spinaker cleat #283455
09/06/16 06:00 AM
09/06/16 06:00 AM
K
kornel Offline OP
kornel  Offline OP
K
Hello
I would like to change the spinnaker halyards system .
I want to have a separate tack.
Can anyone tell me, what is the optimal position mounting of cleats
Drawing attached, two dimensions.
Thank you in advance
Re: spinaker cleat [Re: kornel] #283524
09/19/16 07:03 AM
09/19/16 07:03 AM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Most boats I have seen have the cleat for the tack mounted on the beam. Check the owners manual for the viper or C2 on the AHPC site.
Re: spinaker cleat [Re: kornel] #283535
09/20/16 08:11 PM
09/20/16 08:11 PM
If you are asking about the halyard cleat on the mast, I believe mine is about 3-4 feet up from the base. I know it's about eye level when I'm kneeling on the tramp and raising the spinnaker.
Re: spinaker cleat [Re: Timbo] #283669
10/21/16 12:19 PM
10/21/16 12:19 PM
K
kornel Offline OP
kornel  Offline OP
K
thank you. It's very useful information
Re: spinaker cleat [Re: kornel] #283690
10/25/16 12:50 PM
10/25/16 12:50 PM
Knokke-Heist - Belgium
Gilo Offline
Gilo  Offline
on the Falcon we run the tack along the front beam to the ouside of the port hull and than to the side stay. In that way you can pull the tack while in the trapeze: http://www.theboatshop.be/English/Support_EN.html (look for tramplayout).
Falcon F16 - BEL666
Boats: TheBoatShop.be
0 registered members (), 210 guests, and 29 spiders.
