| Fast cruiser #30460 02/25/04 09:30 AM 02/25/04 09:30 AM |
Joined: Aug 2003 Posts: 125 Cape Coral, FL pete_pollard OP
Posts: 125 Cape Coral, FL | Does anyone want to help me figure out how to increase the light and medium air performance of my Tiki?
It's plenty fast for me in heavy air, say 20+. But, it's just terrible in wind under 6.
Thanks,
"Cat Fest Sailor"
Pete in Cape Coral
| | | Re: Fast cruiser
[Re: pete_pollard]
#30461 02/25/04 09:42 AM 02/25/04 09:42 AM |
Posts: 4,451 West coast of Norway | Hi, I dont think Wharram designs with speed in mind, so you should not expect to much from your Tiki 21. If you want a faster boat, perhaps you could consider a different design ? If not, good sails always helps. A larger rig is the standard answer for light air performance. But then you would be overpowered in the heavy stuff and need to reef earlier. Also, the Tiki is designed for the rig you have got, so be careful with new solutions.. If you want to get radical, you could consider contacting Dave Culp at http://www.kiteship.com. He will probably reccomend a kite based solution both up and downwind. | | | Re: Fast cruiser
[Re: davidtilley]
#30463 02/25/04 11:23 AM 02/25/04 11:23 AM |
Posts: 125 Cape Coral, FL | Thanks all, for your response. If I were much younger I'd be a radical kite sailor! Saw a thing on TV where two guys crossed the English Channel! What a hoot! French coast guard was not amused though!  I think the real problem with the Tiki is that the shrouds go all the way to the mast head. This prevents the gaff (forked stick{that might make a good boat name}at the top)from rotating horizontally into a beam position. This leaves the main severly "goose winged" down wind. Up wind, I haven't a clue! Although when the wind gets up over 6 knots it will point about as well as a Hobie 16 if not as fast.
"Cat Fest Sailor"
Pete in Cape Coral
| | | Re: Edgar
[Re: EdgarAPoe]
#30465 02/25/04 03:12 PM 02/25/04 03:12 PM |
Posts: 125 Cape Coral, FL | The builder maintains that Tiki should be able to achieve speeds of 1-3 times the square root of the WLL (18'6") or 4.3 to 12.9 knots. My GPS has indicated speeds in the 10-12 knot range several times.
My problem is that in wind speeds much below 6 knots, getting the 4.3 is extremely difficult.
"Cat Fest Sailor"
Pete in Cape Coral
| | | Re: Edgar
[Re: davidtilley]
#30467 02/25/04 04:06 PM 02/25/04 04:06 PM |
Posts: 125 Cape Coral, FL | You guys have gotten me thinking. (I try not to do that, it makes my head hurt!). What would a good fast catamaran expect in 3-6 knots?
"Cat Fest Sailor"
Pete in Cape Coral
| | | Re: Edgar
[Re: pete_pollard]
#30468 02/25/04 04:58 PM 02/25/04 04:58 PM |
Posts: 251 beaufort, sc | how much sail area do you have now? my hobie 16 has a reefable main and option of a roller furling jib at 218 sf, a hobie 18 rig with reef points might be even better, you also get a rotating mast that helps efficiency. those wharram rigs are very cruiser oriented, are you sailing to tahiti or do you want to throw some spray across the bay?
marsh hawk
| | | Dan
[Re: dannyb9]
#30469 02/25/04 05:33 PM 02/25/04 05:33 PM |
Posts: 125 Cape Coral, FL | I currently have 208sf. 130 main, 78 jib. The boat throws plenty of spray in high winds, and Tahiti is tempting! The goal I'm trying to reach is that of increased light air performance. One of the guys mentioned earlier a big hooter, that might just be the ticket since I've already ordered a spinnaker. But, thanks any way!
"Cat Fest Sailor"
Pete in Cape Coral
547
guests, and 95
