| Re: New buoyancy harness
[Re: Mike Fahle]
#286809 05/15/17 11:24 PM 05/15/17 11:24 PM |
Joined: Jun 2009 Posts: 524 Petten Netherlands northsea junkie
Posts: 524 Petten Netherlands | But how much buoyancy has this harness?
Are their sizes and buoancy for weight classes?
Is it a swimming vest or a lifesafe vest? I have the the impression that they try to offer both in one vest. That's impossible: I have a life vest which keep my head above the water if I'm unconsious. So the foam (which is only on my chest !) is 7 cm thick. And left 2 cm thicker as right for turning me up if miy face is down.
The danger with these type of gear is that it is only for show.
ronald RAIDER-15 (homebuilt)
[Re: northsea junkie]
#286810 05/16/17 07:39 AM 05/16/17 07:39 AM |
Posts: 807 Hillsborough, NC USA | But how much buoyancy has this harness? The page states that the harness is ISO12402-5 certified, therefore it is a 50 Newton (11 lbs) "flotation aid", not a "lifejacket". It is not USCG certified (and does not meet the 70N / 15.5 lbs minimum buoyancy required). It does not fulfill the requirement of racing rule 40 in the United States. Regards, Eric | | | Re: New buoyancy harness
[Re: Isotope235]
#286811 05/16/17 08:50 AM 05/16/17 08:50 AM |
Posts: 5,590 Naples, FL | So, based on that it may not be acceptable to use during sanctioned regattas?
[Re: waterbug_wpb]
#286813 05/16/17 09:45 AM 05/16/17 09:45 AM |
Posts: 12,310 South Carolina | So, based on that it may not be acceptable to use during sanctioned regattas? It's not acceptable to use where USCG approved life jackets are required, period. If DNR stops you on a lake and decides to look at the fine details, you will not meet the letter of the law with this product because it is not Coast Guard Approved. That said, the CG approval process is fraught with seemingly ridiculous expense and delay. If you change very simple things on a product, it has to get approved again at a high cost. Several of the products many of us use do not meet this requirement and the list is growing while the USCG approval process remains so complicated. I like the product idea....I'm also in need of a new Harness and the buoyancy aid that I currently wear is also not USCG approved (but I do feel that it serves my safety need very well)...I might give it a shot. However, I've participated in two previous kickstarter campaigns (unrelated to this one) and both were a complete disappointment. I'm going to have to stew on it for a little while and research the people/company "blood red" behind it a little. edit; The exchange rate is NOT working in the US's favor against the GBP for this product at the moment, though.
Jake Kohl | | | Re: New buoyancy harness
[Re: waterbug_wpb]
#286815 05/16/17 10:38 AM 05/16/17 10:38 AM |
Posts: 807 Hillsborough, NC USA | US law (and therefore US Sailing prescriptions to the racing rules) require you to have USCG certified Type I, II, or III personal flotation devices (in good condition, of appropriate sizes, accessible) for each person aboard. Children under 13 must wear a USCG approved pfd when underway (with some exceptions). Boats 16 feet and over must also carry a type IV (throwable) PFD. Additional laws apply and state laws may add other requirements. Technically, the law and the rules don't say that the PFD an adult wears must be USCG certified. Therefore you could wear a CE or ISO certified flotation device provided you also had a USCG certified PFD aboard (in good condition, of appropriate size, and accessible). Watch out, however, for regatta NORs and SIs that may change rule 40 and require you to wear a USCG PFD. See http://www.ussailing.org/race-officials/rules/personal-floatation-devices-pfds/ for more information. I hope that helps, Eric
[Re: Ventucky Red]
#286817 05/16/17 01:50 PM 05/16/17 01:50 PM |
Posts: 524 Petten Netherlands | I'm very surprised by all this talk about USCG and other official requirements/ approval. Hey, we are all skippers with resposibility for our lives and that of others on our tramp. So I would say the official required buoyancy is the MINIMUM you should have. And please forget the false story about the alleged trouble you are supposed to have with lifevests. I never go at sea without one, and never feel restricted in my movements. See my vid starting at 3:11 min: https://www.youtube.com/watch?v=kMKThlRmCGEThat is to say; you can't swim with a lifevest!
[Re: Isotope235]
#286818 05/16/17 03:00 PM 05/16/17 03:00 PM |
Posts: 5,590 Naples, FL | To add to Eric's post, I believe the USCG PFDs also have to be "readily accessible" if they aren't being worn. So you can't shove them down into the hull and screw the inspection port back on... Oh, and anyone under 16 must wear them at all times outside of an enclosed cabin.
At least from what I understood from the marine patrol dudes who checked out my boat.
I was on the way back from a race day, and still wearing my pfd which (luckily) happened to be USCG approved (type II I think... Didn't have the floating pillow to keep my head upright while unconscious) when their RIB pulled out of the inlet and "chose" me to saddle up to. The crew had on those inflatable pfds.
I will say they were generally courteous and allowed me to put out a fender before they slid up against the hull. They didn't get on the boat (I think they were a little confused by the nets on the amas) but asked for all the usual paperwork and asked about the pfds. I had a pack of them sitting on the bench seat in the cabin so it was easy to reach down and grab them.
So yeah, two of my flares were out of date, and it "would be helpful" if I had a radar reflector, but I had all the daytime signal devices (mirror, floaty-tube, dye) and some strobes (not SOLAS but close) so they cut me some slack.
They said they stopped me because my registration sticker was on the wrong side of the boat (port bow if you must know...)
[Re: waterbug_wpb]
#286819 05/16/17 03:07 PM 05/16/17 03:07 PM |
Posts: 5,590 Naples, FL | And to Jake's hesitancy regarding Kickstarter and other crowd-funding projects I share that caveat empor.... They're looking for "investors" who can get a discount when/if the product finally makes it to market.
I think a friend sent money to another campaign which was developing an ROV/drone which was supposed to follow you while filming (automatically). I don't think he ever saw the actual product.
And another crowd-source thing was that memorial fund set up for the victim of some horrible violence. The relatives of the victim said they never set up any sort of fund, so I wonder where all that money went.....
#286820 05/16/17 03:09 PM 05/16/17 03:09 PM |
Posts: 1,403 | I'm very surprised by all this talk about USCG and other official requirements/ approval.
I agree a life vest does hamper my maneuverability in the water.. the few times I have been there with a capsized boat.. I would have been better with not having it... on the other hand if I was incapacitated I would be glad that it is on.. With regards to the USCG requirement... as I see it, it is all about "liability pass through." If I had a shop I wouldn't even think about selling a non-approved PFD... There are also laws the require one be aboard the vessel for each person... you don't have to wear it, it just has to be there, unless you're under I believe 16, then it has to be worn. But like seat belts, why wouldn't you use it? | | | Re: New buoyancy harness
[Re: waterbug_wpb]
#286825 05/18/17 10:03 AM 05/18/17 10:03 AM |
Posts: 12,310 South Carolina | And to Jake's hesitancy regarding Kickstarter and other crowd-funding projects I share that caveat empor.... They're looking for "investors" who can get a discount when/if the product finally makes it to market.
And another crowd-source thing was that memorial fund set up for the victim of some horrible violence. The relatives of the victim said they never set up any sort of fund, so I wonder where all that money went..... My last kickstarter was for a cool flip-flop concept where you put them in the oven to warm them up (to a reasonable still touchable temperature) and put your feet into them bearing your full weight to form the soles to your feet. No break in period! They had about a year's worth of delay (actually more than a year) and got everybody's addresses and orders screwed up...couple that with the fact that people tend to move around after 1.5 years, their bulk deliveries from china got lost on a train in the US, turns out you had to heat them up hot enough to get burned so they included socks to wear while molding them, and then, the day I got mine, they sent out a notification to everyone to NOT PUT THEM IN THE OVEN because it softens the glue and they fall apart in a week or two - just wear them and they'll break in.  lol. I actually felt sorry for the folks trying to deliver that product. They were clearly over their head in several aspects of that project.
#286827 05/18/17 12:08 PM 05/18/17 12:08 PM |
Posts: 5,590 Naples, FL | I think you're right Jake... Many items I've seen in the Kickstarter/crowd funding segment are either not fully thought-out or have not been able to get funding through more traditional means... That makes me think that if the lenders/venture capitalists saw something that made them shy away from the group it might mean I should as well.
Not that the concepts weren't awesome... It's usually the management/oversight team and/or the logistics/development process.
1 registered members (soulofasailor),
1,861
guests, and 23
