| Re: Bent Mast Post Picture
[Re: bullswan]
#56831 09/10/05 09:36 AM 09/10/05 09:36 AM |
Posts: 744 | When the ball is totally screwed down, there should be 1/2" to no more than 5/8" gap of thread showing. Anything more will lead to the mast falling down.
Bob
[Re: Bob_Curry]
#56832 09/10/05 09:40 AM 09/10/05 09:40 AM |
Joined: Mar 2005 Posts: 2,074 Northfield,NH USA bullswan OP
Posts: 2,074 Northfield,NH USA | Thanks Bob that helps alot. What about the question of the current condition? Leave it alone or replace it? I thought if I could cut it down from the top rather than the bottom (And still screw the ball on, of course)I could get rid of most of the bent section. Is that a good idea do you think?
The nice part about being a pessimist is that you are constantly being either proven right or pleasantly surprised. - George Will "It's not that liberals aren't smart, it's just that so much of what they know isn't so" -Ronald Reagan | | | Re: Bent Mast Post Picture
[Re: bullswan]
#56833 09/10/05 08:14 PM 09/10/05 08:14 PM |
Posts: 1,479 Thailand | YIKES!!! It's too high. If it can't be straightened and cut then you'll need to replace it. There should be no more then an inch between the ball and the cross beam.
[Re: Bob_Curry]
#56834 09/11/05 08:12 PM 09/11/05 08:12 PM |
Posts: 12,310 South Carolina | Greg,
You might be able to cut that down - but it looks pretty bannanned all the way to the topmost nut. You should probably purchase a replacement and cut the bottom of it to get the elevation correct.
BTW - if you ever cut threads off, first put a nut down below your cut. Make your cut, debur the edges where you cut it, then back the nut off to clean up the threads.
Jake Kohl | | | Re: Bent Mast Post Picture
#56835 09/11/05 08:39 PM 09/11/05 08:39 PM |
Posts: 2,074 Northfield,NH USA | I tried to take the banana apart and the nut just jammed itself to the point that I finally got pissed and sawed the bent post and replaced the entire thing. Before intalling the new one though I did exactly what you say in your posting and cut it to length from the bottom. Left about 3/4 of an inch showing of threads and tried it out today and everything is ship shape. Thanks for your help. Good luck with Ophelia! Looks like you'll be sending her towards Brian Mc. when you are through with her.
Greg
[Re: bullswan]
#56836 09/12/05 06:42 AM 09/12/05 06:42 AM |
Posts: 12,310 South Carolina | Thanks - she turned more northerly overnight ...looks like Haterras now. Looks like we're going to be spared everything but 10 to 20knot breeze...it would be a good day to play hookie.
[Re: mangu]
#56838 09/12/05 03:37 PM 09/12/05 03:37 PM |
Posts: 2,074 Northfield,NH USA | On the shrouds I went down 2 holes and on the forestay I went down 3. I think I could actually go one more all around but I'm not sure how tight they should be, true be told. It's also hard to tell how much the mast is raked unless it's in the water. I used it yesterday this way and it was fine (no weather helm at all). I'm just going to experiment with it I guess.
Fingers crossed but I haven't had ANY problems with the traveler. I squirt in McLube about every other time I go and I make sure it doesn't slam the ends of the rail but other than that...... Could it be a different one than yours since my boat is a 1991 5.5SL?
[Re: mangu]
#56841 09/15/05 06:46 PM 09/15/05 06:46 PM |
Posts: 2,074 Northfield,NH USA | Hey Danno, I'm not sure what was original equipment but my Nacra 5.5SL has an 8:1 currently. Easy as pie. Now I know why!
Greg
1 registered members (Team_Cat_Fever),
361
guests, and 94
