P19 Deck Removal #37310
08/25/04 01:26 PM
08/25/04 01:26 PM
Fulshear, TX
SGalway Offline OP
SGalway  Offline OP
Fulshear, TX
Somewhere along the way I seem to remember hearing something about the decks on most Performance boats being removable. Can anyone confirm this for a 1999 P19? More to the point, does anyone have a clue how to pry those little suckers off without breaking them?
I backed down a wave and pushed a gudgeon into my transom this weekend. I need to repair it and don't particularly care for the inspection port look.
Thanks all,
Shannon Galway
P19mx
Shannon Galway
Fulshear, TX
YoNav! Flying Phantom
www.yonav.net
Re: P19 Deck Removal [Re: SGalway] #37311
08/26/04 07:59 PM
08/26/04 07:59 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
Not an expert but.... 1) the decks pry off with a heat gun... but they usually break in the process and you put new decks back on.
2) Fellow in my area cut access holes on the insides of the hulls ... replaced the gudgeons with two of them doubled up and a backing plate and then reglassed the cutout back in.
Mark
crac.sailregattas.com
Re: P19 Deck Removal [Re: SGalway] #37312
08/26/04 08:58 PM
08/26/04 08:58 PM
Fort Walton Beach, Florida
MikeWilliams Offline
Shannon,
In theory the deck is removable. The problem is it sits on a very thin flange and is epoxyed in place. I recently replaced my foredecks. It was next to impossible to remove them without damaging the flange (it was so delicate). But if you must pull the deck it is not that hard to reconstruct the flange.
But as posted previously... if the deck is fine then it would be best to go though the side of the hull and then repair the hull.
Good luck,
Re: P19 Deck Removal [Re: SGalway] #37313
08/27/04 09:53 AM
08/27/04 09:53 AM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Arn't there inspection ports in the rear of a P19 already. I don't understand why you can't fix it through the existing inspection ports? I must be missing something????
Mike Hill
Tiger #1520
Mike Hill
N20 #1005
Re: P19 Deck Removal [Re: Mike Hill] #37314
08/27/04 10:08 AM
08/27/04 10:08 AM
Flagstaff, Arizona
Dennis Offline
Dennis  Offline
Flagstaff, Arizona
Good point, but there is a bulkhead under the rear beam between the transom and the port. I wonder if you could cut a hole in that bulkhead and go in through there?
0 registered members (), 1,369 guests, and 30 spiders.
