Fitting a new tramp #56792
09/08/05 11:57 AM
09/08/05 11:57 AM
South Africa
Kappie Offline OP
Kappie  Offline OP
South Africa
Any tips re fitting a new mesh tram on H16? Method of lacing tramp etc?
Kappie
Re: Fitting a new tramp [Re: Kappie] #56793
09/08/05 12:32 PM
09/08/05 12:32 PM
Ontario, Canada
Captain_Dave Offline
Ontario, Canada
Kappie,
The Hobie 16 assembly manual http://www.hobiecat.com/support/pdfs/H16_Manual.pdf will give you what you need - step by step. I printed the manual out and keep one in my Hobie tool kit. It has come in handy more than a few times.
Dave
Re: Fitting a new tramp [Re: Captain_Dave] #56794
09/08/05 06:28 PM
09/08/05 06:28 PM
California
mmiller Offline
mmiller  Offline
California
Measure the bow to opposite rudder pins to get the boat square before tensioning. Use a line to pull the longer dimension closer and hold while tensioning the tramp.
Use a liquid soap to get the tramp into the side bars.
Lace the center from the front aft. Lace the rears from the corner casting holes then towards the center.
One trick we use...
Strap a line around the middle of the tramp, around the sidebars. Fix your mainsheet system to the line so you can tension and pull the sidebars in. Bow them in considerably, several inches anyway. Tension the center lace then the rear. Loosen the mainsheet setup and... shabang! You have a tight tramp with less effort and less stress on each grommet.
Hobie Cat Forums
Matt Miller
Hobie Cat Company
0 registered members (), 1,284 guests, and 50 spiders.
