by soulsailor. 03/11/25 11:57 AM
trailer leaf spring corrosion #283090
07/19/16 02:59 PM
07/19/16 02:59 PM
waterbug_wpb Offline OP
Since none of y'all have to dunk your trailers in salt water, I figure you don't worry about this, but for those that do, how to you reduce rust on your leaf springs?
Seems I have to replace mine about every 2 years as large flakes of rust start falling off them.
Rinsed after every salt water dip, and I spray PB blaster and/or WD-40 on them every month or so. Tried axle grease, too but to limited effect. Wondering if painting them would help, or someone's suggestion of melting toilet ring wax (melts around 160 F) and painting it on the leafs.
Yes, I must be cheap since a leaf spring set is like $30 USD each (every other year)...
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283092
07/19/16 04:19 PM
07/19/16 04:19 PM
Rubber torsion axles. No more steel springs.
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283093
07/19/16 05:13 PM
07/19/16 05:13 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
I had no idea torsion axles had rubber torsion bars....
There is a product out there for painting leafs, mostly to make them slide on each other better. But yours should go much longer than 2 years IMO.
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283095
07/19/16 07:47 PM
07/19/16 07:47 PM
Mike Fahle Offline
Mike Fahle  Offline
That's an expensive conversion but the ride is also much better since it behaves like independent suspension even though the wheels share an axle.
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283096
07/19/16 07:50 PM
07/19/16 07:50 PM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
Are you using galvanized springs? Have them on the speed boat that goes in the water every weekend for about 6 months of the year, lasts 10-15 years.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: trailer leaf spring corrosion [Re: Dazz] #283105
07/20/16 09:10 AM
07/20/16 09:10 AM
Interesting input. Thanks!
I am almost sure they aren't galvanized leaf springs given how fast they corroded. I thought they were painted, but if so it obviously didn't work very well.
I'll dig around the inner-net for galvanized leaf springs as well as that torsion bar.
My ony question regarding that torsion bar is how to detect it is nearing the end of its service life. I, for one, am not a big fan of catastrophic failures on interstate highways?
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283107
07/20/16 09:33 AM
07/20/16 09:33 AM
I don't believe they fail catastrophically. The interior tubing is large enough that it can't rotate inside the exterior tubing. The triangle shaped rubber pieces just provide cushion between the two and last a very long time. I'm nearly certain that the failure mode is that your trailer ride starts bottoming out steel on steel as the rubber deteriorates - but they have a reputation of lasting for a very long time.
Re: trailer leaf spring corrosion [Re: Jake] #283108
07/20/16 10:00 AM
07/20/16 10:00 AM
If it were only this easy.... but I'm not sure I believe everything I read.
Still, if $22 USD buys me another year or two of salt water use...
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283109
07/20/16 10:07 AM
07/20/16 10:07 AM
and would that salt-a-way crap they sell at West Marine do anything that fresh water (or soapy fresh water) wouldn't?
I have a manual garden sprayer I hose off the non-galvanized trailer parts (disc, calipers, leaf spring) after driving up the boat ramp...
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283110
07/20/16 10:11 AM
07/20/16 10:11 AM
M
MN3
MN3
M
I recently used this on a trailer (not this brand) - It looked good - help sell the trailer - I have no idea if it's worth it but a guy I sail with uses it all over his trailer. He does back his trailer in often to get his gcat - he recommends this stuff
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283118
07/20/16 01:46 PM
07/20/16 01:46 PM
Punta Gorda, FL
jkkartz1 Offline
jkkartz1  Offline
Punta Gorda, FL
I've owned several salt water trailers. A painted one was left along side the road with the tag pulled, the id# had already rusted off.
The problems with springs is that the rub together and remove any coating. There are also little crevices between the u bolts, plates and bolts. The spray galvanize could trap salt water.
A liberal application of Ospho on the steel surfaces would help. Apply liberally and often. Put it in a spray bottle.
I've never tried the Salt A way, but it probably can't hurt.
A natural anti rust coating is a mix of pine tar, turpentine and linseed oil. Apply liberally on a hot day.
Start a sinking fund for trailer parts.
My Hobie 16 trailer is a 1978 E Z Loader. At the time it was the first galvanized trailer that B & E Marine in Michigan City, IN sold. It has never been in the water, fresh or salt. I have never felt the need to float the boat off. The 2000 Rocket trailer for the flats boat needs constant attention.
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283127
07/20/16 03:40 PM
07/20/16 03:40 PM
catman Offline
catman  Offline
My dual axle power boat trailer has torsion axles. The original pair lasted 24 years.
It's very obvious when it's time to change them.
I got mine here, Redneck Trailer Supply
Re: trailer leaf spring corrosion [Re: catman] #283128
07/20/16 03:49 PM
07/20/16 03:49 PM
catman Offline
catman  Offline
Re: trailer leaf spring corrosion [Re: catman] #283129
07/20/16 04:09 PM
07/20/16 04:09 PM
Yes, I've tried various coatings (grease, etc) on the springs and aside from the nasty looks and hard questions I get from Marine Patrol when they see that rainbow develop the minute the trailer touches the water, I only get so-so results.
So I guess the torsion axle may be the most prudent way to go...
Next is to get the dang disc calipers to keep from sticking. No corrosion that I see on piston... must be the actuator (hydraulic surge brake) not returning all the way? How do the calipers adjust for pad wear?
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283130
07/20/16 07:07 PM
07/20/16 07:07 PM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
Jay,
Check out this web site. They have a shop a block off 75 in Bradenton on Hwy 64. Great folks with tons of stuff. Here is a waterproofing corrosion spray. They also have the other stuff you are looking for.
http://www.sturdybuiltonline.com/Bo...Waterproof-Lubrication-Spray_p_1136.html
Forrest
I-20
USA 645
" There ain't enough rum in the drum!"
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283132
07/21/16 08:03 AM
07/21/16 08:03 AM
Fluid compensation. Just like a car. As the pad wears, the piston extends further (actually, it just doesn't retract back as far) and it holds more fluid in the caliper with the increased volume of the extended piston. Your fluid level in the reservoir will drop as a result. When you change the pads and press the pistons back into the caliper, you need to watch that the fluid doesn't overflow the reservoir if you have ever added any.
You get ANY moisture (including air-born humidity) into the brake fluid system and it will pretty quickly lead to internal corrosion. The hydraulic brake fluid readily absorbs that moisture and, though not practiced by just about anyone, it's a good idea to change the brake fluid occasionally.
Re: trailer leaf spring corrosion [Re: Jake] #283134
07/21/16 08:49 AM
07/21/16 08:49 AM
Thanks Jake. I flush the fluid annually and usually have to change the pads about then, too... I'd bet there might be something going on with the actuator in the tongue that's setting me up for failure and causing those calipers to stick. The seal between caliper body and piston is still intact so as you said it may be the fluid causing the issue.
And Forrest I'll have to try that stuff, too. Being that I drop the boat on a ramp in the everglades, they get really hyper about any petrochemicals in the water. Even bearing buddies cause frowns on the faces of those dudes with guns and badges (although they probably have a chip on their shoulder anyway...)
I show them I use food grade grease which doesn't work as well as Red tacky #2, but I learned that from having to deal with the same issues on farm irrigation pumps dripping grease in the water canals..
Re: trailer leaf spring corrosion [Re: waterbug_wpb] #283147
07/22/16 08:46 AM
07/22/16 08:46 AM
Solomon's Island, MD
samc99us Offline
samc99us  Offline
T-9 may work.
Scorpion F18
Re: trailer leaf spring corrosion [Re: samc99us] #283148
07/22/16 08:52 AM
07/22/16 08:52 AM
Originally Posted by samc99us
T-9 may work.
Sam is talking about Boeshield T-9 which is probably the best product available to protect raw metal surfaces (It's THE product to protect cast iron tool surfaces). It dries to a tacky film and you may give it a whirl - that whole suspension environment, though, is just brutal on any coating or finish you can put on it.
Re: trailer leaf spring corrosion [Re: Jake] #283157
07/22/16 03:02 PM
07/22/16 03:02 PM
like the galvainized trailer frame?
And where does one score this mystical T-9?
0 registered members (), 369 guests, and 37 spiders.
Posts267,060
