| Re: lake size
[Re: mmadge]
#52073 06/30/05 06:04 PM 06/30/05 06:04 PM |
Posts: 152 Central Texas | The lake I used to sail on is about 50% of the size of the lake you are planing to sail on... A few people sailed Hobies and Darts there... Keep in mind that you will tack a lot and that the legs between the tacks will be short - not much time to get on the wire. You might want to think about a 14 or a wave...
Patrick, Hobie 16 '85
| | | Re: lake size
[Re: buster48]
#52081 07/04/05 02:02 AM 07/04/05 02:02 AM |
Posts: 493 Minnesota | I agree with that size of a lake being 'marginal'. -But it's better than not sailing at all.
It does get boring sailing back and forth across a small circle, if you are by yourself. But with friends and some beer, it is quite entertaining! Also, a slow wind will make a small lake seem HUGE. If the wind completely dies, and you forgot your paddle, hand-paddling will make the lake into an endless ocean! If you flip you boat, you won't need Gary's Solo-Right.-You just float to shore and walk the mast back up.
Seriously, get the Hobie. It will be fun enough. The wind is never the same, so there is always different experience each time you sail. The wind is steady, or puffy, or punchy, or light, or moderate, or heavy, or rising, or shifting, or...
| | | Re: lake size
[Re: aaronhoy]
#52083 07/06/05 12:59 AM 07/06/05 12:59 AM |
Posts: 493 Minnesota | No need to use the side of a Hobie-16. The tramp on a H-16 is laced with a convient place to 'dangle' through!
442
guests, and 27
