| H16 vs. H14 capsizing #48352 05/02/05 10:09 PM 05/02/05 10:09 PM |
Posts: 217 West Texas | Hey gang, quick one here: When I flip on the 16, it seems like the mast kind of hangs out near the surface for a bit and then if I don't make some effort to get the boat up then it will slowly start down towards a turtle. Compare that with my (first) two capsizes on the H14 this past weekend where the first time the only reason it didn't turtle was that I didn't have the boat figured out yet (WAY less stable standing on one hull than the 16!) and I therefore kept spinning it from one hull to the other. lol The second capsize it went right over and the mast went down and stuck two feet into the mud at the bottom of the lake. My friend came over in his ski boat and helped me remove the mast from the mud, which was nice. What I can't figure out is why the dang H14 doesn't want to stop at simply "capsized" and tries to turn turtle immediately. There are enough 14s out there that somebody must have the answer. I'd rather not have the silly mast bob but I may resort to that if I don't get other ideas. I don't believe the mast is taking on any water because it's still pretty light carrying it around. When my 16 mast took on water it weighed a friggin' ton. So I think there's something else involved. Help please!
Warm regards,
Jim
| | | Re: H16 vs. H14 capsizing
[Re: JaimeZX]
#48353 05/02/05 11:46 PM 05/02/05 11:46 PM |
Posts: 9 | Hey, Jim. I have both boats as well, and I have not had a similar experience with my 14. We both thought of the obvious, water in the mast, but you seem to be convinced that this is not the case. Nonetheless, if I were you, I would do the standard mast vs. water test. The mast on my 14 seems to be water tight and virtually floats like a champ. Have you had the main sheet out of the cam once the boat is in the water? If all else fails, you would look pretty damn cool if you added the hobie bob... Watch out H14 nationals!( sarcasm ) Don't feel too bad though; some people seem to have trouble with the 14 even whilst on land. | | | Re: H16 vs. H14 capsizing
[Re: jeffrey]
#48354 05/08/05 01:47 AM 05/08/05 01:47 AM |
Posts: 493 Minnesota | Nice sails! Don't ya just love the Tequilla Sunrise colors?
[Re: hrtsailor]
#48356 05/08/05 10:54 PM 05/08/05 10:54 PM |
Posts: 217 West Texas | I never retrofitted to the comptip mast and I wonder if the extra weight is what causes that slow turtle on your 16. Do you have a comptip mast? Did the 14s get changed to comptip? The reason I turtled that I remember was a 25 to 35 mph wind blowing on the tramp with the mast still downwind. Not sure if the 14s ever went comptip, the '75 we have is all aluminum again. Your H16 turtle experience you describe is the same scenario as happened to me. This past Saturday I ran two empty gallon jugs up the H14 mast with the sail (tied to the halyard shackle) and when we capsized the mast stayed right at the surface. Also, the new righting system I installed made getting the boat back up much easier.  Thanks for your input!
Warm regards,
Jim
[Re: JaimeZX]
#48358 06/21/05 03:49 AM 06/21/05 03:49 AM |
Posts: 6 Siena, Italy | Not sure if the 14s ever went comptip, the '75 we have is all aluminum again Hi, I'm new here ... reading some posts I found "Comptip Mast" that help you about this ... just for info ... Even in my opinion and my little experience the H14 try to turtle immediatly, especially if the mast isn't silly. I'll try to add the hobie bob as jeffrey suggested ! Hope it works and prevent me to turtle again ! Mizi | | | Re: H16 vs. H14 capsizing
[Re: JaimeZX]
#48363 06/22/05 02:15 PM 06/22/05 02:15 PM |
Posts: 545 Brighton, UK | To answer the original question, the reason the 14 turtles much quicker than the 16 is to do with the difference in mast length. Generally a boat with a longer mast is less prone to turtling than a boat with a shorter mast. However when a boat is on its side the shorter mast boat is generally easier to right. Gareth www.fourhulls.com | | | Re: H16 vs. H14 capsizing
[Re: hrtsailor]
#48364 06/23/05 02:50 AM 06/23/05 02:50 AM |
Posts: 6 Siena, Italy | Getting out of the turtle is easy. Put your weight on the stern end to get the bows to come straight up rather than try to bring one hull up . The boat will fall over to the side once the mast gets near the surface. Howard Sorry but ... the tip works even without crew ? If so can you explain me where exactly I have to place my feet ! Thanks Mizi | | |
722
guests, and 44
