Page 3 of 4 1 2 3 4
Re: galvanic corrosion [Re: Jimbo] #51049
06/22/05 12:02 AM
06/22/05 12:02 AM
Will_R Offline
Will_R  Offline
I've got $5 that if the SS hounds was removed from that mast there would be quite a bit of pitting, not to mentiong flakey/brittle aluminum visible.
Re: galvanic corrosion [Re: Will_R] #51050
06/22/05 06:34 AM
06/22/05 06:34 AM
Jimbo Offline
Jimbo  Offline
This is exactly why you cant tolerate corrosion on your boat! Corrosion doesn't just eat away the metal like a very slow grinder. It changes the metal that's left behind so that it all becomes JUNK! 'Aluminum' as we know it is highly alloyed. It is far from pure aluminum. Structurally, it's like comparing iron to steel. The downside of this type of alloying is that it's both prone to corrosion (pure aluminum BTW is very corrosion resistant) and succeptible to changes in the crystalline structure so that it becomes weak and brittle when corroded. Beware!
Jimbo
Re: And your decision is ! [Re: Jimbo] #51051
06/22/05 08:43 AM
06/22/05 08:43 AM
BobG Offline
BobG  Offline
So Catius, You've learned all about the rudder system and galvanic corrosion ,.."what's your final answer"! Do you wanna use a life line? Is a Mystere in your future!
Re: galvanic corrosion [Re: Will_R] #51052
06/22/05 09:15 AM
06/22/05 09:15 AM
Annapolis,MD
Keith Offline
Keith  Offline
Annapolis,MD
I'd say that mast is a perfect candidate to be cut at the hounds and have a comptip installed!
Re: galvanic corrosion [Re: Keith] #51053
06/22/05 06:28 PM
06/22/05 06:28 PM
catman Offline
catman  Offline
ROTFLMAO
Re: galvanic corrosion [Re: catman] #51054
06/23/05 09:09 AM
06/23/05 09:09 AM
BobG Offline
BobG  Offline
What's "Rotting Florida Mayonnaise" got to do with this.
ROTFLMAO?
Re: galvanic corrosion [Re: BobG] #51055
06/23/05 09:29 AM
06/23/05 09:29 AM
Rolling On The Floor Laughing My butt Off.
Re: galvanic corrosion [Re: MauganN20] #51056
06/23/05 06:38 PM
06/23/05 06:38 PM
catman Offline
catman  Offline
Now my sides hurt!
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: Fleet111] #51057
06/24/05 09:26 AM
06/24/05 09:26 AM
BobG Offline
BobG  Offline
The original spinnaker size offered by Yves at Mystere was 269Sqft. The N6.0 NE. is 360 and there are some older chutes at 400plus. Which chute size or is it shape actually is working the best for the M6.0? I support Galvanic corrosion Free Sailing..........Bob G
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: BobG] #51058
06/24/05 10:26 PM
06/24/05 10:26 PM
BobG Offline
BobG  Offline
hey Catman is that 360sqft spi in that avatar....
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: BobG] #51059
06/25/05 09:46 AM
06/25/05 09:46 AM
Charleston, SC
NCSUtrey Offline
NCSUtrey  Offline
Charleston, SC
Me gusta carbon fiber......
Trey
N20 314
Layline Rigging
www.velocitysailing.com
Trey
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: NCSUtrey] #51060
06/26/05 09:56 PM
06/26/05 09:56 PM
BobG Offline
BobG  Offline
There's a new beetle that has developed a taste for carbon fibre.
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: BobG] #51061
06/27/05 02:12 PM
06/27/05 02:12 PM
catman Offline
catman  Offline
Honestly I don't know the sq.ft of that chute and I have not used it for a while. It was one of the chutes Hans used in the W 1000. It will sheet to the rear beam so I know it's not small. I'm using one I got from Robbie D. off his T.
The T's and the M6.0XL are close in dimensions,board type so having Robbie local is good for used stuff. One thing about T chutes is they are designed to go downwind and may not be flat enough to reach up like a N20.
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: catman] #51062
06/27/05 02:16 PM
06/27/05 02:16 PM
BobG Offline
BobG  Offline
Yes it is larger than normal.For a moment I thought you were sailing a M4.3
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: BobG] #51063
06/27/05 04:42 PM
06/27/05 04:42 PM
Long Island, NY
Catius Offline OP
Catius  Offline OP
Long Island, NY
so...after all this fantastic advice (thank you, I think I will soon earn a PhD in galvanic corrosion and anodization ;-), I've decided to buy the Mystere 6.0. I will sail it for the first time in a 3 weeks...curious how much "upgrade" it will be from my old P19. The current owner tells me it's got an oversized chute (420 sq.ft.). Is that indeed very large?...and if so, as of what wind speeds would you say it get's just too crazy (based on YOUR level of experience?). Thanks!
Thomas Mystere 6.0
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: BobG] #51064
06/27/05 04:46 PM
06/27/05 04:46 PM
catman Offline
catman  Offline
No, When I sail 4.3's bad things happen,or I find the weak points. Note the mast...Nice flex. No it wasn't my job to raise the chute. The mast survived...........
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: catman] #51065
06/27/05 04:53 PM
06/27/05 04:53 PM
catman Offline
catman  Offline
But the snuffer hoop didn't. Mystere warrantied it..Nice!
The attachment works then it won't. Trust me ,it broke off.
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: Catius] #51066
06/27/05 05:40 PM
06/27/05 05:40 PM
catman Offline
catman  Offline
Your going to find that the huge chute is only good for going deep down wind. For me I would use it in any wind speed that I would sail in. Steer deep to survive and don't let off the mainsheet unless you want your mast half as long as it is now. Try to find a smaller Tornado chute. They're easier to handle and way more efficent. I can put you in touch with Robbie Daniels if your intrested. PM me here.
Re: Opinions on Mystere 6.0 ?Spinnaker.? [Re: catman] #51067
06/27/05 07:51 PM
06/27/05 07:51 PM
BobG Offline
BobG  Offline
Robbie still alive? is he still a Mystere dealer ? Does he want to save whats left of the Mystere Fleet.I've been on his website and see nothing about Mystere, could not be reading it correctly There seems to be a M6.0 in all corners of the state now maybe a little reunion at the Wild cat regatta is in order on Lake Eustis. Catman you will probably have to tell us the difference between the two boats.In Rick White's Cat Sailing for the 90's Randy Smythe has a section about the P19. Aside from the bow the boat at least has some of the same basic attributes. Is this the best written information to use to make a M6.0 competative.
Re: Opinions on Mystere 6.0 ?Spinnaker.? Sorry [Re: BobG] #51068
06/27/05 07:55 PM
06/27/05 07:55 PM
BobG Offline
BobG  Offline
Catius, that was meant for you about the two boats P19 I do know you can catch and pass them though.
Page 3 of 4 1 2 3 4
1 registered members (soulofasailor), 1,976 guests, and 26 spiders.
