I am having some difficulty to find groove tracks for the tramps of the Catri 27 I am building. Maybe the luff tracks from Hobies comptip would serve (?). Anyone with previous experience with those?
All suggestions welcome - thanks!
Luiz
Re: Tramp track - where to buy? Suggestions?
[Re: Luiz]
#35707 07/19/0409:35 AM07/19/0409:35 AM
Nacra uses a solid Aluminum c-shape extrusion that rivets to the hulls. It has a 1"+ horizontal flange that is tangent with the top of the "C" shape. I would take a picture but my boat is 2 hours away at the moment.
[Re: Luiz]
#35709 07/19/0411:06 AM07/19/0411:06 AM
You can buy track from Sunrise Yacht Products in St. Petersberg, FL. Go their website and follow "main, installation, installation producuts." They are good people and will custom anything you need. (Not affiliated...)
3) Aluminium extrusion companies sometimes have a standard product that will work. Try contacting local firms. I remember a story about someone using an extrusion made for screen doors
Both my examples were New Zealand Companies. I have had good luck dealing with New Zealand firms via internet
Good Luck It sounds like you are into the hard part of your boat building, finding all the littole parts you thought would be easy
[Re: Luiz]
#35711 07/19/0411:48 AM07/19/0411:48 AM
Hello Luiz, Make sure the track is 6061T-6 aluminum alloy. There is alot of 6063T-5 track on the market and it is soft and will open up and spit the rope out under load. Might be OK for awnings but not for tramp tracks. Bill
[Re: Mike Hill]
#35712 07/19/0401:18 PM07/19/0401:18 PM
Very good alternative. The photo is not necessary - just tell me if the flange is an inverted "L" to fit the deck/hull joing or if it is flat, which would be ideal for me. Thanks, Luiz
Luiz
[Re: Luiz]
#35714 07/19/0401:50 PM07/19/0401:50 PM
-The sections in the first NZ link are too shallow - I need a rope "luff" to make the first part of the tramp impermeable with vinyl or something similar.
-The plastic section in the second link is perfect, but plastic might not resist for long.
I checked some of the more important nearby aluminum companies, like www.alcoa.com.br (Brazil is an important producer) but this is hardly a standard section. The only real rigger is www.farol.com.br and the available extrusions are only for masts and very limited in choice. It'd be necessary to find a naval alloy round or oval section and then cut the groove, but this would destroy the anodization, so painting would be necessary. It is feasible but not practical nor beautifull.
I'd rather buy the proper product in the US. It is easier to pay US dollars and to receive the goods through my brother in Naples (Fl) or via mailbox.
I'm lucky: so far this has been the only part that required asking around. The custom SS parts were easy to make in Rio and the standard deck hardware is excellent - take a look at Nautos (click in "English").
The "to do" list now is: -Rear seat, tramps, sails, SS stringers and mast/boom/bowsprit/standing rigging - which will come complete from Europe.
Cheers,
Luiz
[Re: BRoberts]
#35718 07/19/0402:40 PM07/19/0402:40 PM
Your track looks bolted to the deck, so the groove should be lateral. I am looking for a track to bolt to the side of the hull so the groove must be in the center. Thanks,
The aluminum "tramp" tracks are the same as that used by all caravan manufactureres when the have an "annexe" that attaches to the side of the caravan so any caravan manufacture should have "heaps" of the track in stock. Theirs is also the right alloy for use on catamarans as well, and its cheap. darryl
Darryl, Your indication certainly works well in Australia and maybe in the US, but I bet that in Brazil they use a cheap alloy and a section that is too light for our purpose. Thanks, Luiz
