Prindle 16 Rudder Question #37638
09/02/04 12:12 PM
09/02/04 12:12 PM
mleach350 Offline OP
I have recently rebuilt a Prindle 16 and used the rudder rebuild kit to snug up the rudder system. The main problem I have been having is in locking the rudders down when we are getting going. The rudders just don't want to catch and stay down and we end up tying the rudder lines around the tiller bar. Any tips on how to cure this or is it simply old parts on an old boat that need to be replaced? Thanks in advance for any help.
Prindle 16, J-24, RC Laser
Re: Prindle 16 Rudder Question [Re: mleach350] #37639
09/02/04 12:29 PM
09/02/04 12:29 PM
Socal
nesdog Offline
nesdog  Offline
Socal
Did you replace the hook that sits on the blade? It can wear down and will not hold very well. That would be my guess.
Sheldon
P-18
Re: Prindle 16 Rudder Question [Re: nesdog] #37640
09/02/04 12:38 PM
09/02/04 12:38 PM
Simi Valley, CA
jfint Offline
jfint  Offline
Simi Valley, CA
Or the springs that hold tension on the cross piece the hook is supposed to catch
Josh Fint Prindle 19 "Accident Prone" Moro Bay Sailing
Re: Prindle 16 Rudder Question [Re: mleach350] #37641
09/02/04 01:11 PM
09/02/04 01:11 PM
Norfolk, VA
Dan Berger Offline
Dan Berger  Offline
Norfolk, VA
I had the same problem on my P18. I found that the hole that the hook pin goes through was a a little reamed, so I added some resin and then re-drilled. That took out a lot of the slop and got it in the right angle. Merely tightening the two nuts might help, but if they were loose and reamed the hole, it won't fix it. I also filed the inside of the hook so that it was more of a hook and not so flat. Granted, it set me up for failure if I were to run aground and needed the kick-up feature, but it sure kept them locked down. I just made sure that if I were near shore, I had the rudders unlocked.
Dan Berger
Norfolk, VA
A Cat USA139
Supercat 15
Re: Prindle 16 Rudder Question [Re: mleach350] #37642
09/02/04 01:24 PM
09/02/04 01:24 PM
Fort Loramie, Ohio
jmhoying Offline
jmhoying  Offline
Fort Loramie, Ohio
Her is an article on Prindle rudder adjustments that was in an old Prindle newsletter.
Good luck,
Jack
Re: Prindle 16 Rudder Question [Re: jmhoying] #37643
09/03/04 05:55 PM
09/03/04 05:55 PM
Thanks for the ideas everyone, I'll definately check out all of these areas and see if anything can be improved.
Re: Prindle 16 Rudder Question [Re: jmhoying] #37644
09/05/04 01:01 AM
09/05/04 01:01 AM
Dotan Offline
Dotan  Offline
After reading this newsletter till the end, I am really starting to believe that "Prindle Cat has the best rudder system going."
Dotan kick up rudder systems for dinghy and catamarans http://www.dotan.com
0 registered members (), 569 guests, and 73 spiders.
