| Re: N5.2
[Re: Wrinkledpants]
#30436 02/24/04 01:54 PM 02/24/04 01:54 PM |
Posts: 284 Norfolk, VA | Reid,
I am putting a 5.2 together now, and I ran the jib wires from the front crossbeam, above the tramp, through one slot, under the tramp, back up through the other slot and back over the tramp again to the rear beam. I don't know if this is right, but it makes sense to me. The wire being above the tramp in the rear is going to be bad on the legs, but I'll cover it with hose or somthing. If it ran under the tramp, then I think it would wear a hole in the tramp.
The tramp I have came from Sunrise Yacht Products and has the slots cut into them and reinforced from the manufacturer. It is a VERY nice tramp!
I am putting one boat together out of 3, so I have several exampes to look at. On another, it has wires running under the tramp that look to be there for frame rigidity and then it has wires running parallel to them ABOVE the tramp for the jib blocks!
If anyone out there thinks I'm off base, please let me know! I've seen it done so many different ways, it is hard to figure it out sometimes!
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
| | | Re: N5.2
[Re: Dan Berger]
#30437 02/24/04 03:45 PM 02/24/04 03:45 PM |
Posts: 12,310 South Carolina | Dan,
I'm pretty sure the wire in question should only be on top of the trampoline between the two slots - this is where the jib blocks would typically attach. The whole idea was to get the wire away from the skipper's knees.
Jake Kohl | | |
484
guests, and 33
