Hulls interchangeable by years? #43080
01/19/05 03:16 PM
01/19/05 03:16 PM
C
cclxxxz Offline OP
cclxxxz  Offline OP
C
Y'All,
Please forgive me if this topic has already been covered, but I need help. My '82 H-16 was killed by a falling tree and now I need a port hull. Can I use a hull from another year H-16, or does it have to be an '82? I am currently considering a hull from a '71, but I don't know if it will fit.
Thanx in advance.
cclxxxz
Re: Hulls interchangeable by years? [Re: cclxxxz] #43081
01/19/05 08:37 PM
01/19/05 08:37 PM
The real question is, "Will my 1982 corner castings fit over a 1971 hull pylon?" The dimension between the pylons is irrelevent (to a point) since the side bars "float" in the corner castings.
The answer is "probably." But you won't really know until you try.
The corner castings were changed slightly in the early 80's to better fit the pylons and to prevent cracking. Odds are the '71 pylons are so worn that they'll be really loose in the castings, no matter what year your castings are.
0 registered members (), 967 guests, and 34 spiders.
