| Re: Carbo Blocks
[Re: CMerrell]
#32572 04/23/04 05:53 PM 04/23/04 05:53 PM |
Posts: 1,884 Detroit, MI | Chris, I did that on my 17 - used the smaller block on the boom and the larger Ratchamatic block on the traveller. It's an awesome setup for that boat since you have to let out a bunch of sheet in a tack. The sheet itself is 5/16 Marlow Excel Marstron - similar to Yale Light, but not as durable and way less expensive. I think the line cost all of $18. Anyway, I'm going to try that setup on the 16 this weekend. I sold the 16's main system (stock line w/ regular Harkens)with the 17. I'll let you know how it works, but I've already got a pretty good idea.  Matt | | | Re: Carbo Blocks
[Re: CMerrell]
#32573 04/23/04 08:21 PM 04/23/04 08:21 PM |
Posts: 744 | Chris, I'm running a 29mm triple with 5/16" Yale Light on the boom of the F14. Bob
| | | Re: Carbo Blocks
[Re: CMerrell]
#32574 04/26/04 03:24 PM 04/26/04 03:24 PM |
Posts: 284 Norfolk, VA | Chris, While you are ordering your new blocks, why don't you order some tramp cleaner, too?!
Dan Berger Norfolk, VA A Cat USA139 Supercat 15
| | | Re: Carbo Blocks
[Re: Dan Berger]
#32575 04/26/04 05:22 PM 04/26/04 05:22 PM |
Posts: 38 | I use a set of 57mm Carbo blocks on my H-16. I use the 57mm triple as an upper block and a 57mm triple with ratchet, cam, and becket. I use a 3/8 Samson trophy braid mainsheet and like the blocks. They are much more durable than they look like, they have survived 2 seasons use without a single issue.
Hobie 16 sail #102653
989
guests, and 37
