprove it?
Rick White
www.onlinemarinestore.com
Re: Weather App [Re: Mlcreek] #282321
03/30/16 07:27 AM
03/30/16 07:27 AM
brucat Offline
brucat  Offline
Several mentions in this thread of WeatherFlow products (WindAlert, SailFlow), another local favorite is iWindsurf. As I mentioned above, they are related, and definitely have the similar look/feel, if not identical forecasts.
More info: http://www.weatherflow.com/consumer-products/
Makes me wonder how independent the others are?
In any case, no forecast or tool is 100% correct all of the time, and sometimes they are WAY off. The very best (usually paid) include a confidence level, and other things that might happen on a difficult day.
Re: Weather App [Re: RickWhite] #282324
03/30/16 08:59 AM
03/30/16 08:59 AM
Clermont, FL, USA
Clermont, FL, USA
http://www.sailflow.com/ if you like it use it if you don't move on, there are a lot of options. I also use the NOAA site, http://www.srh.noaa.gov/mlb/.
What do you use Rick?
F18 USA 242
Re: Weather App [Re: David Ingram] #282325
03/30/16 02:37 PM
03/30/16 02:37 PM
a wet finger and weather eye.
Re: Weather App [Re: waterbug_wpb] #282327
03/31/16 05:46 AM
03/31/16 05:46 AM
RickWhite Offline
RickWhite  Offline
haha I like Jay's
Actually, here in the Keys and at Put-in-Bay Wunderground has been extremely accurate.., storms plus or minus an hour than predicted, and winds very close in speed and direction.
Rick White
Re: Weather App [Re: Mlcreek] #282328
03/31/16 09:15 AM
03/31/16 09:15 AM
Windguru Pro and this:
