| Re: Moving jib sheet from wire to hull on N5.2
[Re: NacraMike]
#34181 06/09/04 05:14 PM 06/09/04 05:14 PM |
Posts: 606 Maryland | Your jib will be too open for an efficient slot except when on a down wind reach. Many 5.2 owners run the jib sheet cables wires under the tramp with a short run that surfaces above the tramp before continuing the run under again.
Requires having 2 reinforced grommets added for each cable run. Most opt to have the cable surface about midway then go back under about 18" from the front beam.
Kris Hathaway | | | Re: Moving jib sheet from wire to hull on N5.2
[Re: dickcnacra52]
#34183 06/10/04 06:48 AM 06/10/04 06:48 AM |
Posts: 606 Maryland | It is not the manufacture's setup. N5.2's Jib blocks are suppose to be able to move forward and aft. It controls the jib's leach and foot. Further back, tighter the foot and more open the leach. If ya gonna race then it will help. Adjusts the boat's power so that it can sail according to the prevailing sea, wind, and crew weight conditions (that's another thread).
[Re: NacraMike]
#34184 06/10/04 10:42 AM 06/10/04 10:42 AM |
Posts: 74 Maryland, USA | I have a Nacra 5.5SL which has a wire going across tramp (hull to hull) that can also be adjusted forward and back. I replaced it with a tramp mounted line. Its convenient, but you will loose some adjustability which might be a problem if you're seriously racing. Just another option for you. See Nacramania.com upgrades section for more info.
Patrick Ragen Taipan 4.9 USA 274
485
guests, and 26
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
