Inter 20 specs #3663
11/09/01 04:25 PM
11/09/01 04:25 PM
MI
sail6000 Offline OP
sail6000  Offline OP
MI
5 Year Limited Warranty
<br>Molded White Hulls
<br>4 Degrees Canted Symmetrical Hulls
<br>High Aspect Carbon Daggerboards (4.75:1)
<br>High Aspect Carbon CHC Rudders (3.1:1)
<br> Double Trapeze
<br>Exclusive Rudder Rake System
<br>Mylar Main and Dacron Race Jib
<br>Foam Battens
<br>Equipped with Newly Developed Harken and Garhauer Gear Throughout
<br> Complete Asymmetric Spinnaker Package
<br>Mesh Trampoline with Integrated Spinnaker Bag
<br>Outboard Led Rotation and Downhaul Controls
<br>
<br>
<br>
<br>
<br>Inter 20 specs -
<br>
<br> Length: 20' (6.10m)
<br>Width: 8' 6" (2.59m)
<br>Mast Length: 32' (8.13m)
<br>Weight: 390 lbs. (177kg)
<br>Mainsail with Mast: 193 sq. ft. (18m2)
<br>Jib: 53 sq. ft. (4.15m2)
<br>Spinnaker: 270 sq. ft. (23m2)
<br>Construction: vinylester foam, sandwich hulls
<br>
<br>
<br><br><br>
3704- (213 downloads)
Re: Inter 20 specs [Re: sail6000] #3664
11/09/01 09:29 PM
11/09/01 09:29 PM
USA
NaCl H20 Offline
NaCl H20  Offline
USA
The Jan de Boer Catamarans has the same size main as the Performance site.
<br>They list the main as 18sq m / 193 sq ft
<br>Two jibs 44.7 sq ft and 52.2 sq ft.
<br>
<br>Performance should get serious about accurate specs on it's site....Or are both the Euro and US mains the same.
<br>
<br>----------------------------------------------------------------------
<br>
<br>Length: 20' (6.10m)
<br>Construction: vinylester foam, sandwich hulls<br><br>
3717- (165 downloads)
Both sites give the EU specs (nm) [Re: NaCl H20] #3665
11/10/01 08:32 AM
11/10/01 08:32 AM
Wouter<br><br>
3728- (165 downloads)
Re: Both sites give the EU specs (nm) [Re: Wouter] #3666
11/10/01 08:58 AM
11/10/01 08:58 AM
MI
sail6000 Offline OP
sail6000  Offline OP
MI
This sail area difference certainly has been the crux of the difficulty in getting this Class started .
<br> My understanding is that the U S is without the mast .
<br>-This controversey may turn out to be a blessing in disquise and allow us the opportunity to form a more open inclusive flexible set of class rules.<br><br>
3732- (175 downloads)
Re: Both sites give the EU specs (nm) [Re: sail6000] #3667
11/10/01 10:13 AM
11/10/01 10:13 AM
USA
NaCl H20 Offline
NaCl H20  Offline
USA
The Performance site says 18sq WITH mast. Has anybody ever measured an I20 main? <br><br>
3734- (158 downloads)
Re: Both sites give the EU specs (nm) [Re: NaCl H20] #3668
11/11/01 10:48 AM
11/11/01 10:48 AM
I know at the Curacao regatta last year the US I20 sail was matched to the Dutch I20 and found it larger. The Americans were upset because it then got a 'faster' texel rating, which in these conditions (25knots+) was definately not true. WF can definately comment on this. Matt Mayfield<br><br>
0 registered members (), 484 guests, and 37 spiders.
