| Re: 2 questions.............
[Re: max]
#55883 08/24/05 06:25 PM 08/24/05 06:25 PM |
Posts: 152 Central Texas | #1 the holes are used to shackel the two jib sheet blocks in the middle to the jib. Depending which hole you are using you can modify the shape of the jib. Start with the hole in the middle ( I currentely use the middle hole and the one above - I shackle through two holes to shorten the distance between sail and crossbar when I sheet in tight)
#2 The old EPO's are made utilizing glass and epoxy as composit materials... I would not advice to lay up additional carbon fiber cloth. This might look cool if you have the equipment to get good quality surfaces, but it will not do anything for the performance of the part. The carbon fiber will act very different than the layers of glass. If you feel like the laminat of the EPO's is compramized - try to repair them in the traditional way utilizing glass cloth. If it is just damaged gel coat - sand them well, reapply the gel coat , or paint them. How ever the EPO's look they will perform better than the original Lexan blades. (IMHO)
Patrick
Patrick, Hobie 16 '85
1,093
guests, and 39
Mod | | Forums26 Topics22,406 Posts267,061 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
